path: root/board/solidrun
2017-08-28imx: imx6: Move gpr_init() function to soc.cBreno Lima
Since the gpr_init() function is common for boards using MX6S, MX6DL, MX6D, MX6Q and MX6QP processors move it to the soc.c file. Signed-off-by: Breno Lima <breno.lima@nxp.com> Acked-by: Stefano Babic <sbabic@denx.de> Reviewed-by: Lukasz Majewski <lukma@denx.de> Reviewed-by: Fabio Estevam <fabio.estevam@nxp.com>
2017-07-18Merge branch 'master' of git://www.denx.de/git/u-boot-imxTom Rini
Change is consistent with other SOCs and it is in preparation for adding SOMs. SOC's related files are moved from cpu/ to mach-imx/<SOC>. This change is also coherent with the structure in kernel. Signed-off-by: Stefano Babic <sbabic@denx.de> CC: Fabio Estevam <fabio.estevam@nxp.com> CC: Akshay Bhat <akshaybhat@timesys.com> CC: Ken Lin <Ken.Lin@advantech.com.tw> CC: Marek Vasut <marek.vasut@gmail.com> CC: Heiko Schocher <hs@denx.de> CC: "Sébastien Szymanski" <sebastien.szymanski@armadeus.com> CC: Christian Gmeiner <christian.gmeiner@gmail.com> CC: Stefan Roese <sr@denx.de> CC: Patrick Bruenn <p.bruenn@beckhoff.com> CC: Troy Kisky <troy.kisky@boundarydevices.com> CC: Nikita Kiryanov <nikita@compulab.co.il> CC: Otavio Salvador <otavio@ossystems.com.br> CC: "Eric Bénard" <eric@eukrea.com> CC: Jagan Teki <jagan@amarulasolutions.com> CC: Ye Li <ye.li@nxp.com> CC: Peng Fan <peng.fan@nxp.com> CC: Adrian Alonso <adrian.alonso@nxp.com> CC: Alison Wang <b18965@freescale.com> CC: Tim Harvey <tharvey@gateworks.com> CC: Martin Donnelly <martin.donnelly@ge.com> CC: Marcin Niestroj <m.niestroj@grinn-global.com> CC: Lukasz Majewski <lukma@denx.de> CC: Adam Ford <aford173@gmail.com> CC: "Albert ARIBAUD (3ADEV)" <albert.aribaud@3adev.fr> CC: Boris Brezillon <boris.brezillon@free-electrons.com> CC: Soeren Moch <smoch@web.de> CC: Richard Hu <richard.hu@technexion.com> CC: Wig Cheng <wig.cheng@technexion.com> CC: Vanessa Maegima <vanessa.maegima@nxp.com> CC: Max Krummenacher <max.krummenacher@toradex.com> CC: Stefan Agner <stefan.agner@toradex.com> CC: Markus Niebel <Markus.Niebel@tq-group.com> CC: Breno Lima <breno.lima@nxp.com> CC: Francesco Montefoschi <francesco.montefoschi@udoo.org> CC: Jaehoon Chung <jh80.chung@samsung.com> CC: Scott Wood <oss@buserror.net> CC: Joe Hershberger <joe.hershberger@ni.com> CC: Anatolij Gustschin <agust@denx.de> CC: Simon Glass <sjg@chromium.org> CC: "Andrew F. Davis" <afd@ti.com> CC: "Łukasz Majewski" <l.majewski@samsung.com> CC: Patrice Chotard <patrice.chotard@st.com> CC: Nobuhiro Iwamatsu <iwamatsu@nigauri.org> CC: Hans de Goede <hdegoede@redhat.com> CC: Masahiro Yamada <yamada.masahiro@socionext.com> CC: Stephen Warren <swarren@nvidia.com> CC: Andre Przywara <andre.przywara@arm.com> CC: "Álvaro Fernández Rojas" <noltari@gmail.com> CC: York Sun <york.sun@nxp.com> CC: Xiaoliang Yang <xiaoliang.yang@nxp.com> CC: Chen-Yu Tsai <wens@csie.org> CC: George McCollister <george.mccollister@gmail.com> CC: Sven Ebenfeld <sven.ebenfeld@gmail.com> CC: Filip Brozovic <fbrozovic@gmail.com> CC: Petr Kulhavy <brain@jikos.cz> CC: Eric Nelson <eric@nelint.com> CC: Bai Ping <ping.bai@nxp.com> CC: Anson Huang <Anson.Huang@nxp.com> CC: Sanchayan Maity <maitysanchayan@gmail.com> CC: Lokesh Vutla <lokeshvutla@ti.com> CC: Patrick Delaunay <patrick.delaunay@st.com> CC: Gary Bisson <gary.bisson@boundarydevices.com> CC: Alexander Graf <agraf@suse.de> CC: u-boot@lists.denx.de Reviewed-by: Fabio Estevam <fabio.estevam@nxp.com> Reviewed-by: Christian Gmeiner <christian.gmeiner@gmail.com>
