path: root/board/siemens
2016-02-18board: atmel: siemens: clean up PLLB codeWenyou Yang
Due to introducing the new PLLB clock handle functions, use these functions to clean up the PLLB enable code. Signed-off-by: Wenyou Yang <wenyou.yang@atmel.com> Reviewed-by: Andreas Bießmann <andreas.devel@googlemail.com> Tested-by: Heiko Schocher <hs@denx.de>
2016-02-18board: atmel: siemens: clean up UTMI PLL codeWenyou Yang
Due to introducing the new UTMI PLL clock handle functions, use the functions to reduce the duplicated code. Signed-off-by: Wenyou Yang <wenyou.yang@atmel.com> Tested-by: Heiko Schocher <hs@denx.de> Reviewed-by: Andreas Bießmann <andreas.devel@googlemail.com>
2016-02-18board: atmel: clean up peripheral clock codeWenyou Yang
Due to introducing the new peripheral clock handle functions, use these functions to reduce duplicated code. Signed-off-by: Wenyou Yang <wenyou.yang@atmel.com> Tested-by: Heiko Schocher <hs@denx.de> [Rebased on current master, fixup for at91rm9200ek] Signed-off-by: Andreas Bießmann <andreas.devel@googlemail.com>
2016-02-02arm: at91/spl: mpddrc: add struct atmel_mpddrc_configWenyou Yang
Add struct atmel_mpddrc_config to accommodate the mpddrc register configurations, not using the mpddrc register map structure, struct atmel_mpddrc, in order to increase readability and reduce run-time memory use. Signed-off-by: Wenyou Yang <wenyou.yang@atmel.com> Reviewed-by: Andreas Bießmann <andreas.devel@googlemail.com>
2016-01-14Fix GCC format-security errors and convert sprintfs.Ben Whitten
With format-security errors turned on, GCC picks up the use of sprintf with a format parameter not being a string literal. Simple uses of sprintf are also converted to use strcpy. Signed-off-by: Ben Whitten <ben.whitten@gmail.com> Acked-by: Wolfgang Denk <wd@denx.de> Reviewed-by: Tom Rini <trini@konsulko.com>
2015-12-12siemens,am33x: remove ddr3 delay workaroundEgli, Samuel
Signed-off-by: Samuel Egli <samuel.egli@siemens.com> Cc: Roger Meier <r.meier@siemens.com> Cc: Heiko Schocher <hs@denx.de>
2015-10-01arm, at91: small updates for the smartweb boardHeiko Schocher
- add CONFIG_BOOT_RETRY_TIME to 30 - fex LED colors - fix button pressed combination - add CONFIG_USB_HOST_ETHER CONFIG_USB_ETHER_ASIX CONFIG_USB_ETHER_MCS7830 Signed-off-by: Heiko Schocher <hs@denx.de> Signed-off-by: Matthias Michel <matthias.michel@siemens.com>
2015-09-11at91, taurus, smartweb: add dfu supportHeiko Schocher
[root@pollux dfu-util]# ./src/dfu-util -l dfu-util 0.8 Copyright 2005-2009 Weston Schmidt, Harald Welte and OpenMoko Inc. Copyright 2010-2014 Tormod Volden and Stefan Schmidt This program is Free Software and has ABSOLUTELY NO WARRANTY Please report bugs to dfu-util@lists.gnumonks.org Found DFU: [0908:02d2] ver=0212, devnum=119, cfg=1, intf=0, alt=0, name="Linux", serial="UNKNOWN" [root@pollux dfu-util]# Signed-off-by: Heiko Schocher <hs@denx.de> Acked-by: Lukasz Majewski <l.majewski@samsung.com>
2015-09-11taurus: board updatesHeiko Schocher
taurus changes: - rename at91_spl_board_init to spl_board_init fixes problems with recovery button and nand erase sector 0 - adapt CONFIG_SPL_MAX_SIZE and CONFIG_SPL_BSS_MAX_SIZE - add CONFIG_AT91_HW_WDT_TIMEOUT 15 - CONFIG_SF_DEFAULT_MODE SPI_MODE_3 not mode 0 Signed-off-by: Heiko Schocher <hs@denx.de>
2015-09-11arm, at91: add axm extensionsHeiko Schocher
