path: root/board/spc1920
2008-07-11Fix some more print() format errors.Wolfgang Denk
2007-08-02Fix build errors and warnings / code cleanup.Wolfgang Denk
2007-01-09SPC1920: cleanup memory contoller setupMarkus Klotzbuecher
2007-01-09SPC1920: add support for the FM18L08 Ramtron FRAMMarkus Klotzbuecher
2007-01-09Miscellanious spc1920 related cleanupsMarkus Klotzbuecher
2007-01-09SPC1920 GO/NOGO led should be set to color red in U-BootMarkus Klotzbuecher
2007-01-09Update the SPC1920 CMB PLD driverMarkus Klotzbuecher
2007-01-09Add support for the tms320671x host port interface (HPI)Markus Klotzbuecher
2006-07-21Code cleanup.Wolfgang Denk
2006-07-12Support for spc1920 board.Markus Klotzbuecher
Patch by Markus Klotzbuecher, 12 Jul 2006
