path: root/board/socrates
2009-09-24ppc/85xx: Clean up use of LAWAR definesKumar Gala
On 85xx platforms we shouldn't be using any LAWAR_* defines but using the LAW_* ones provided by fsl-law.h. Rename any such uses and limit the LAWAR_ to the 83xx platform as the only user so we will get compile errors in the future. Signed-off-by: Kumar Gala <galak@kernel.crashing.org>
2009-08-2885xx: Move to a common linker scriptKumar Gala
There are really no differences between all the 85xx linker scripts so we can just move to a single common one. Board code is still able to override the common one if need be. Signed-off-by: Kumar Gala <galak@kernel.crashing.org>
2009-06-04Redundant Environment: protect full sector sizeWolfgang Denk
Several boards used different ways to specify the size of the protected area when enabling flash write protection for the sectors holding the environment variables: some used CONFIG_ENV_SIZE and CONFIG_ENV_SIZE_REDUND, some used CONFIG_ENV_SECT_SIZE, and some even a mix of both for the "normal" and the "redundant" areas. Normally, this makes no difference at all. However, things are different when you have to deal with boards that can come with different types of flash chips, which may have different sector sizes. Here we may have to chose CONFIG_ENV_SECT_SIZE such that it fits the biggest sector size, which may include several sectors on boards using the smaller sector flash types. In such a case, using CONFIG_ENV_SIZE or CONFIG_ENV_SIZE_REDUND to enable the protection may lead to the case that only the first of these sectors get protected, while the following ones aren't. This is no real problem, but it can be confusing for the user - especially on boards that use CONFIG_ENV_SECT_SIZE to protect the "normal" areas, while using CONFIG_ENV_SIZE_REDUND for the "redundant" area. To avoid such inconsistencies, I changed all sucn boards that I found to consistently use CONFIG_ENV_SECT_SIZE for protection. This should not cause any functional changes to the code. Signed-off-by: Wolfgang Denk <wd@denx.de> Cc: Paul Ruhland Cc: Pantelis Antoniou <panto@intracom.gr> Cc: Stefan Roese <sr@denx.de> Cc: Gary Jennejohn <garyj@denx.de> Cc: Dave Ellis <DGE@sixnetio.com> Acked-by: Stefan Roese <sr@denx.de>
2008-12-19mpc8xxx: LCRR[CLKDIV] is sometimes five bitsTrent Piepho
On newer CPUs, 8536, 8572, and 8610, the CLKDIV field of LCRR is five bits instead of four. In order to avoid an ifdef, LCRR_CLKDIV is set to 0x1f on all systems. It should be safe as the fifth bit was defined as reserved and set to 0. Code that was using a hard coded 0x0f is changed to use LCRR_CLKDIV. Signed-off-by: Trent Piepho <tpiepho@freescale.com> Acked-by: Kumar Gala <galak@kernel.crashing.org> Acked-by: Jon Loeliger <jdl@freescale.com>
2008-12-0385xx: socrates: fix DDR SDRAM tlb entry configurationAnatolij Gustschin
since commit be0bd8234b9777ecd63c4c686f72af070d886517 tlb entry for socrates DDR SDRAM will be reconfigured by setup_ddr_tlbs() from initdram() causing an inconsistency with previously configured DDR SDRAM tlb entry from tlb_table: socrates>l2cam 7 9 IDX PID EPN SIZE V TS RPN U0-U3 WIMGE UUUSSS 7 : 00 00000000 256MB V 0 -> 0_00000000 0000 -I-G- ---RWX 8 : 00 00000000 256MB V 0 -> 0_00000000 0000 ----- ---RWX 9 : 00 10000000 256MB V 0 -> 0_10000000 0000 ----- ---RWX This patch makes the presence of the DDR SDRAM tlb entry in the tlb_table dependent on CONFIG_SPD_EEPROM to avoid this inconsistency. Signed-off-by: Anatolij Gustschin <agust@denx.de> Acked-by: Andy Fleming <afleming@freescale.com>
2008-10-18Pass dimm parameters to populate populate controller optionsHaiying Wang