add extensions for the axm board: - power on LED on power up - press both recovery buttons on power up to enter recovery mode - detect 64 MiB and 128 MiB ramsize - PHY rest at reboot because of ATMEL bug - use siemens update concept - add axm default environment - set CONFIG_SPL_MAX_SIZE to 15k Signed-off-by: Heiko Schocher <hs@denx.de>
2015-09-11corvus, dfu: add dfu supportHeiko Schocher
add support for DFU on the corvus board. Signed-off-by: Heiko Schocher <hs@denx.de>
2015-09-11at91: corvus: board updatesHeiko Schocher
- rename at91_spl_board_init into spl_board_init - use SZ_1X defines for sizes Signed-off-by: Heiko Schocher <hs@denx.de>
2015-08-21arm: at91: pmc: replace the constant with a define in at91_pmc.hErik van Luijk
To enable the clocks on the at91 boards a constant (0x4) is used. This is replaced with a define in at91_pmc.h (1 << 2). Signed-off-by: Erik van Luijk <evanluijk@interact.nl> Reviewed-by: Andreas Bießmann <andreas.devel@googlemail.com>
2015-08-21arm: at91: at91sam9m10g45ek/corvus remove useless chip select 1 initErik van Luijk
On these boards the DDR is connected to a dedicated controller and not to chip select 1 of the EBI. Signed-off-by: Erik van Luijk <evanluijk@interact.nl> Tested-by: Erik van Luijk <evanluijk@interact.nl>
2015-08-21arm: at91: mpddr: allow multiple DDR controllersErik van Luijk
The mpddr.c depends on ATMEL_BASE_MPDDRC for the base address to configure the controller. This cannot be used when there is more than one controller (i.e. AT91SAM9G45, AT91SAM9M10). Signed-off-by: Erik van Luijk <evanluijk@interact.nl> [remove 'new blank line at EOF'] Signed-off-by: Andreas Bießmann <andreas.devel@googlemail.com>
2015-08-12arm, at91: support for sam9260 based smartweb boardHeiko Schocher
add support for the at91sam9260 based board smartweb from siemens. SPL is used without serial support, as this SoC has only 4k sram for running SPL. Here a U-Boot bootlog: RomBOOT > U-Boot 2015.07-rc2-00109-g4ae828c (Jun 15 2015 - 09:31:16 +0200) CPU: AT91SAM9260 Crystal frequency: 18.432 MHz CPU clock : 198.656 MHz Master clock : 99.328 MHz Watchdog enabled DRAM: 64 MiB WARNING: Caches not enabled NAND: 256 MiB In: serial Out: serial Err: serial Net: macb0 Hit any key to stop autoboot: 0 U-Boot> Signed-off-by: Heiko Schocher <hs@denx.de>
2015-08-05usb: musb-new: CONFIG_MUSB prefix replacement with CONFIG_USB_MUSBPaul Kocialkowski
USB-related options are usually prefixed with CONFIG_USB and platform-specific adaptation for the MUSB controller already have a CONFIG_USB_MUSB prefix, so this switches all MUSB-related options to a CONFIG_USB_MUSB prefix, for consistency. Signed-off-by: Paul Kocialkowski <contact@paulk.fr>
2015-07-22usb: USB download gadget and functions config options coherent namingPaul Kocialkowski
This introduces a coherent scheme for naming USB download gadget and functions config options. The download USB gadget config option is moved to CONFIG_USB_GADGET_DOWNLOAD for better consistency with other gadgets and each function's config option is moved to a CONFIG_USB_FUNCTION_ prefix. Signed-off-by: Paul Kocialkowski <contact@paulk.fr> Tested-by: Lukasz Majewski <l.majewski@samsung.com> Test HW: Odroid_XU3 (Exynos5422), trats (Exynos4210)
2015-06-19siemens,am33x,thuban: rename dxr2 to thubanHeiko Schocher
Update new naming scheme. Signed-off-by: Samuel Egli <samuel.egli@siemens.com> Acked-by: Heiko Schocher <hs@denx.de> Reviewed-by: Tom Rini <trini@konsulko.com>
2015-06-19siemens,am33x,rastaban: add rastaban configHeiko Schocher
rastaban is a draco version with more flash, more RAM and faster CPU. Number of partitions is the same but rootfs partition is different. Signed-off-by: Samuel Egli <samuel.egli@siemens.com> Acked-by: Heiko Schocher <hs@denx.de> Reviewed-by: Tom Rini <trini@konsulko.com>
