path: root/board/socrates
2016-06-03mtd: nand: Add+use mtd_to/from_nand and nand_get/set_controller_dataScott Wood
These functions are part of the Linux 4.6 sync. They are being added before the main sync patch in order to make it easier to address the issue across all NAND drivers (many/most of which do not closely track their Linux counterparts) separately from other merge issues. Signed-off-by: Scott Wood <oss@buserror.net>
2016-05-27Delete tests of CONFIG_OF_LIBFDT when testing CONFIG_OF_BOARD_SETUPRobert P. J. Day
Since CONFIG_OF_BOARD_SETUP depends on CONFIG_OF_LIBFDT: config OF_BOARD_SETUP bool "Set up board-specific details in device tree before boot" depends on OF_LIBFDT ... remove superfluous tests of CONFIG_OF_LIBFDT when testing for CONFIG_OF_BOARD_SETUP. Signed-off-by: Robert P. J. Day <rpjday@crashcourse.ca> [trini: Typo fix: s/ifdefi/ifdef/] Signed-off-by: Tom Rini <trini@konsulko.com>
2016-01-19Add more SPDX-License-Identifier tagsTom Rini
In a number of places we had wordings of the GPL (or LGPL in a few cases) license text that were split in such a way that it wasn't caught previously. Convert all of these to the correct SPDX-License-Identifier tag. Signed-off-by: Tom Rini <trini@konsulko.com>
2015-03-30nand: Remove CONFIG_MTD_NAND_VERIFY_WRITEPeter Tyser
The CONFIG_MTD_NAND_VERIFY_WRITE has been removed from Linux for some time and a more generic method of NAND verification now exists in U-Boot. Signed-off-by: Peter Tyser <ptyser@xes-inc.com> Tested-by: Heiko Schocher <hs@denx.de> Acked-by: Heiko Schocher <hs@denx.de>
2014-11-21fdt: Allow ft_board_setup() to report failureSimon Glass
This function can fail if the device tree runs out of space. Rather than silently booting with an incomplete device tree, allow the failure to be detected. Unfortunately this involves changing a lot of places in the code. I have not changed behvaiour to return an error where one is not currently returned, to avoid unexpected breakage. Eventually it would be nice to allow boards to register functions to be called to update the device tree. This would avoid all the many functions to do this. However it's not clear yet if this should be done using driver model or with a linker list. This work is left for later. Signed-off-by: Simon Glass <sjg@chromium.org> Acked-by: Anatolij Gustschin <agust@denx.de>
2014-09-24MAINTAINERS: comment out blank M: fieldMasahiro Yamada
Since commit ddaf5c8f3030050fcd356a1e49e3ee8f8f52c6d4 (patman: RunPipe() should not pipe stdout/stderr unless asked), Patman spits lots of "Invalid MAINTAINERS address: '-'" error messages for patches with global changes. It takes too long for Patman to process them. Anyway, "M: -" does not carry any important information. Rather, it is just like a place holder in case of assigning a new board maintainer. Let's comment out. This commit can be reproduced by the following command: find . -name MAINTAINERS | xargs sed -i -e '/^M:[[:blank:]]*-$/s/^/#/' Signed-off-by: Masahiro Yamada <yamada.m@jp.panasonic.com>
2014-08-25mtd, ubi, ubifs: resync with Linux-3.14Heiko Schocher
resync ubi subsystem with linux: commit 455c6fdbd219161bd09b1165f11699d6d73de11c Author: Linus Torvalds <torvalds@linux-foundation.org> Date: Sun Mar 30 20:40:15 2014 -0700 Linux 3.14 A nice side effect of this, is we introduce UBI Fastmap support to U-Boot. Signed-off-by: Heiko Schocher <hs@denx.de> Signed-off-by: Tom Rini <trini@ti.com> Cc: Marek Vasut <marex@denx.de> Cc: Sergey Lapin <slapin@ossfans.org> Cc: Scott Wood <scottwood@freescale.com> Cc: Joerg Krause <jkrause@posteo.de>
2013-11-25Driver/DDR: combine ccsr_ddr for 83xx, 85xx and 86xxYork Sun
Fix ccsr_ddr structure to avoid using typedef. Combine DDR2 and DDR3 structure for 83xx, 85xx and 86xx. Signed-off-by: York Sun <yorksun@freescale.com>
2013-11-25Driver/DDR: Moving Freescale DDR driver to a common driverYork Sun
Freescale DDR driver has been used for mpc83xx, mpc85xx, mpc86xx SoCs. The similar DDR controllers will be used for ARM-based SoCs. Signed-off-by: York Sun <yorksun@freescale.com>
2013-08-20powerpc: Fix CamelCase checkpatch warningsPrabhakar Kushwaha
