path: root/board/sr1500/qts
2016-10-27arm: socfpga: sr1500: Adding handoff for SDRAM ctrlcfg.extratime1Chin Liang See
Adding new handoff for SDRAM ctrcfg.extratime1 which is required for stable LPDDR2 operation. Since the board is using DDR3, the handoff is set to default value 0. Signed-off-by: Chin Liang See <clsee@altera.com> Cc: Marek Vasut <marex@denx.de> Cc: Dinh Nguyen <dinguyen@opensource.altera.com>
2015-12-07arm: socfpga: Add SoCFPGA SR1500 boardStefan Roese
The SR1500 board is a CycloneV based board, similar to the EBV SoCrates, equipped with the following devices: - SPI NOR - eMMC - Ethernet Signed-off-by: Stefan Roese <sr@denx.de> Reviewed-by: Marek Vasut <marex@denx.de> Cc: Pavel Machek <pavel@denx.de> Cc: Dinh Nguyen <dinguyen@opensource.altera.com> Acked-by: Pavel Machek <pavel@denx.de>