2015-06-19arm, am33xx: update for siemens am335x based boardsHeiko Schocher
updates for the siemens am335x based boards: - draco: add delay for DDR3 configuration - change MTD partition layout and add a possibility to redefine MTD layout in board header. - move ubi support to common header file - draco: improve dtb naming - draco: set CONFIG_SYS_CBSIZE to 1024 - add generic env based led Leds can now be defined in Environment - add generic env based dfu button Which gpio is used for the dfu button can be defined through the Environment - set MACH_TYPE only if defined - draco: increase CPU freq to 300MHz - Add time command to siemens am33xx boards - DDR3: increase default tRFC - draco: enable pullup for DFU and ERST pin - change print format DDR3 Signed-off-by: Samuel Egli <samuel.egli@siemens.com> Acked-by: Heiko Schocher <hs@denx.de> Reviewed-by: Tom Rini <trini@konsulko.com> Signed-off-by: Heiko Schocher <hs@denx.de>
2015-05-28am33xx, spl, siemens: enable debug uart output againHeiko Schocher
a6b541b090: TI ARMv7: Don't use GD before crt0.S has set it moves the init of the debug uart at the very end of SPL code. Enable it for the siemens board earlier, as they print ddr settings ... all debug output before board_init_r() is here currently useless. Maybe we must rework this globally? Signed-off-by: Heiko Schocher <hs@denx.de>
2015-04-18net: cosmetic: Name ethaddr variables consistentlyJoe Hershberger
Use "_ethaddr" at the end of variables and drop CamelCase. Make constant values actually 'const'. Signed-off-by: Joe Hershberger <joe.hershberger@ni.com> Acked-by: Simon Glass <sjg@chromium.org>
2015-01-19arm, at91: corvus board updatesHeiko Schocher
- corvus board fix problems with toshiba nand chips on the corvus board problems with toshiba chips Manufacturer ID: 0x98 Chip ID: 0xdc encounterd. Solve this in the following way: - set other nand timings - enable CONFIG_SYS_NAND_READY_PIN - correct the MACH_TYPE setting Signed-off-by: Heiko Schocher <hs@denx.de>
2015-01-19taurus, spl: erase also spi flash if recovery button is pressedHeiko Schocher
if in SPL mode recovery button is pressed, erase also spi flash from offset 0 to CONFIG_SYS_NAND_U_BOOT_SIZE on the taurus board. Signed-off-by: Heiko Schocher <hs@denx.de>
2014-12-04arm, am335x: siemens boards add FIT supportHeiko Schocher
add FIT support and set "boardid" from factoryset records "DEV/id" and "COMP/ver". "boardid" is used for selecting which fit configuration gets booted on the board. Signed-off-by: Heiko Schocher <hs@denx.de>
2014-12-04arm, am335x, siemens: read COMP/ver from factorysetHeiko Schocher
2014-12-04arm, am335x, siemens: fix factoryset interpretationHeiko Schocher
a record could contain other records, so after an ">" (begin mark) there not always come an end mark "<", instead a ">" is possible. Take care of this. Signed-off-by: Heiko Schocher <hs@denx.de>
2014-11-17arm, spl, at91: add spl support for the corvus boardHeiko Schocher
replaces the at91bootstrap code with SPL code. make the spl image with: ./tools/mkimage -T atmelimage -d spl/u-boot-spl.bin spl/boot.bin this writes the length of the spl image into the 6th execption vector. This is needed from the ROM bootloader. Signed-off-by: Heiko Schocher <hs@denx.de> Reviewed-by: Bo Shen <voice.shen@atmel.com> Reviewed-by: Andreas Bießmann <andreas.devel@googlemail.com> Signed-off-by: Andreas Bießmann <andreas.devel@googlemail.com>
