path: root/board/spear
2017-04-05board_f: Drop setup_dram_config() wrapperSimon Glass
By making dram_init_banksize() return an error code we can drop the wrapper. Adjust this and clean up all implementations. Signed-off-by: Simon Glass <sjg@chromium.org> Reviewed-by: Stefan Roese <sr@denx.de>
2016-05-31arm: spear: x600: Add support for Micrel KSZ9031 PHYStefan Roese
As the old ethernet PHY is not available any more, the x600 board has been redesigned with the Micrel KSZ9031 PHY. This patch adds support to autodetect the PHY and configure the Micrel PHY correctly. Signed-off-by: Stefan Roese <sr@denx.de>
2015-12-22net: designware: Zap CONFIG_DW_AUTONEGMarek Vasut
This symbol is not used anywhere, so remove it. For spear600, remove it from the board file, since the symbol is not defined for spear600 either. Signed-off-by: Marek Vasut <marex@denx.de> Cc: Dinh Nguyen <dinguyen@opensource.altera.com> Cc: Joe Hershberger <joe.hershberger@ni.com>
2015-08-28arm: spear: Fix booting - relocate vector table to 0 (low-vector)Stefan Roese
Booting SPEAr600 eval board doesn't work with current mainline U-Boot. With this patch the low-vector bit is left to '0'. Resulting in the common relocation of the vectors to 0 (SDRAM) to work correctly. Tested on the SPEAr600 EVB. Signed-off-by: Stefan Roese <sr@denx.de> Acked-by: Viresh Kumar <viresh.kumar@linaro.org> Cc: Vipin Kumar <vk.vipin@gmail.com>
2015-04-18Kconfig: Move CONFIG_DESIGNWARE_ETH to KconfigSimon Glass
Move this to Kconfig and clean up board config files that use it. Also rename it to CONFIG_ETH_DESIGNWARE to fit with the naming that exists in drivers/net/Kconfig. Signed-off-by: Simon Glass <sjg@chromium.org> Version 1: Acked-by: Joe Hershberger <joe.hershberger@ni.com>
2014-10-29kconfig: arm: introduce symbol for ARM CPUsGeorges Savoundararadj
This commit introduces a Kconfig symbol for each ARM CPU: CPU_ARM720T, CPU_ARM920T, CPU_ARM926EJS, CPU_ARM946ES, CPU_ARM1136, CPU_ARM1176, CPU_V7, CPU_PXA, CPU_SA1100. Also, it adds the CPU feature Kconfig symbol HAS_VBAR which is selected for CPU_ARM1176 and CPU_V7. For each target, the corresponding CPU is selected and the definition of SYS_CPU in the corresponding Kconfig file is removed. Also, it removes redundant "string" type in some Kconfig files. Signed-off-by: Georges Savoundararadj <savoundg@gmail.com> Acked-by: Albert ARIBAUD <albert.u.boot@aribaud.net> Cc: Masahiro Yamada <yamada.m@jp.panasonic.com>
2014-09-24MAINTAINERS: comment out blank M: fieldMasahiro Yamada
Since commit ddaf5c8f3030050fcd356a1e49e3ee8f8f52c6d4 (patman: RunPipe() should not pipe stdout/stderr unless asked), Patman spits lots of "Invalid MAINTAINERS address: '-'" error messages for patches with global changes. It takes too long for Patman to process them. Anyway, "M: -" does not carry any important information. Rather, it is just like a place holder in case of assigning a new board maintainer. Let's comment out. This commit can be reproduced by the following command: find . -name MAINTAINERS | xargs sed -i -e '/^M:[[:blank:]]*-$/s/^/#/' Signed-off-by: Masahiro Yamada <yamada.m@jp.panasonic.com>
2014-05-13fpga: xilinx: Avoid CamelCase for in Xilinx_descMichal Simek
No functional changes. Signed-off-by: Michal Simek <michal.simek@xilinx.com>
2014-05-13fpga: spartan3: Avoid CamelCaseMichal Simek
2014-02-19kbuild: add dummy obj-y to create built-in.oMasahiro Yamada
We are going to switch over to Kbuild in upcoming commits. Each makefile must have non-empty obj- or obj-y to generate built-in.o on Kbuild. Signed-off-by: Masahiro Yamada <yamada.m@jp.panasonic.com>
