path: root/board/silica
2015-02-24kconfig: remove unneeded dependency on !SPL_BUILDMasahiro Yamada
Now CONFIG_SPL_BUILD is not defined in Kconfig, so "!depends on SPL_BUILD" and "if !SPL_BUILD" are redundant. Signed-off-by: Masahiro Yamada <yamada.m@jp.panasonic.com>
2015-02-12dm: omap3: Move driver model CONFIGs to KconfigSimon Glass
Remove driver model CONFIGs from the board config headers and use Kconfig instead. Signed-off-by: Simon Glass <sjg@chromium.org>
2014-10-29kconfig: arm: introduce symbol for ARM CPUsGeorges Savoundararadj
This commit introduces a Kconfig symbol for each ARM CPU: CPU_ARM720T, CPU_ARM920T, CPU_ARM926EJS, CPU_ARM946ES, CPU_ARM1136, CPU_ARM1176, CPU_V7, CPU_PXA, CPU_SA1100. Also, it adds the CPU feature Kconfig symbol HAS_VBAR which is selected for CPU_ARM1176 and CPU_V7. For each target, the corresponding CPU is selected and the definition of SYS_CPU in the corresponding Kconfig file is removed. Also, it removes redundant "string" type in some Kconfig files. Signed-off-by: Georges Savoundararadj <savoundg@gmail.com> Acked-by: Albert ARIBAUD <albert.u.boot@aribaud.net> Cc: Masahiro Yamada <yamada.m@jp.panasonic.com>
2014-04-17am335x: Switch to CONFIG_SKIP_LOWLEVEL_INIT from guarding SPL or NOR_BOOTTom Rini
In the case of SPL or NOR_BOOT (no SPL involved) we need to include certain code in the build. Use !CONFIG_SKIP_LOWLEVEL_INIT rather than CONFIG_SPL_BUILD || CONFIG_NOR_BOOT to make the code clearer, and to make supporting XIP QSPI boot clearer in the code. Signed-off-by: Tom Rini <trini@ti.com> Reviewed-by: Wolfgang Denk <wd@denx.de>
2014-03-04drivers: net: cpsw: add support to have phy address from cpsw platform dataMugunthan V N
Some platforms like AM437x have different EVMs with different phy addresses, so this patch adds support for passing phy address via cpsw plaform data. Also renamed phy_id to phy_addr so better understanding of the code. Reviewed-by: Felipe Balbi <balbi@ti.com> Signed-off-by: Mugunthan V N <mugunthanvnm@ti.com> [trini: Update BuR am335x_igep0033 pcm051_rev3 pcm051_rev1 cm_t335 pengwyn boards] Signed-off-by: Tom Rini <trini@ti.com>
2014-02-21am335x: Initial support for Silica Pengwyn boardLothar Felten
This patch add support for the Silica Pengwyn board [1] The board is based on a TI AM3354 CPU [2] All jumpers removed it will boot from the SDcard, the console is on UART1 accessible via the FDTI -> USB. The on board NAND flash is supported and can act as boot medium, depending on jumper settings. USB Host, USB Device and Ethernet are also provided but untested. [1] http://www.silica.com/product/silica-pengwyn-board.html [2] http://www.ti.com/product/am3354 Signed-off-by: Lothar Felten <lothar.felten@gmail.com> [trini: Move CONFIG_BOARD_LATE_INIT into am335x_evm.h, drop unused spi0_pin_mux from Pengwyn support] Signed-off-by: Tom Rini <trini@ti.com>
