2009-01-29 | move Samsung's board to board/samsung | Jean-Christophe PLAGNIOL-VILLARD | |
Signed-off-by: Jean-Christophe PLAGNIOL-VILLARD <plagnioj@jcrosoft.com> | |||
2004-02-08 | Patch by Anders Larsen, 09 Jan 2004: | wdenk | |
ARM memory layout fixes: the abort-stack is now set up in the correct RAM area, and the BSS is zeroed out as it should be. Furthermore, the magic variables 'armboot_end' and 'armboot_end_data' of the linker scripts are replaced by '__bss_start' and '_end', resp., which is a further step to eliminate unnecessary differences between the implementation of the CPU architectures. | |||
2002-11-03 | Initial revision | wdenk | |
