path: root/board/socrates/law.c
2009-09-24ppc/85xx: Clean up use of LAWAR definesKumar Gala
On 85xx platforms we shouldn't be using any LAWAR_* defines but using the LAW_* ones provided by fsl-law.h. Rename any such uses and limit the LAWAR_ to the 83xx platform as the only user so we will get compile errors in the future. Signed-off-by: Kumar Gala <galak@kernel.crashing.org>
2008-09-0985xx: socrates: Enable Lime support.Anatolij Gustschin
This patch adds Lime GDC support together with support for the PWM backlight control through the w83782d chip. The reset pin of the latter is attached to GPIO, so we need to reset it in early_board_init_r. Signed-off-by: Anatolij Gustschin <agust@denx.de>
2008-06-1185xx/86xx: Move to dynamic mgmt of LAWsKumar Gala
With the new LAW interface (set_next_law) we can move to letting the system allocate which LAWs are used for what purpose. This makes life a bit easier going forward with the new DDR code. Signed-off-by: Kumar Gala <galak@kernel.crashing.org> Signed-off-by: Andy Fleming <afleming@freescale.com> Acked-by: Jon Loeliger <jdl@freescale.com> Acked-by: Becky Bruce <becky.bruce@freescale.com>
2008-06-11Socrates: Added FPGA mapping. LAWs and TLBs cleanup.Sergei Poselenov
Signed-off-by: Sergei Poselenov <sposelenov@emcraft.com>
2008-05-20Initial support for "Socrates" boardSergei Poselenov