2017-07-12mx6cuboxi: Add support for sataPeter Robinson
The Cubox-i and Hummingboard series of devices have an option of SATA on board, and depending on how the fuses are blown even the option to boot SPL from SATA. So enable support for it so it can be used to boot the OS from if people desire. Cc: Fabio Estevam <fabio.estevam@nxp.com> Signed-off-by: Peter Robinson <pbrobinson@gmail.com> Acked-by: Fabio Estevam <fabio.estevam@nxp.com>
2017-07-12arm: mvebu: clearfog: fix chip name commentBaruch Siach
The clearfog uses Armada 388. Cc: Stefan Roese <sr@denx.de> Signed-off-by: Baruch Siach <baruch@tkos.co.il> Signed-off-by: Stefan Roese <sr@denx.de>
2017-07-12driver/ddr: Add support for setting timing in hws_topology_mapMarek Behún
The DDR3 training code for Marvell A38X currently computes 1t timing when given board topology map of the Turris Omnia, but Omnia needs 2t. This patch adds support for enforcing the 2t timing in struct hws_topology_map, through a new enum hws_timing, which can assume following values: HWS_TIM_DEFAULT - default behaviour, compute whether to enable 2t from the number of CSs HWS_TIM_1T - enforce 1t HWS_TIM_2T - enforce 2t This patch also sets all the board topology maps (db-88f6820-amc, db-88f6820-gp, controlcenterdc and clearfog) to have timing set to HWS_TIM_DEFAULT. Signed-off-by: Marek Behun <marek.behun@nic.cz> Reviewed-by: Stefan Roese <sr@denx.de> Signed-off-by: Stefan Roese <sr@denx.de>
2017-05-31arm: mvebu: clearfog: reset uSOM onboard 1512 phyPatrick Wildt
Use GPIO19 which is wired to the uSOM phy reset signal in order to reset the uSOM's 1512 Gigabit Ethernet phy. This GPIO is valid on ClearFog rev 2.1 and newer. Taken from SolidRun's specialised u-boot, see https://github.com/SolidRun/u-boot-armada38x/commit/f906e3df172e07ac82cdd87b278d7896949262ea Signed-off-by: Patrick Wildt <patrick@blueri.se> Signed-off-by: Stefan Roese <sr@denx.de>
2016-09-06mx6: ddr: Allow changing REFSEL and REFR fieldsFabio Estevam
Currently MX6 SPL DDR initialization hardcodes the REF_SEL and REFR fields of the MDREF register as 1 and 7, respectively for DDR3 and 0 and 3 for LPDDR2. Looking at the MDREF initialization done via DCD we see that boards do need to initialize these fields differently: $ git grep 0x021b0020 board/ board/bachmann/ot1200/mx6q_4x_mt41j128.cfg:DATA 4 0x021b0020 0x00005800 board/ccv/xpress/imximage.cfg:DATA 4 0x021b0020 0x00000800 /* MMDC0_MDREF */ board/freescale/mx6qarm2/imximage.cfg:DATA 4 0x021b0020 0x7800 board/freescale/mx6qarm2/imximage.cfg:DATA 4 0x021b0020 0x00005800 board/freescale/mx6qarm2/imximage_mx6dl.cfg:DATA 4 0x021b0020 0x00005800 board/freescale/mx6qarm2/imximage_mx6dl.cfg:DATA 4 0x021b0020 0x00005800 board/freescale/mx6qsabreauto/imximage.cfg:DATA 4 0x021b0020 0x00005800 board/freescale/mx6qsabreauto/mx6dl.cfg:DATA 