path: root/board/spear/spear320/spear320.c
2015-04-18Kconfig: Move CONFIG_DESIGNWARE_ETH to KconfigSimon Glass
Move this to Kconfig and clean up board config files that use it. Also rename it to CONFIG_ETH_DESIGNWARE to fit with the naming that exists in drivers/net/Kconfig. Signed-off-by: Simon Glass <sjg@chromium.org> Version 1: Acked-by: Joe Hershberger <joe.hershberger@ni.com>
2014-02-07net/designware - switch driver to phylib usageAlexey Brodkin
With this change driver will benefit from existing phylib and thus custom phy functionality implemented in the driver will go away: * Instantiation of the driver is now much shorter - 2 parameters instead of 4. * Simplified phy management/functoinality in driver is replaced with rich functionality of phylib. * Support of custom phy initialization is now done with existing "board_phy_config". Note that after this change some previously used config options (driver-specific PHY configuration) will be obsolete and they are simply substituted with similar options of phylib. For example: * CONFIG_DW_AUTONEG - no need in this one. Autonegotiation is enabled by default. * CONFIG_DW_SEARCH_PHY - if one wants to specify attached phy explicitly CONFIG_PHY_ADDR board config option has to be used, otherwise automatically the first discovered on MDIO bus phy will be used I believe there's no need now in "doc/README.designware_eth" because user only needs to instantiate the driver with "designware_initialize" whose prototype exists in "include/netdev.h". Cc: Joe Hershberger <joe.hershberger@ni.com> Cc: Vipin Kumar <vipin.kumar@st.com> Cc: Stefan Roese <sr@denx.de> Cc: Mischa Jonker <mjonker@synopsys.com> Cc: Shiraz Hashim <shiraz.hashim@st.com> Cc: Albert ARIBAUD <albert.u.boot@aribaud.net> Cc: Amit Virdi <amit.virdi@st.com> Cc: Sonic Zhang <sonic.zhang@analog.com> Signed-off-by: Alexey Brodkin <abrodkin@synopsys.com>
2012-07-07SPEAr: Add interface information in initializationVipin Kumar
Few Designware peripheral registers need to be modified based on the ethernet interface selected by the board. This patch supports interface information in ethernet driver Signed-off-by: Vipin Kumar <vipin.kumar@st.com> Signed-off-by: Amit Virdi <amit.virdi@st.com> Signed-off-by: Stefan Roese <sr@denx.de>
2012-07-07SPEAr: Add macb driver support for spear310 and spear320Vipin KUMAR
SPEAr310 and SPEAr320 SoCs have an extra ethernet controller. The driver for this device is already supported by u-boot, so configuring board configuration file and defining base addresses etc to make use of the common driver Signed-off-by: Vipin Kumar <vipin.kumar@st.com> Signed-off-by: Amit Virdi <amit.virdi@st.com> Signed-off-by: Stefan Roese <sr@denx.de>
2012-07-07SPEAr: Configure network support for spear SoCsVipin KUMAR
2012-07-07SPEAr: Configure FSMC driver for NAND interfaceVipin KUMAR
Since FSMC is a standard IP and it supports different memory interfaces, it is supported independent of spear platform and spear is configured to use that driver for interfacing with the NAND device Signed-off-by: Vipin Kumar <vipin.kumar@st.com> Signed-off-by: Amit Virdi <amit.virdi@st.com> Signed-off-by: Stefan Roese <sr@denx.de> Acked-by: Scott Wood <scottwood@freescale.com>
2010-03-21mod change 755 => 644 for multiple filesThomas Weber
I executed 'find . -name "*.[chS]" -perm 755 -exec chmod 644 {} \;' Signed-off-by: Thomas Weber <swirl@gmx.li> Add some more: neither Makefile nor config.mk need execute permissions. Signed-off-by: Wolfgang Denk <wd@denx.de>
2010-03-07SPEAr : Supporting new mach ids for spear310 and spear320Vipin Kumar
Supporting new machine ids for SoCs spear310 and spear320 include/asm-arm/mach-types.h has to be updated before applying this patch for build to work Signed-off-by: Vipin Kumar <vipin.kumar@st.com>
2010-01-23SPEAr : Support added for SPEAr320 boardVipin KUMAR
SPEAr320 SoC support contains basic spear320 support along with the usage of following drivers - serial driver(UART) - i2c driver - smi driver - nand driver(FSMC) - usbd driver - emi driver(cfi support) Signed-off-by: Vipin <vipin.kumar@st.com>
