path: root/board/sorcery
2008-11-09Moved initialization of MPC8220 FEC to cpu_eth_init()Ben Warren
Removed initialization of the driver from net/eth.c Signed-off-by: Ben Warren <biggerbadderben@gmail.com>
2008-09-02Moved initialization of EEPRO100 Ethernet controller to board_eth_init()Ben Warren
Affected boards: db64360 db64460 katmai taihu taishan yucca cpc45 cpu87 eXalion elppc debris kvme080 mpc8315erdb integratorap ixdp425 oxc pm826 pm828 pm854 pm856 ppmc7xx sc3 sc520_spunk sorcery tqm8272 tqm85xx utx8245 Removed initialization of the driver from net/eth.c Also, wrapped contents of pci_eth_init() by CONFIG_PCI. Signed-off-by: Ben Warren <biggerbadderben@gmail.com>
2007-07-04Remove obsolete mpc8220 linker scriptsGrant Likely
2006-09-04Fix build problems on sorcery board.Wolfgang Denk
2005-05-16Add PCI support for Sorcery board.wdenk
Code cleanup (especially Sorcery / Alaska / Yukon serial driver).
2005-04-05* Patch by Ladislav Michl, 05 Apr 2005:wdenk
Add support for VoiceBlue board. * Patch by Ladislav Michl, 05 Apr 2005: Fix netboot_common() prototypes. * Cleanup.
2005-04-05Add support for MPC8220 based "sorcery" board.LABEL_2005_04_05_2345wdenk