2014-02-07net/designware - switch driver to phylib usageAlexey Brodkin
With this change driver will benefit from existing phylib and thus custom phy functionality implemented in the driver will go away: * Instantiation of the driver is now much shorter - 2 parameters instead of 4. * Simplified phy management/functoinality in driver is replaced with rich functionality of phylib. * Support of custom phy initialization is now done with existing "board_phy_config". Note that after this change some previously used config options (driver-specific PHY configuration) will be obsolete and they are simply substituted with similar options of phylib. For example: * CONFIG_DW_AUTONEG - no need in this one. Autonegotiation is enabled by default. * CONFIG_DW_SEARCH_PHY - if one wants to specify attached phy explicitly CONFIG_PHY_ADDR board config option has to be used, otherwise automatically the first discovered on MDIO bus phy will be used I believe there's no need now in "doc/README.designware_eth" because user only needs to instantiate the driver with "designware_initialize" whose prototype exists in "include/netdev.h". Cc: Joe Hershberger <joe.hershberger@ni.com> Cc: Vipin Kumar <vipin.kumar@st.com> Cc: Stefan Roese <sr@denx.de> Cc: Mischa Jonker <mjonker@synopsys.com> Cc: Shiraz Hashim <shiraz.hashim@st.com> Cc: Albert ARIBAUD <albert.u.boot@aribaud.net> Cc: Amit Virdi <amit.virdi@st.com> Cc: Sonic Zhang <sonic.zhang@analog.com> Signed-off-by: Alexey Brodkin <abrodkin@synopsys.com>
2013-04-01Consolidate bool typeYork Sun
'bool' is defined in random places. This patch consolidates them into a single header file include/linux/types.h, using stdbool.h introduced in C99. All other #define, typedef and enum are removed. They are all consistent with true = 1, false = 0. Replace FALSE, False with false. Replace TRUE, True with true. Skip *.py, *.php, lib/* files. Signed-off-by: York Sun <yorksun@freescale.com>
2012-10-04ARM: Add X600 board support (SPEAr600 based)Stefan Roese
This patch adds support for the X600 SPEAr600 based board. Its also the first SPEAr600 board that uses the newly introduced SPEAr600 SPL support. Xloader is not necessary any more. By using the new "u-boot.spr" make target, one image will generated containing both, U-Boot SPL (with mkimage header as needed by the SPEAr BootROM, and the main U-Boot with mkimage header. Signed-off-by: Stefan Roese <sr@denx.de> Cc: Amit Virdi <amit.virdi@st.com> Cc: Vipin Kumar <vipin.kumar@st.com>
2012-07-07SPL: ARM: spear: Remove some objects from SPL buildStefan Roese
2012-07-07SPEAr: Enable dcache for fast file transferShiraz Hashim
Enable data cache with 1:1 mapping of DDR to enable fast file transfer over tty which was doing lot of copy. This feature is enabled only for flashing operation i.e. when CONFIG_SPEAR_USBTTY is enabled. This has been tested on SPEAr320, SPEAr600 and SPEAr900 evaluation boards. Following figures show an estimate on the performance improvements. The test setup was a Linux host (not Windows) and involved measurement of only binary transfer time, through kermit. The flash erase and flash copy time would be unaffected by these patches. Another thing is this that the timings remained more or less same across ARM9 and Cortex based devices, hence reporting only one of the cases. Before Enhancements =================== $ time ukermit.small -p /dev/ttyACM0 -f spear320_uImage.img Downloading file: 100.00% completed(2014080/2014080 bytes) real 0m41.228s user 0m0.002s sys 0m0.064s After Enhancements ================== $ time ukermit.large -p /dev/ttyACM0 -f spear320_uImage.img Downloading file: 100.00% completed(2014080/2014080 bytes) real 0m5.441s user 0m0.001s sys 0m0.001s Signed-off-by: Shiraz Hashim <shiraz.hashim@st.com> Signed-off-by: Amit Virdi <amit.virdi@st.com> Signed-off-by: Stefan Roese <sr@denx.de>
