path: root/board/solidrun/hummingboard
2014-02-11hummingboard: Return from cpu_eth_init() directlyFabio Estevam
There is no need to print an error message when cpu_eth_init() fails because net/eth.c already prints it. In order to simplify the code, just return the value from cpu_eth_init(bis) directly. Signed-off-by: Fabio Estevam <fabio.estevam@freescale.com>
2014-01-15mx6: Add initial support for the Hummingboard soloFabio Estevam
SolidRun has designed the Hummingboard board based on mx6q/dl/solo. Add the initial support for the mx6 solo variant. More information about this hardware can be found at: http://imx.solid-run.com/wiki/index.php?title=Carrier-One_Hardware (Carrier-One was the previous name of Hummingboard). Based on the work from Jon Nettleton <jon.nettleton@gmail.com>. Signed-off-by: Jon Nettleton <jon.nettleton@gmail.com> Signed-off-by: Fabio Estevam <fabio.estevam@freescale.com>