85xx, 86xx PowerPC folders have code variables with CamelCase naming conventions. because of this code checkpatch script generates "WARNING: Avoid CamelCase". Convert variables name to normal naming convention and modify board, driver files with updated the new structure. Signed-off-by: Prabhakar Kushwaha <prabhakar@freescale.com> Acked-by: York Sun <yorksun@freescale.com>
2012-11-278xxx: Change all 8*xx_DDR addresses to 8xxxAndy Fleming
There were a number of shared files that were using CONFIG_SYS_MPC85xx_DDR_ADDR, or CONFIG_SYS_MPC86xx_DDR_ADDR, and several variants (DDR2, DDR3). A recent patchset added 85xx-specific ones to code which was used by 86xx systems. After reviewing places where these constants were used, and noting that the type definitions of the pointers assigned to point to those addresses were the same, the cleanest approach to fixing this problem was to unify the namespace for the 85xx, 83xx, and 86xx DDR address definitions. This patch does: s/CONFIG_SYS_MPC8.xx_DDR/CONFIG_SYS_MPC8xxx_DDR/g All 85xx, 86xx, and 83xx have been built with this change. Signed-off-by: Andy Fleming <afleming@freescale.com> Tested-by: Andy Fleming <afleming@freescale.com> Acked-by: Kim Phillips <kim.phillips@freescale.com>
2011-10-03PPC: Fix socrates NAND problemMarek Vasut
nand.c:36: error: static declaration of 'nand_read_buf' follows non-static declaration /home/marex/u-boot/include/nand.h:139: error: previous declaration of 'nand_read_buf' was here Signed-off-by: Marek Vasut <marek.vasut@gmail.com> Cc: Scott Wood <scottwood@freescale.com> Signed-off-by: Scott Wood <scottwood@freescale.com>
2011-05-12Fix incorrect use of getenv() before relocationWolfgang Denk
A large number of boards incorrectly used getenv() in their board init code running before relocation. In some cases this caused U-Boot to hang when certain environment variables grew too long. Fix the code to use getenv_r(). Signed-off-by: Wolfgang Denk <wd@denx.de> Cc: Stefan Roese <sr@denx.de> Cc: The LEOX team <team@leox.org> Cc: Michael Schwingen <michael@schwingen.org> Cc: Georg Schardt <schardt@team-ctech.de> Cc: Werner Pfister <Pfister_Werner@intercontrol.de> Cc: Dirk Eibach <eibach@gdsys.de> Cc: Peter De Schrijver <p2@mind.be> Cc: John Zhan <zhanz@sinovee.com> Cc: Rishi Bhattacharya <rishi@ti.com> Cc: Peter Tyser <ptyser@xes-inc.com>
2011-04-04powerpc/8xxx: Refactor fsl_ddr_get_spd into common code from boardKumar Gala
Move fsl_ddr_get_spd into common mpc8xxx/ddr/main.c as most boards pretty much do the same thing. The only variations are in how many controllers or DIMMs per controller exist. To make this work we standardize on the names of the SPD_EEPROM_ADDRESS defines based on the use case of the board. We allow boards to override get_spd to either do board specific fixups to the SPD data or deal with any unique behavior of how the SPD eeproms are wired up. Signed-off-by: Kumar Gala <galak@kernel.crashing.org>
2011-04-04powerpc/8xxx: Replace fsl_ddr_get_mem_data_rate with get_ddr_freq()Kumar Gala
Every 85xx board implements fsl_ddr_get_mem_data_rate via get_ddr_freq() and every 86xx board uses get_bus_freq(). If implement get_ddr_freq() as a static inline to call get_bus_freq() we can remove fsl_ddr_get_mem_data_rate altogether and just call get_ddr_freq() directly. Signed-off-by: Kumar Gala <galak@kernel.crashing.org>
2011-01-14mpc85xx boards: initdram() cleanup/bugfixBecky Bruce
Correct initdram to use phys_size_t to represent the size of dram; instead of changing this all over the place, and correcting all the other random errors I've noticed, create a common initdram that is used by all non-corenet 85xx parts. Most of the initdram() functions were identical, with 2 common differences: 1) DDR tlbs for the fixed_sdram case were set up in initdram() on some boards, and were part of the tlb_table on others. I have changed them all over to the initdram() method - we shouldn't be accessing dram before this point so they don't need to be done sooner, and this seems cleaner. 2) Parts that require the DDR11 erratum workaround had different implementations - I have adopted the version from the Freescale errata document. It also looks like some of the versions were buggy, and, depending on timing, could have resulted in the DDR controller being disabled. This seems bad. The xpedite boards had a common/fsl_8xxx_ddr.c; with this change only the 517 board uses this so I have moved the ddr code into that board's directory in xpedite517x.c Signed-off-by: Becky Bruce <beckyb@kernel.crashing.org> Tested-by: Paul Gortmaker <paul.gortmaker@windriver.com> Signed-off-by: Kumar Gala <galak@kernel.crashing.org>