4 0x021b0020 0x00005800 board/freescale/mx6qsabreauto/mx6qp.cfg:DATA 4 0x021b0020 0x00005800 board/freescale/mx6sabresd/mx6dlsabresd.cfg:DATA 4 0x021b0020 0x00005800 board/freescale/mx6sabresd/mx6q_4x_mt41j128.cfg:DATA 4 0x021b0020 0x00005800 board/freescale/mx6slevk/imximage.cfg:DATA 4 0x021b0020 0x00001800 board/freescale/mx6sxsabreauto/imximage.cfg:DATA 4 0x021b0020 0x00000800 board/freescale/mx6sxsabresd/imximage.cfg:DATA 4 0x021b0020 0x00000800 board/warp/imximage.cfg:DATA 4 0x021b0020 0x00001800 So introduce a mechanism for users to be able to configure REFSEL and REFR fields as needed. Keep all the mx6 SPL users in their current REF_SEL and REFR values, so no functional changes for the existing users. Signed-off-by: Fabio Estevam <fabio.estevam@nxp.com> Reviewed-by: Eric Nelson <eric@nelint.com>
2016-07-28mx6cuboxi: Replace is_mx6q() for macroBreno Lima
It's not necessary to implement the is_mx6q function, there is a macro in sys_proto.h already implemented. Signed-off-by: Breno Lima <breno.lima@nxp.com> Reviewed-by: Fabio Estevam <fabio.estevam@nxp.com>
2016-04-01usb: Rename ehci-fsl.h to ehci-ci.hMateusz Kulikowski
Most of ehci-fsl header describe USB controller designed by Chipidea and used by various SoC vendors. This patch renames it to a generic header: ehci-ci.h Contents of file are not changed (so it contains several references to freescale SoCs). Signed-off-by: Mateusz Kulikowski <mateusz.kulikowski@gmail.com> Acked-by: Marek Vasut <marex@denx.de> Tested-by: Simon Glass <sjg@chromium.org>
2016-02-06Use correct spelling of "U-Boot"Bin Meng
Correct spelling of "U-Boot" shall be used in all written text (documentation, comments in source files etc.). Signed-off-by: Bin Meng <bmeng.cn@gmail.com> Reviewed-by: Heiko Schocher <hs@denx.de> Reviewed-by: Simon Glass <sjg@chromium.org> Reviewed-by: Minkyu Kang <mk7.kang@samsung.com>
2016-01-14arm: mvebu: Consolidate board Kconfig options into one fileStefan Roese
Merging all the board specific Kconfig options into the main Kconfig file for mach-mvebu makes things easier to maintain. Signed-off-by: Stefan Roese <sr@denx.de> Cc: Luka Perkov <luka.perkov@sartura.hr>
2016-01-14arm: mvebu: Add SolidRun ClearFog Armada 38x initial supportStefan Roese
This patch adds basic support for the SolidRun ClearFog Armada 38x based board to mainline U-Boot. Supported interfaces / devices are: - DDR3 - UART - MMC - Ethernet port 0 (connected to dedicated PHY) - I2C The included DT source was taken from Russell King's ftp server: http://www.home.arm.linux.org.uk/~rmk/clearfog/ With only minor modifications, like the addition of some aliases and the "u-boot,dm-pre-reloc" property. Signed-off-by: Stefan Roese <sr@denx.de> Cc: Rabeeh Khoury <rabeeh@solid-run.com> Cc: Luka Perkov <luka.perkov@sartura.hr>
2016-01-11MAINTAINERS/mailmap: Update my email addressFabio Estevam
Update my email address to the NXP account. Signed-off-by: Fabio Estevam <fabio.estevam@nxp.com>
2016-01-10mx6cuboxi: Remove obsolete commentFabio Estevam
We currently support various versions of Solidrun mx6 boards, so remove the obsolete comment. Reported-by: Jon Nettleton <jon.nettleton@gmail.com> Signed-off-by: Fabio Estevam <fabio.estevam@nxp.com> Reviewed-by: Stefano Babic <sbabic@denx.de>
