path: root/board/socrates/upm_table.h
2008-09-0985xx: socrates: Enable Lime support.Anatolij Gustschin
This patch adds Lime GDC support together with support for the PWM backlight control through the w83782d chip. The reset pin of the latter is attached to GPIO, so we need to reset it in early_board_init_r. Signed-off-by: Anatolij Gustschin <agust@denx.de>
2008-09-0985xx: Socrates: Major code update.Detlev Zundel
- Update the local bus ranges in the FDT for Linux for the various devices connected to the local bus via chip-select. - Set the LCRR_DBYP bit in the LCRR for local bus frequencies lower than 66 MHz and uses I/O accessor functions consequently. - UPM data update. - Update of default environment and configuration. Use I2C multibus as we do have two I2C buses. Also enable sdram and ext2 commands. Signed-off-by: Wolfgang Grandegger <wg@grandegger.com> Signed-off-by: Sergei Poselenov <sposelenov@emcraft.com> Signed-off-by: Detlev Zundel <dzu@denx.de>
2008-06-28Coding Style CleanupWolfgang Denk
2008-06-11Socrates: added missed file with UPMA configuration data.Sergei Poselenov
Signed-of-by: Sergei Poselenov <sposelenov@emcraft.com>