2011-01-14socrates: rename sdram_setup fixed_sdram()Becky Bruce
This will help us go to a fixed initdram() for all 85xx boards going forward. sdram_setup() had an argument that it didn't need, since the value was #defined. Signed-off-by: Becky Bruce <beckyb@kernel.crashing.org> Signed-off-by: Kumar Gala <galak@kernel.crashing.org>
2010-09-19socrates: adjust TEXT_BASE to increase U-Boot image sizeWolfgang Denk
We need more room for the U-Boot image. Shift TEXT_BASE as needed. Signed-off-by: Wolfgang Denk <wd@denx.de>
2010-07-1683xx/85xx/86xx: LBC register cleanupBecky Bruce
Currently, 83xx, 86xx, and 85xx have a lot of duplicated code dedicated to defining and manipulating the LBC registers. Merge this into a single spot. To do this, we have to decide on a common name for the data structure that holds the lbc registers - it will now be known as fsl_lbc_t, and we adopt a common name for the immap layouts that include the lbc - this was previously known as either im_lbc or lbus; use the former. In addition, create accessors for the BR/OR regs that use in/out_be32 and use those instead of the mismash of access methods currently in play. I have done a successful ppc build all and tested a board or two from each processor family. Signed-off-by: Becky Bruce <beckyb@kernel.crashing.org> Acked-by: Kim Phillips <kim.phillips@freescale.com> Signed-off-by: Kumar Gala <galak@kernel.crashing.org>
2009-10-31video: mb862xx: improve board-specific Lime configurationWolfgang Grandegger
To avoid board-specific code accessing the mb862xx registers directly, the public function mb862xx_probe() has been introduced. Furthermore, the "Change of Clock Frequency" and "Set Memory I/F Mode" registers are now defined by CONFIG_SYS_MB862xx_CCF and CONFIG_SYS_MB862xx__MMR, respectively. The BSPs for the socrates and lwmon5 boards have been adapted accordingly. Signed-off-by: Wolfgang Grandegger <wg@denx.de>
2009-09-24ppc/85xx: Clean up use of LAWAR definesKumar Gala
On 85xx platforms we shouldn't be using any LAWAR_* defines but using the LAW_* ones provided by fsl-law.h. Rename any such uses and limit the LAWAR_ to the 83xx platform as the only user so we will get compile errors in the future. Signed-off-by: Kumar Gala <galak@kernel.crashing.org>
2009-08-2885xx: Move to a common linker scriptKumar Gala
There are really no differences between all the 85xx linker scripts so we can just move to a single common one. Board code is still able to override the common one if need be. Signed-off-by: Kumar Gala <galak@kernel.crashing.org>
2009-06-04Redundant Environment: protect full sector sizeWolfgang Denk
Several boards used different ways to specify the size of the protected area when enabling flash write protection for the sectors holding the environment variables: some used CONFIG_ENV_SIZE and CONFIG_ENV_SIZE_REDUND, some used CONFIG_ENV_SECT_SIZE, and some even a mix of both for the "normal" and the "redundant" areas. Normally, this makes no difference at all. However, things are different when you have to deal with boards that can come with different types of flash chips, which may have different sector sizes. Here we may have to chose CONFIG_ENV_SECT_SIZE such that it fits the biggest sector size, which may include several sectors on boards using the smaller sector flash types. In such a case, using CONFIG_ENV_SIZE or CONFIG_ENV_SIZE_REDUND to enable the protection may lead to the case that only the first of these sectors get protected, while the following ones aren't. This is no real problem, but it can be confusing for the user - especially on boards that use CONFIG_ENV_SECT_SIZE to protect the "normal" areas, while using CONFIG_ENV_SIZE_REDUND for the "redundant" area. To avoid such inconsistencies, I changed all sucn boards that I found to consistently use CONFIG_ENV_SECT_SIZE for protection. This should not cause any functional changes to the code. Signed-off-by: Wolfgang Denk <wd@denx.de> Cc: Paul Ruhland Cc: Pantelis Antoniou <panto@intracom.gr> Cc: Stefan Roese <sr@denx.de> Cc: Gary Jennejohn <garyj@denx.de> Cc: Dave Ellis <DGE@sixnetio.com> Acked-by: Stefan Roese <sr@denx.de>