2016-01-10mx6cuboxi: Fix the reset delay for the AR8035 PHYFabio Estevam
Since commit 59370f3fcd1350 ("net: phy: delay only if reset handler is registered") Ethernet is no longer functional: Booting from net ... FEC Waiting for PHY auto negotiation to complete......... TIMEOUT ! BOOTP broadcast 1 BOOTP broadcast 2 BOOTP broadcast 3 BOOTP broadcast 4 This commit does not have an issue in itself, but it revelead a problem with the Ethernet initialization. As per the AR8035 datasheet: "For a reliable power on reset, suggest to keep asserting the reset low long enough (10ms) to ensure the clock is stable and clock-to-reset 1ms requirement is satisfied." So do as suggested and keep the reset low for 10ms. Also add a 100us delay after deasserting the reset line to guarantee that the PHY ID can be read correctly and the Atheros PHY can be loaded as per Troy Kisky's suggestion. Signed-off-by: Fabio Estevam <fabio.estevam@nxp.com> Tested-by: Tom Rini <trini@konsulko.com>
2015-09-13mx6: remove SYS_SOC from board KconfigPeng Fan
Remove duplicated SYS_SOC Kconfig entry from board Kconfig, because we have this entry in arch/arm/cpu/armv7/mx6/Kconfig. Signed-off-by: Peng Fan <Peng.Fan@freescale.com> Cc: Stefano Babic <sbabic@denx.de> Cc: Heiko Schocher <hs@denx.de> Cc: Christian Gmeiner <christian.gmeiner@gmail.com> Cc: Stefan Roese <sr@denx.de> Cc: Troy Kisky <troy.kisky@boundarydevices.com> Cc: Nikita Kiryanov <nikita@compulab.co.il> Cc: "Eric Bénard" <eric@eukrea.com> Cc: Fabio Estevam <fabio.estevam@freescale.com> Cc: Tim Harvey <tharvey@gateworks.com> Cc: Marek Vasut <marex@denx.de> Cc: Markus Niebel <Markus.Niebel@tq-group.com> Cc: Otavio Salvador <otavio@ossystems.com.br> Acked-by: Stefan Roese <sr@denx.de> Acked-by: Marek Vasut <marex@denx.de> Acked-by: Christian Gmeiner <christian.gmeiner@gmail.com> Acked-by: Markus Niebel <Markus.Niebel@tq-group.com> Acked-by: Troy Kisky <troy.kisky@boundarydevices.com> Acked-by: Igor Grinberg <grinberg@compulab.co.il>
2015-09-02imx: mx6: ddr init MMDC according to ddr_typePeng Fan
To i.MX6, DDR3 and LPDDR2 is supported, so rename function mx6_dram_cfg to mx6_ddr3_cfg and the original mx6_dram_cfg function only is a wrapper. The new reimplemented function mx6_dram_cfg only invokes mx6_ddr3_cfg when ddr_type is for DDR3. Later we can use ddr_type to initialize MMDC for LPDDR2. Initialize ddr_type for different boards which enable SPL. Signed-off-by: Peng Fan <Peng.Fan@freescale.com> Cc: Stefano Babic <sbabic@denx.de> Cc: Tim Harvey <tharvey@gateworks.com> Cc: Stefan Roese <sr@denx.de> Cc: Fabio Estevam <fabio.estevam@freescale.com> Reviewed-by: Stefan Roese <sr@denx.de>
2015-09-02imx: clock support enet2 anatop clock supportPeng Fan
To i.MX6SX/UL, two ethernet interfaces are supported. Add ENET2 clock support: 1. Introduce a new input parameter "fec_id", only 0 and 1 are allowed. To value 1, only i.MX6SX/UL can pass the check. 2. Modify board code who use this api to follow new api prototype. Signed-off-by: Peng Fan <Peng.Fan@freescale.com> Cc: Heiko Schocher <hs@denx.de> Cc: Fabio Estevam <fabio.estevam@freescale.com> Cc: Stefan Roese <sr@denx.de> Cc: Nikolaos Pasaloukos <Nikolaos.Pasaloukos@imgtec.com> Cc: Stefano Babic <sbabic@denx.de> Reviewed-by: Stefan Roese <sr@denx.de>