2014-11-17arm, at91, spl: add spl support for the taurus boardHeiko Schocher
replaces the at91bootstrap code with SPL code. make the spl image with: ./tools/mkimage -T atmelimage -d spl/u-boot-spl.bin spl/boot.bin this writes the length of the spl image into the 6th execption vector. This is needed from the ROM bootloader. Signed-off-by: Heiko Schocher <hs@denx.de> Reviewed-by: Bo Shen <voice.shen@atmel.com> Signed-off-by: Andreas Bießmann <andreas.devel@googlemail.com>
2014-11-17arm, at91: add spi dataflash support for the taurus boardHeiko Schocher
Signed-off-by: Heiko Schocher <hs@denx.de> Reviewed-by: Bo Shen <voice.shen@atmel.com> Reviewed-by: Jagannadha Sutradharudu Teki <jagannadh.teki@gmail.com> Signed-off-by: Andreas Bießmann <andreas.devel@googlemail.com>
2014-11-06arm: am335x: net: pxm2: disable rgmii internal delay modeHeiko Schocher
disable internal delay through gmii_sel register, as this is done in the ar8031 phy. Signed-off-by: Heiko Schocher <hs@denx.de> Cc: Tom Rini <trini@ti.com>
2014-10-29kconfig: arm: introduce symbol for ARM CPUsGeorges Savoundararadj
This commit introduces a Kconfig symbol for each ARM CPU: CPU_ARM720T, CPU_ARM920T, CPU_ARM926EJS, CPU_ARM946ES, CPU_ARM1136, CPU_ARM1176, CPU_V7, CPU_PXA, CPU_SA1100. Also, it adds the CPU feature Kconfig symbol HAS_VBAR which is selected for CPU_ARM1176 and CPU_V7. For each target, the corresponding CPU is selected and the definition of SYS_CPU in the corresponding Kconfig file is removed. Also, it removes redundant "string" type in some Kconfig files. Signed-off-by: Georges Savoundararadj <savoundg@gmail.com> Acked-by: Albert ARIBAUD <albert.u.boot@aribaud.net> Cc: Masahiro Yamada <yamada.m@jp.panasonic.com>
2014-05-13siemens:cosmetic, dxr2: rename dxr2 to dracoEgli, Samuel
The actual board name is draco and dxr2 is the target name. In the future we'll have different targets based on draco board. All changes are purely non-functional and basically rename dxr2 to draco. One style fix in board.c that existed already before. Signed-off-by: Samuel Egli <samuel.egli@siemens.com> Reviewed-by: Roger Meier <r.meier@siemens.com> Cc: Heiko Schocher <hs@denx.de> Cc: Wolfgang Denk <wd@denx.de>
2014-05-13siemens: add led cmd for flexible LED controlEgli, Samuel
* remove setting LED in user button function. We want to decouple reading user button and setting LED. This two things need to be done independently. * led cmd can be used to control LEDs that are defined in board file having a led cmd, one can easily set LEDs in u-boot shell. For example bootcmd can be extended to disable status LED before loading kernel. Signed-off-by: Samuel Egli <samuel.egli@siemens.com> Cc: Roger Meier <r.meier@siemens.com> Cc: Heiko Schocher <hs@denx.de> Cc: Wolfgang Denk <wd@denx.de>
2014-05-13siemens: update DDR3 parameters for dxr2Egli, Samuel
* add parameters for factory and print them at start up to facilitate control of right DDR3 settings in EEPROM. * cosmetic changes in a couple of printfs Signed-off-by: Samuel Egli <samuel.egli@siemens.com> Cc: Roger Meier <r.meier@siemens.com> Cc: Heiko Schocher <hs@denx.de> Cc: Wolfgang Denk <wd@denx.de>
2014-05-13siemens: cosmetic: remove unused and rename definesEgli, Samuel
For dxr2 board DXR2_IOCTRL_VAL is set by data in EEPROM. In pxm2 board it does not make sense to have dxr2 as prefix. Replace it with more meaningful DDR prefix. Signed-off-by: Samuel Egli <samuel.egli@siemens.com> Cc: Pascal Bach <pascal.bach@siemens.com> Cc: Roger Meier <r.meier@siemens.com> Cc: Heiko Schocher <hs@denx.de> Cc: Wolfgang Denk <wd@denx.de>