2008-12-19mpc8xxx: LCRR[CLKDIV] is sometimes five bitsTrent Piepho
On newer CPUs, 8536, 8572, and 8610, the CLKDIV field of LCRR is five bits instead of four. In order to avoid an ifdef, LCRR_CLKDIV is set to 0x1f on all systems. It should be safe as the fifth bit was defined as reserved and set to 0. Code that was using a hard coded 0x0f is changed to use LCRR_CLKDIV. Signed-off-by: Trent Piepho <tpiepho@freescale.com> Acked-by: Kumar Gala <galak@kernel.crashing.org> Acked-by: Jon Loeliger <jdl@freescale.com>
2008-12-0385xx: socrates: fix DDR SDRAM tlb entry configurationAnatolij Gustschin
since commit be0bd8234b9777ecd63c4c686f72af070d886517 tlb entry for socrates DDR SDRAM will be reconfigured by setup_ddr_tlbs() from initdram() causing an inconsistency with previously configured DDR SDRAM tlb entry from tlb_table: socrates>l2cam 7 9 IDX PID EPN SIZE V TS RPN U0-U3 WIMGE UUUSSS 7 : 00 00000000 256MB V 0 -> 0_00000000 0000 -I-G- ---RWX 8 : 00 00000000 256MB V 0 -> 0_00000000 0000 ----- ---RWX 9 : 00 10000000 256MB V 0 -> 0_10000000 0000 ----- ---RWX This patch makes the presence of the DDR SDRAM tlb entry in the tlb_table dependent on CONFIG_SPD_EEPROM to avoid this inconsistency. Signed-off-by: Anatolij Gustschin <agust@denx.de> Acked-by: Andy Fleming <afleming@freescale.com>
2008-10-18Pass dimm parameters to populate populate controller optionsHaiying Wang
Because some dimm parameters like n_ranks needs to be used with the board frequency to choose the board parameters like clk_adjust etc. in the board_specific_paramesters table of the board ddr file, we need to pass the dimm parameters to the board file. * move ddr dimm parameters header file from /cpu to /include directory. * add ddr dimm parameters to populate board specific options. * Fix fsl_ddr_board_options() for all the 8xxx boards which call this function. Signed-off-by: Haiying Wang <Haiying.Wang@freescale.com>
2008-09-22socrates: fix crash after relocationAnatolij Gustschin
Currently U-Boot crashes after relocation to RAM. Changing the CPO value of the DDR SDRAM TIMING_CFG_2 register to READ_LAT + 1 (to the value it was before conversion of socrates to new DDR code) fixes the problem. Signed-off-by: Anatolij Gustschin <agust@denx.de>
2008-09-1385xx: socrates: autoprobe Lime chipu-boot@bugs.denx.de
This patch is an attempt to implement autoprobing for the Lime presence on the bus. Configure GPCM for Lime CS2 and try to access chip ID registers. Second read atempt delivers register values if the chip is present. Signed-off-by: Anatolij Gustschin <agust@denx.de>
2008-09-0985xx: socrates: Enable Lime support.Anatolij Gustschin
This patch adds Lime GDC support together with support for the PWM backlight control through the w83782d chip. The reset pin of the latter is attached to GPIO, so we need to reset it in early_board_init_r. Signed-off-by: Anatolij Gustschin <agust@denx.de>
2008-09-0985xx: Socrates: Major code update.Detlev Zundel
- Update the local bus ranges in the FDT for Linux for the various devices connected to the local bus via chip-select. - Set the LCRR_DBYP bit in the LCRR for local bus frequencies lower than 66 MHz and uses I/O accessor functions consequently. - UPM data update. - Update of default environment and configuration. Use I2C multibus as we do have two I2C buses. Also enable sdram and ext2 commands. Signed-off-by: Wolfgang Grandegger <wg@grandegger.com> Signed-off-by: Sergei Poselenov <sposelenov@emcraft.com> Signed-off-by: Detlev Zundel <dzu@denx.de>
2008-08-27FSL DDR: Convert socrates to new DDR code.Kumar Gala
2008-08-13socrates: Update NAND driver to new API.Scott Wood
Also, fix some minor formatting issues, and simplify the handling of "state" for writes. Signed-off-by: Scott Wood <scottwood@freescale.com>
2008-06-28Coding Style CleanupWolfgang Denk
2008-06-1185xx/86xx: Move to dynamic mgmt of LAWsKumar Gala
With the new LAW interface (set_next_law) we can move to letting the system allocate which LAWs are used for what purpose. This makes life a bit easier going forward with the new DDR code. Signed-off-by: Kumar Gala <galak@kernel.crashing.org> Signed-off-by: Andy Fleming <afleming@freescale.com> Acked-by: Jon Loeliger <jdl@freescale.com> Acked-by: Becky Bruce <becky.bruce@freescale.com>