2015-06-15mx6cuboxi: Fix boot of hummingboard dual-liteFabio Estevam
Hummingboard dual-lite is picking the incorrect calibration structure. Fix it so that it can boot. While at it, also fix p1_mpdgctrl1 register to match Solid-run's setting. Reported-by: Andrei Gherzan <andrei@gherzan.ro> Signed-off-by: Fabio Estevam <fabio.estevam@freescale.com> Tested-by: Andrei Gherzan <andrei@gherzan.ro>
2015-05-19hummingboard: Remove unused directoryFabio Estevam
The 'mx6-microsom' directory was only used for the previous mx6solo hummingboard support, which has been removed in favour of the SPL version. Remove the remaining piece of the old mx6solo hummingboard support. Signed-off-by: Fabio Estevam <fabio.estevam@freescale.com> Acked-by: Stefano Babic <sbabic@denx.de>
2015-05-15mx6cuboxi: Mention Cubox-i in the READMEFabio Estevam
Cubox-i boards are also supported, so update the README file. Signed-off-by: Fabio Estevam <fabio.estevam@freescale.com>
2015-05-15hummingboard: Remove mx6solo specific supportFabio Estevam
Hummingboard dual, dual-lite and solo are now supported via SPL mechanism. Remove the previous hummingboard support, which does not use SPL and supported only the solo variant. Signed-off-by: Fabio Estevam <fabio.estevam@freescale.com> Reviewed-by: Tom Rini <trini@konsulko.com>
2015-05-15mx6cuboxi: Pull down PAD_ENET_RXD0/RXD1Fabio Estevam
Configure PAD_ENET_RXD0/RXD1 pads as pull down because these pads are directly connected to the Atheros 8035/8030 although they should be functional only in the RMII mode - 8030. Signed-off-by: Rabeeh Khoury <rabeeh@solid-run.com> Signed-off-by: Fabio Estevam <fabio.estevam@freescale.com> Reviewed-by: Stefano Babic <sbabic@denx.de> Reviewed-by: Tom Rini <trini@konsulko.com> Tested-By: Vagrant Cascadian <vagrant@aikidev.net>
2015-05-15mx6cuboxi: Fix Ethernet PHY detection problemFabio Estevam
mx6cuboxi sometimes fails to recognize the Ethernet PHY: Net: Phy 0 not found The explanation for this behavior comes from from Rabeeh Khoury: "The LED_ACT pin on the carrier-one boards had a pull down that forces the phy address to 0x0; where on CuBox-i and the production HummingBoard that pin is connected directly to LED that depending on the pull down strength of the LED it might be sampled as '0' or '1' thus the phy address might appear as either address 0x0 or 0x4." "This is AR8035 implementation; in reset stage the LED pin is configured as input, and pull up/down does matter. In this case it configures the PHY address. After reset is deasserted the same LED pin becomes output and then according to the previous pull/up it should be active high/low" One way to properly fix this behavior is to place external pull-up/down resistors in the LED line, but from a software standpoint we can fix it by telling phy_find_by_mask() to scan the PHY at addresses 0x0 and 0x4. Reported-by: Vagrant Cascadian <vagrant@aikidev.net> Signed-off-by: Rabeeh Khoury <rabeeh@solid-run.com> Signed-off-by: Fabio Estevam <fabio.estevam@freescale.com> Acked-by: Stefano Babic <sbabic@denx.de> Reviewed-by: Tom Rini <trini@konsulko.com> Tested-By: Vagrant Cascadian <vagrant@aikidev.net>