2012-07-07SPEAr: Initialize SNOR in early_board_init_fAmit Virdi
flash reading is required earlier than flash_init is called since the env_init is called before flash_init. This makes the smi_init necessary before env_init being called. Signed-off-by: Amit Virdi <amit.virdi@st.com> Acked-by: Stefan Roese <sr@denx.de> Signed-off-by: Stefan Roese <sr@denx.de>
2012-07-07SPEAr: Add configuration options for spear3xx and spear6xx boardsVipin KUMAR
This patch adds options for all the below mentioned configurations and subsequently renames the include/configs/spearxxx.h files to spear3xx_evb.h, spear6xx_evb.h etc to depict evaluation board configuration. SPEAr3xx and SPEAr6xx boards can be compiled in following configurations 1. Environment placed in NAND 2. Console on usb device 3. Console on usb device with environment placed in NAND 4. SPEAr310 and SPEAr320 support environment variables in parallel NOR flash. Signed-off-by: Vipin Kumar <vipin.kumar@st.com> Signed-off-by: Amit Virdi <amit.virdi@st.com> Signed-off-by: Stefan Roese <sr@denx.de>
2012-07-07SPEAr: Add interface information in initializationVipin Kumar
Few Designware peripheral registers need to be modified based on the ethernet interface selected by the board. This patch supports interface information in ethernet driver Signed-off-by: Vipin Kumar <vipin.kumar@st.com> Signed-off-by: Amit Virdi <amit.virdi@st.com> Signed-off-by: Stefan Roese <sr@denx.de>
2012-07-07SPEAr: Add macb driver support for spear310 and spear320Vipin KUMAR
SPEAr310 and SPEAr320 SoCs have an extra ethernet controller. The driver for this device is already supported by u-boot, so configuring board configuration file and defining base addresses etc to make use of the common driver Signed-off-by: Vipin Kumar <vipin.kumar@st.com> Signed-off-by: Amit Virdi <amit.virdi@st.com> Signed-off-by: Stefan Roese <sr@denx.de>
2012-07-07SPEAr: Configure network support for spear SoCsVipin KUMAR
2012-07-07SPEAr: Place ethaddr write and read within CONFIG_CMD_NETVipin KUMAR
ethaddr can be optionally read from i2c memory. So, chip_config command supports reading/writing hw mac id into i2c memory. Placing this code within CONFIG_CMD_NET as this would only be needed when network interface is configured Signed-off-by: Vipin Kumar <vipin.kumar@st.com> Signed-off-by: Amit Virdi <amit.virdi@st.com> Signed-off-by: Stefan Roese <sr@denx.de>
2012-07-07SPEAr: Eliminate dependency on Xloader tableAmit Virdi
Xloader table was used primarily to inform u-boot about the DDR size. However, now the ddr size is calculated at runtime which eliminates any need for the Xloader table. So removing this unnecessary code. Signed-off-by: Amit Virdi <amit.virdi@st.com> Acked-by: Stefan Roese <sr@denx.de> Signed-off-by: Stefan Roese <sr@denx.de>
2012-07-07SPEAr: Fix ARM relocation supportAmit Virdi
While the u-boot code is running from the flash, it is essential that no access is made to the bss segment. This is due to the fact that .rel.dyn and .bss areas overlap and former contains information used in relocation. In SPEAr, this was not taken into consideration. As a result, while the relocation wasn't complete, dram_init populated an uninitialized global variable resulting in corruption of .rel.dyn area, which resulted in u-boot crash. This commit fixes this problem by removing code that accesses bss segment Signed-off-by: Amit Virdi <amit.virdi@st.com> Acked-by: Stefan Roese <sr@denx.de> Signed-off-by: Stefan Roese <sr@denx.de>
