path: root/board/st-ericsson/snowball
2014-02-19kbuild: use Linux Kernel build scriptsMasahiro Yamada
Now we are ready to switch over to real Kbuild. This commit disables temporary scripts: scripts/{Makefile.build.tmp, Makefile.host.tmp} and enables real Kbuild scripts: scripts/{Makefile.build,Makefile.host,Makefile.lib}. This switch is triggered by the line in scripts/Kbuild.include -build := -f $(if $(KBUILD_SRC),$(srctree)/)scripts/Makefile.build.tmp obj +build := -f $(if $(KBUILD_SRC),$(srctree)/)scripts/Makefile.build obj We need to adjust some build scripts for U-Boot. But smaller amount of modification is preferable. Additionally, we need to fix compiler flags which are locally added or removed. In Kbuild, it is not allowed to change CFLAGS locally. Instead, ccflags-y, asflags-y, cppflags-y, CFLAGS_$(basetarget).o, CFLAGS_REMOVE_$(basetarget).o are prepared for that purpose. Signed-off-by: Masahiro Yamada <yamada.m@jp.panasonic.com> Tested-by: Gerhard Sittig <gsi@denx.de>
2012-10-04snowball: Clear UART RX FIFORamesh Chandrasekaran
Without usb-serial cable plugged at this stage, some garbage is seen in UART RX FIFO, which blocks autoboot progress. The fix makes sure to empty the RX FIFO, before we wait for user input to interrupt autoboot. Signed-off-by: Ramesh Chandrasekaran <ramesh.chandrasekaran@stericsson.com>
2012-09-01u8500: Separating mmc config parameters from driverJohn Rigby
Configuration in vexpress and u8500.v1 is different from what is needed in u8500.v2. As such, card configuration specifics need to reside in the board file rather than the driver. Signed-off-by: John Rigby <john.rigby@linaro.org> Signed-off-by: Mathieu Poirier <mathieu.poirier@linaro.org> Signed-off-by: Tom Rini <trini@ti.com>
2012-09-01u8500: Enabling power to MMC device on AB8500 V2Mathieu J. Poirier
Register mapping has changed on power control chip between the first and second revision. Signed-off-by: Mathieu Poirier <mathieu.poirier@linaro.org> Signed-off-by: John Rigby <john.rigby@linaro.org> Signed-off-by: Tom Rini <trini@ti.com>
2012-09-01snowball: applying power to LAN and GBF controllersMathieu J. Poirier
LAN and GBF need to be powered explicitely, doing so with interface to AB8500 companion chip. Signed-off-by: Mathieu Poirier <mathieu.poirier@linaro.org> Signed-off-by: John Rigby <john.rigby@linaro.org>
2012-09-01snowball: Add support for ux500 based snowball boardMathieu J. Poirier
Signed-off-by: Mathieu Poirier <mathieu.poirier@linaro.org> Signed-off-by: John Rigby <john.rigby@linaro.org> Acked-by: Tom Rini <trini@ti.com> Acked-by: Linus Walleij <linus.walleij@linaro.org> Conflicts: drivers/gpio/Makefile