2015-05-15mx6cuboxi: Add USB host supportFabio Estevam
Enable USB Host1 port. Signed-off-by: Rabeeh Khoury <rabeeh@solid-run.com> Signed-off-by: Fabio Estevam <fabio.estevam@freescale.com> Tested-By: Vagrant Cascadian <vagrant@aikidev.net>
2015-05-15mx6cuboxi: Add HDMI output supportFabio Estevam
Add HDMI output using PLL5 as the source for the IPU clocks, and accurate VESA timings. These settings are based on the patch from Soeren Moch <smoch@web.de> submitted for the tbs2910 mx6 based board. It allows the display to work properly at 1024x768@60. This should make the hdmi output signal compatible with most if not all modern displays. Signed-off-by: Jon Nettleton <jon.nettleton@gmail.com> Signed-off-by: Fabio Estevam <fabio.estevam@freescale.com> Reviewed-by: Tom Rini <trini@konsulko.com> Tested-by: Tom Rini <trini@konsulko.com> Signed-off-by: Rabeeh Khoury <rabeeh@solid-run.com> Signed-off-by: Fabio Estevam <fabio.estevam@freescale.com> Reviewed-by: Tom Rini <trini@konsulko.com> Tested-by: Vagrant Cascadian <vagrant@aikidev.net>
2015-04-27mx6cuboxi: Load the correct 'fdtfile' variableFabio Estevam
Instead of hardcoding the 'fdtfile' variable, let's detect the SoC and board variant on the fly and change the dtb name. Based on the scheme done on am335x board. Signed-off-by: Fabio Estevam <fabio.estevam@freescale.com> Tested-By: Vagrant Cascadian <vagrant@debian.org> Reviewed-by: Tom Rini <trini@konsulko.com>
2015-04-27mx6cuboxi: Differentiate Cubox-i and HummingboardFabio Estevam
Introduce is_hummingboard() function that reads GPIOs that can distinguish between Cubox-i and Hummingboard. Print the board name accordingly. Based on a patch from Rabeeh Khoury. Signed-off-by: Rabeeh Khoury <rabeeh@solid-run.com> Signed-off-by: Fabio Estevam <fabio.estevam@freescale.com> Reviewed-by: Tom Rini <trini@konsulko.com>
2015-04-27mx6cuboxi: Introduce multi-SoC supportFabio Estevam
Cubox-i and Hummingboard support several MX6 SoCs: mx6solo, mx6dual-lite, mx6dual and mx6quad. Add support for the different SoC/memory sizes combinations. DDR initialization values were extracted from Solid-run internal U-boot. Tested on a CuBox-i4Pro, HummingBoard-i2eX and HummingBoard-i1. Signed-off-by: Rabeeh Khoury <rabeeh@solid-run.com> Signed-off-by: Fabio Estevam <fabio.estevam@freescale.com> Reviewed-by: Tom Rini <trini@konsulko.com>
2015-04-27mx6cuboxi: Prepare for multi SoC supportFabio Estevam
Cubox-i and Hummingboard support several MX6 SoCs: mx6solo, mx6dual-lite, mx6dual and mx6quad. Use IOMUX_PADS() macro in order to prepare for the multi-SoC support. Also pass 'MX6QDL' in the defconfig to indicate it. Signed-off-by: Fabio Estevam <fabio.estevam@freescale.com> Reviewed-by: Tom Rini <trini@konsulko.com>
2015-04-27mx6cuboxi: Fix the defconfig nameFabio Estevam
The correct name of the defconfig file is 'mx6cuboxi_defconfig'. Signed-off-by: Fabio Estevam <fabio.estevam@freescale.com> Reviewed-by: Tom Rini <trini@konsulko.com>