2012-07-07SPEAr: Configure FSMC driver for NAND interfaceVipin KUMAR
Since FSMC is a standard IP and it supports different memory interfaces, it is supported independent of spear platform and spear is configured to use that driver for interfacing with the NAND device Signed-off-by: Vipin Kumar <vipin.kumar@st.com> Signed-off-by: Amit Virdi <amit.virdi@st.com> Signed-off-by: Stefan Roese <sr@denx.de> Acked-by: Scott Wood <scottwood@freescale.com>
2011-08-04spear: fix build errors for spear3xx/spear600 platformsShiraz Hashim
Signed-off-by: Shiraz Hashim <shiraz.hashim@st.com> Acked-by: Vipin Kumar <vipin.kumar@st.com>
2011-07-26Use ALL-y style instead of ifeq blocks for better readabilityDaniel Schwierzeck
Signed-off-by: Daniel Schwierzeck <daniel.schwierzeck@googlemail.com>
2010-07-24cmd_usage(): simplify return code handlingWolfgang Denk
Lots of code use this construct: cmd_usage(cmdtp); return 1; Change cmd_usage() let it return 1 - then we can replace all these ocurrances by return cmd_usage(cmdtp); This fixes a few places with incorrect return code handling, too. Signed-off-by: Wolfgang Denk <wd@denx.de>
2010-03-21mod change 755 => 644 for multiple filesThomas Weber
I executed 'find . -name "*.[chS]" -perm 755 -exec chmod 644 {} \;' Signed-off-by: Thomas Weber <swirl@gmx.li> Add some more: neither Makefile nor config.mk need execute permissions. Signed-off-by: Wolfgang Denk <wd@denx.de>
2010-03-07SPEAr : Supporting new mach ids for spear310 and spear320Vipin Kumar
Supporting new machine ids for SoCs spear310 and spear320 include/asm-arm/mach-types.h has to be updated before applying this patch for build to work Signed-off-by: Vipin Kumar <vipin.kumar@st.com>
2010-01-23SPEAr : Support added for SPEAr320 boardVipin KUMAR
SPEAr320 SoC support contains basic spear320 support along with the usage of following drivers - serial driver(UART) - i2c driver - smi driver - nand driver(FSMC) - usbd driver - emi driver(cfi support) Signed-off-by: Vipin <vipin.kumar@st.com>
2010-01-23SPEAr : Support added for SPEAr310 boardVipin KUMAR
SPEAr310 SoC support contains basic spear310 support along with the usage of following drivers - serial driver(UART) - i2c driver - smi driver - nand driver(FSMC) - usbd driver - emi driver(cfi support) Signed-off-by: Vipin <vipin.kumar@st.com>
2010-01-23SPEAr : emi controller initialization for CFI driver supportVipin KUMAR
SPEAr310 and SPEAr320 SoCs contain an EMI controller to interface Paraller NOR flashes. This patch adds the support for this IP The standard CFI driver is used to interface with NOR flashes Signed-off-by: Vipin <vipin.kumar@st.com>
2010-01-23SPEAr : Support added for SPEAr300 boardVipin KUMAR
SPEAr300 SoC support contains basic spear300 support along with the usage of following drivers - serial driver(UART) - i2c driver - smi driver - nand driver(FSMC) - usbd driver Signed-off-by: Vipin <vipin.kumar@st.com>
2010-01-23SPEAr : Support for HW mac id read/write from i2c memVipin KUMAR
This patch adds the support to read and write mac id from i2c memory. For reading: if (env contains ethaddr) pick env ethaddr else pick ethaddr from i2c memory For writing: chip_config ethaddr XX:XX:XX:XX:XX:XX writes the mac id in i2c memory Signed-off-by: Vipin <vipin.kumar@st.com>
2010-01-23SPEAr : Support added for SPEAr600 boardVipin KUMAR
SPEAr600 SoC support contains basic spear600 support along with the usage of following drivers - serial driver(UART) - i2c driver - smi driver - nand driver(FSMC) - usbd driver Signed-off-by: Vipin <vipin.kumar@st.com>