Because some dimm parameters like n_ranks needs to be used with the board frequency to choose the board parameters like clk_adjust etc. in the board_specific_paramesters table of the board ddr file, we need to pass the dimm parameters to the board file. * move ddr dimm parameters header file from /cpu to /include directory. * add ddr dimm parameters to populate board specific options. * Fix fsl_ddr_board_options() for all the 8xxx boards which call this function. Signed-off-by: Haiying Wang <Haiying.Wang@freescale.com>
2008-09-22socrates: fix crash after relocationAnatolij Gustschin
Currently U-Boot crashes after relocation to RAM. Changing the CPO value of the DDR SDRAM TIMING_CFG_2 register to READ_LAT + 1 (to the value it was before conversion of socrates to new DDR code) fixes the problem. Signed-off-by: Anatolij Gustschin <agust@denx.de>
2008-09-1385xx: socrates: autoprobe Lime chipu-boot@bugs.denx.de
This patch is an attempt to implement autoprobing for the Lime presence on the bus. Configure GPCM for Lime CS2 and try to access chip ID registers. Second read atempt delivers register values if the chip is present. Signed-off-by: Anatolij Gustschin <agust@denx.de>
2008-09-0985xx: socrates: Enable Lime support.Anatolij Gustschin
This patch adds Lime GDC support together with support for the PWM backlight control through the w83782d chip. The reset pin of the latter is attached to GPIO, so we need to reset it in early_board_init_r. Signed-off-by: Anatolij Gustschin <agust@denx.de>
2008-09-0985xx: Socrates: Major code update.Detlev Zundel
- Update the local bus ranges in the FDT for Linux for the various devices connected to the local bus via chip-select. - Set the LCRR_DBYP bit in the LCRR for local bus frequencies lower than 66 MHz and uses I/O accessor functions consequently. - UPM data update. - Update of default environment and configuration. Use I2C multibus as we do have two I2C buses. Also enable sdram and ext2 commands. Signed-off-by: Wolfgang Grandegger <wg@grandegger.com> Signed-off-by: Sergei Poselenov <sposelenov@emcraft.com> Signed-off-by: Detlev Zundel <dzu@denx.de>
2008-08-27FSL DDR: Convert socrates to new DDR code.Kumar Gala
2008-08-13socrates: Update NAND driver to new API.Scott Wood
Also, fix some minor formatting issues, and simplify the handling of "state" for writes. Signed-off-by: Scott Wood <scottwood@freescale.com>
2008-06-28Coding Style CleanupWolfgang Denk
2008-06-1185xx/86xx: Move to dynamic mgmt of LAWsKumar Gala
With the new LAW interface (set_next_law) we can move to letting the system allocate which LAWs are used for what purpose. This makes life a bit easier going forward with the new DDR code. Signed-off-by: Kumar Gala <galak@kernel.crashing.org> Signed-off-by: Andy Fleming <afleming@freescale.com> Acked-by: Jon Loeliger <jdl@freescale.com> Acked-by: Becky Bruce <becky.bruce@freescale.com>
2008-06-11Socrates: Added FPGA base address update in FDT.Sergei Poselenov
2008-06-11Socrates: NAND support added. Changed the U-Boot base address andSergei Poselenov
2008-06-11Socrates: added missed file with UPMA configuration data.Sergei Poselenov
Signed-of-by: Sergei Poselenov <sposelenov@emcraft.com>
2008-06-11Socrates: Added FPGA mapping. LAWs and TLBs cleanup.Sergei Poselenov
2008-06-10socrates: Fix PCI clk fix patchAndy Fleming
The submitted patch seems to have been more up-to-date, but an older patch was already in the repository. This patch encompasses the differences Taken entirely from Sergei Poselenov <sposelenov@emcraft.com> Signed-off-by: Andy Fleming <afleming@freescale.com>
2008-05-27Socrates: Fix PCI bus frequency reportSergei Poselenov
2008-05-20socrates: changes to support FDTSergei Poselenov
Signed-off-by: Sergei Poselenov <sposelenov@emcraft.com> Signed-off-by: Wolfgang Denk <wd@denx.de>
2008-05-20Initial support for "Socrates" boardSergei Poselenov
