path: root/board/sixnet
2009-06-04Redundant Environment: protect full sector sizeWolfgang Denk
Several boards used different ways to specify the size of the protected area when enabling flash write protection for the sectors holding the environment variables: some used CONFIG_ENV_SIZE and CONFIG_ENV_SIZE_REDUND, some used CONFIG_ENV_SECT_SIZE, and some even a mix of both for the "normal" and the "redundant" areas. Normally, this makes no difference at all. However, things are different when you have to deal with boards that can come with different types of flash chips, which may have different sector sizes. Here we may have to chose CONFIG_ENV_SECT_SIZE such that it fits the biggest sector size, which may include several sectors on boards using the smaller sector flash types. In such a case, using CONFIG_ENV_SIZE or CONFIG_ENV_SIZE_REDUND to enable the protection may lead to the case that only the first of these sectors get protected, while the following ones aren't. This is no real problem, but it can be confusing for the user - especially on boards that use CONFIG_ENV_SECT_SIZE to protect the "normal" areas, while using CONFIG_ENV_SIZE_REDUND for the "redundant" area. To avoid such inconsistencies, I changed all sucn boards that I found to consistently use CONFIG_ENV_SECT_SIZE for protection. This should not cause any functional changes to the code. Signed-off-by: Wolfgang Denk <wd@denx.de> Cc: Paul Ruhland Cc: Pantelis Antoniou <panto@intracom.gr> Cc: Stefan Roese <sr@denx.de> Cc: Gary Jennejohn <garyj@denx.de> Cc: Dave Ellis <DGE@sixnetio.com> Acked-by: Stefan Roese <sr@denx.de>
2009-03-27ppc: cleanup compiler errors/warningsHeiko Schocher
Current u-boot top of tree builds with warnings/errors for the following boards: ads5121 cpci5200 mecp5200 v38b IAD210 MBX MBX860T NX823 RPXClassic debris PN62 following patch solves this. Signed-off-by: Heiko Schocher <hs@denx.de> Acked-by: Mike Frysinger <vapier@gentoo.org>
2009-03-20boards: get mac address from environmentMike Frysinger
The boards that get converted here to use the environment for the mac address rather than global data: debris mgcoge mgsuvd muas3001 netstal pn62 sixnet vcma9 xilinx (the ones that use xilinx_enet) Signed-off-by: Mike Frysinger <vapier@gentoo.org> CC: Ben Warren <biggerbadderben@gmail.com> CC: Sangmoon Kim <dogoil@etinsys.com> CC: Heiko Schocher <hs@denx.de> CC: David Mueller <d.mueller@elsoft.ch> CC: Niklaus Giger <niklaus.giger@netstal.com> CC: Wolfgang Grandegger <wg@denx.de> CC: Dave Ellis <DGE@sixnetio.com> CC: Ricardo Ribalda <ricardo.ribalda@uam.es>
2007-07-10board/[j-z]*: Remove lingering references to CFG_CMD_* symbols.Jon Loeliger
2007-07-09board/[q-z]*: Remove obsolete references to CONFIG_COMMANDSJon Loeliger
2007-07-04board/[k-z]*: Augment CONFIG_COMMANDS tests with defined(CONFIG_CMD_*).Jon Loeliger
2006-04-12Merge with /home/m8/git/u-bootWolfgang Denk
2006-04-08Fix JFFS2 support for legacy NAND driver.Marian Balakowicz
Some more NAND cleanup and small fixes.
2006-03-05Re-factoring the legacy NAND code (legacy NAND now only in board-specificBartlomiej Sieka
code and in SoC code). Boards using the old way have CFG_NAND_LEGACY and BOARDLIBS = drivers/nand_legacy/libnand_legacy.a added. Build breakage for NETTA.ERR and NETTA_ISDN - will go away when the new NAND support is implemented for these boards.
2005-08-08Add common (with Linux) MTD partition scheme and "mtdparts" commandWolfgang Denk
Old, obsolete and duplicated code was cleaned up and replace by the new partitioning method. There are two possible approaches now: * define a single, static partition * use mtdparts command line option and dynamic partitioning Default is static partitioning.
2003-09-16Code cleanupLABEL_2003_09_16_2310wdenk
2003-09-11* Patch by Gary Jennejohn, 11 Sep 2003:wdenk
- allow for longer timeouts for USB mass storage devices * Patch by Denis Peter, 11 Sep 2003: - fix USB data pointer assignment for bulk only transfer. - prevent to display erased directories in FAT filesystem. * Change output format for NAND flash - make it look like for other memory, too
2003-09-10* Patches by Denis Peter, 9 Sep 2003:U-Boot-0_4_8wdenk
add FAT support for IDE, SCSI and USB * Patches by Gleb Natapov, 2 Sep 2003: - cleanup of POST code for unsupported architectures - MPC824x locks way0 of data cache for use as initial RAM; this patch unlocks it after relocation to RAM and invalidates the locked entries. * Patch by Gleb Natapov, 30 Aug 2003: new I2C driver for mpc107 bridge. Now works from flash. * Patch by Dave Ellis, 11 Aug 2003: - JFFS2: fix typo in common/cmd_jffs2.c - JFFS2: fix CFG_JFFS2_SORT_FRAGMENTS option - JFFS2: remove node version 0 warning - JFFS2: accept JFFS2 PADDING nodes - SXNI855T: add AM29LV800 support - SXNI855T: move environment from EEPROM to flash - SXNI855T: boot from JFFS2 in NOR or NAND flash * Patch by Bill Hargen, 11 Aug 2003: fixes for I2C on MPC8240 - fix i2c_write routine - fix iprobe command - eliminates use of global variables, plus dead code, cleanup.
2003-05-31* Patch by Marc Singer, 29 May 2003:LABEL_2003_05_31_2115wdenk
Fixed rarp boot method for IA32 and other little-endian CPUs. * Patch by Marc Singer, 28 May 2003: Added port I/O commands. * Patch by Matthew McClintock, 28 May 2003 - cpu/mpc824x/start.S: fix relocation code when booting from RAM - minor patches for utx8245 * Patch by Daniel Engström, 28 May 2003: x86 update * Patch by Dave Ellis, 9 May 2003 + 27 May 2003: add nand flash support to SXNI855T configuration fix/extend nand flash support: - fix 'nand erase' command so does not erase bad blocks - fix 'nand write' command so does not write to bad blocks - fix nand_probe() so handles no flash detected properly - add doc/README.nand - add .jffs2 and .oob options to nand read/write - add 'nand bad' command to list bad blocks - add 'clean' option to 'nand erase' to write JFFS2 clean markers - make NAND read/write faster * Patch by Rune Torgersen, 23 May 2003: Update for MPC8266ADS board
2003-03-28Patches by Dave Ellis, 18 Mar 2003 for SXNI855T board:wdenk
- fix SRAM and SDRAM memory sizing - add status LED support - add MAC address for second (SCC1) ethernet port Update default environment for TQM8260 board
2002-03-02Initial revisionwdenk
2001-04-28Initial revisionwdenk