2015-04-22mx6: Add initial SPL support for HummingBoard-i2eXFabio Estevam
Add the initial SPL support for HummingBoard-i2eX, which is based on a MX6 Dual. For more information about HummingBoard, please check: http://www.solid-run.com/products/hummingboard/ Based on the work from Jon Nettleton and Rabeeh Khoury. Signed-off-by: Fabio Estevam <fabio.estevam@freescale.com> Reviewed-by: Tom Rini <trini@konsulko.com>
2014-12-01arm: mx6: Change defines ENET_xxMHz to ENET_xxMHZ (no CamelCase)Stefan Roese
As checkpatch complaines about these camel-case defines, lets change them to only use upper-case characters. Signed-off-by: Stefan Roese <sr@denx.de> Acked-by: Heiko Schocher <hs@denx.de> Cc: Fabio Estevam <fabio.estevam@freescale.com> Cc: Jon Nettleton <jon.nettleton@gmail.com> Cc: Stefano Babic <sbabic@denx.de> Reviewed-by: Fabio Estevam <fabio.estevam@freescale.com>
2014-10-29kconfig: arm: introduce symbol for ARM CPUsGeorges Savoundararadj
This commit introduces a Kconfig symbol for each ARM CPU: CPU_ARM720T, CPU_ARM920T, CPU_ARM926EJS, CPU_ARM946ES, CPU_ARM1136, CPU_ARM1176, CPU_V7, CPU_PXA, CPU_SA1100. Also, it adds the CPU feature Kconfig symbol HAS_VBAR which is selected for CPU_ARM1176 and CPU_V7. For each target, the corresponding CPU is selected and the definition of SYS_CPU in the corresponding Kconfig file is removed. Also, it removes redundant "string" type in some Kconfig files. Signed-off-by: Georges Savoundararadj <savoundg@gmail.com> Acked-by: Albert ARIBAUD <albert.u.boot@aribaud.net> Cc: Masahiro Yamada <yamada.m@jp.panasonic.com>
2014-08-11Merge branch 'master' of git://git.denx.de/u-boot-armStefano Babic
Conflicts: boards.cfg Signed-off-by: Stefano Babic <sbabic@denx.de>
2014-07-23mx6: Remove duplication of iomuxc structureFabio Estevam
There is no need to keep iomuxc_base_regs structure as it serves the exact same purpose of the iomuxc structure, which is to provide access to the GPR registers. The additional fields of iomuxc_base_regs are not used. Other advantage of 'iomuxc' is that it has a shorter name and the variable declarations can fit into a single line. So remove iomuxc_base_regs structure and use iomuxc instead. Signed-off-by: Fabio Estevam <fabio.estevam@freescale.com> Acked-by: Stefano Babic <sbabic@denx.de>
2014-02-11hummingboard: Return from cpu_eth_init() directlyFabio Estevam
There is no need to print an error message when cpu_eth_init() fails because net/eth.c already prints it. In order to simplify the code, just return the value from cpu_eth_init(bis) directly. Signed-off-by: Fabio Estevam <fabio.estevam@freescale.com>
2014-01-15mx6: Add initial support for the Hummingboard soloFabio Estevam
SolidRun has designed the Hummingboard board based on mx6q/dl/solo. Add the initial support for the mx6 solo variant. More information about this hardware can be found at: http://imx.solid-run.com/wiki/index.php?title=Carrier-One_Hardware (Carrier-One was the previous name of Hummingboard). Based on the work from Jon Nettleton <jon.nettleton@gmail.com>. Signed-off-by: Jon Nettleton <jon.nettleton@gmail.com> Signed-off-by: Fabio Estevam <fabio.estevam@freescale.com>