2014-05-13am33xx: add SSC enable macroYegor Yefremov
Signed-off-by: Yegor Yefremov <yegorslists@googlemail.com>
2014-03-12arm: am335x: DXR2: Move unconditional LAN9303 reset into commandStefan Roese
The switch HW reset results in a disconnection of the switch port daisy- chain for a few seconds. This is not desired in the normal field use case. So lets remove this switch reset from the normal bootup sequence and move it into a board specific command. This way it can be executed in the development environment when really needed. Signed-off-by: Stefan Roese <sr@denx.de> Cc: Roger Meier <r.meier@siemens.com> Cc: Lukas Stockmann <lukas.stockmann@siemens.com> Cc: Tom Rini <trini@ti.com>
2014-03-04arm: am335x: DXR2: Reset SMSC LAN9303 switch via GPIO upon bootupStefan Roese
Since the switch may be re-configured for VLAN usage in Linux (or any other OS), lets reset the switch to its default register values upon power-up. Otherwise network might not be available in U-Boot. Signed-off-by: Stefan Roese <sr@denx.de> Cc: Heiko Schocher <hs@denx.de> Cc: Roger Meier <r.meier@siemens.com> Cc: Lukas Stockmann <lukas.stockmann@siemens.com> Cc: Tom Rini <trini@ti.com>
2014-03-04drivers: net: cpsw: add support to have phy address from cpsw platform dataMugunthan V N
Some platforms like AM437x have different EVMs with different phy addresses, so this patch adds support for passing phy address via cpsw plaform data. Also renamed phy_id to phy_addr so better understanding of the code. Reviewed-by: Felipe Balbi <balbi@ti.com> Signed-off-by: Mugunthan V N <mugunthanvnm@ti.com> [trini: Update BuR am335x_igep0033 pcm051_rev3 pcm051_rev1 cm_t335 pengwyn boards] Signed-off-by: Tom Rini <trini@ti.com>
2013-12-18ARM: AM33xx+: Update ioregs to pass different valuesLokesh Vutla
Currently same value is programmed for all ioregs. This is not the case for all SoC's like AM4372. So adding a structure for ioregs and updating in all board files. And also return from config_cmd_ctrl() and config_ddr_data() functions if data is not passed. Signed-off-by: Lokesh Vutla <lokeshvutla@ti.com> [trini: Fixup dxr2, cm_t335, adapt pcm051 rev3] Signed-off-by: Tom Rini <trini@ti.com>
2013-12-12am33xx: Enable D-CACHE on !CONFIG_SYS_DCACHE_OFFTom Rini
Test on Beaglebone white over cpsw, usb ether and SD card (read and write), performance increased, crc32 of data matches. Signed-off-by: Tom Rini <trini@ti.com>
2013-12-10Merge branch 'u-boot/master' into 'u-boot-arm/master'Albert ARIBAUD
Conflicts: arch/arm/cpu/armv7/rmobile/Makefile doc/README.scrapyard Needed manual fix: arch/arm/cpu/armv7/omap-common/Makefile board/compulab/cm_t335/u-boot.lds
2013-12-09arm, at91: add siemens corvus boardHeiko Schocher
enable support for the siemens AT91SAM9G20 based board corvus. Signed-off-by: Boris Schmidt <boris.schmidt@siemens.com> Reviewed-by: Heiko Schocher <hs@denx.de> Cc: Andreas Bießmann <andreas.devel@googlemail.com> Cc: Bo Shen <voice.shen@atmel.com> Signed-off-by: Andreas Bießmann <andreas.devel@googlemail.com>
2013-12-09arm, at91: add Siemens board taurus and axmHeiko Schocher
enable support for the siemens AT91SAM9G20 based boards taurus and axm. Signed-off-by: Roger Meier <r.meier@siemens.com> Reviewed-by: Heiko Schocher <hs@denx.de> Cc: Andreas Bießmann <andreas.devel@googlemail.com> Cc: Bo Shen <voice.shen@atmel.com> Signed-off-by: Andreas Bießmann <andreas.devel@googlemail.com>
