path: root/board/siemens/rut/board.c
2016-01-14Fix GCC format-security errors and convert sprintfs.Ben Whitten
With format-security errors turned on, GCC picks up the use of sprintf with a format parameter not being a string literal. Simple uses of sprintf are also converted to use strcpy. Signed-off-by: Ben Whitten <ben.whitten@gmail.com> Acked-by: Wolfgang Denk <wd@denx.de> Reviewed-by: Tom Rini <trini@konsulko.com>
2015-08-05usb: musb-new: CONFIG_MUSB prefix replacement with CONFIG_USB_MUSBPaul Kocialkowski
USB-related options are usually prefixed with CONFIG_USB and platform-specific adaptation for the MUSB controller already have a CONFIG_USB_MUSB prefix, so this switches all MUSB-related options to a CONFIG_USB_MUSB prefix, for consistency. Signed-off-by: Paul Kocialkowski <contact@paulk.fr>
2014-12-04arm, am335x: siemens boards add FIT supportHeiko Schocher
add FIT support and set "boardid" from factoryset records "DEV/id" and "COMP/ver". "boardid" is used for selecting which fit configuration gets booted on the board. Signed-off-by: Heiko Schocher <hs@denx.de>
2014-05-13am33xx: add SSC enable macroYegor Yefremov
Signed-off-by: Yegor Yefremov <yegorslists@googlemail.com>
2014-03-04drivers: net: cpsw: add support to have phy address from cpsw platform dataMugunthan V N
Some platforms like AM437x have different EVMs with different phy addresses, so this patch adds support for passing phy address via cpsw plaform data. Also renamed phy_id to phy_addr so better understanding of the code. Reviewed-by: Felipe Balbi <balbi@ti.com> Signed-off-by: Mugunthan V N <mugunthanvnm@ti.com> [trini: Update BuR am335x_igep0033 pcm051_rev3 pcm051_rev1 cm_t335 pengwyn boards] Signed-off-by: Tom Rini <trini@ti.com>
2013-12-18ARM: AM33xx+: Update ioregs to pass different valuesLokesh Vutla
Currently same value is programmed for all ioregs. This is not the case for all SoC's like AM4372. So adding a structure for ioregs and updating in all board files. And also return from config_cmd_ctrl() and config_ddr_data() functions if data is not passed. Signed-off-by: Lokesh Vutla <lokeshvutla@ti.com> [trini: Fixup dxr2, cm_t335, adapt pcm051 rev3] Signed-off-by: Tom Rini <trini@ti.com>
2013-12-04am33xx: Stop modifying certain EMIF4D registersTom Rini
Based on the definitive guide to EMIF configuration[1] certain registers that we have been modifying (and are documented registers) should be left in their reset values rather than modified. This has been tested on AM335x GP EVM and Beaglebone White. [1]: http://processors.wiki.ti.com/index.php/AM335x_EMIF_Configuration_tips Cc: Enric Balletbo i Serra <eballetbo@iseebcn.com> Cc: Javier Martinez Canillas <javier@dowhile0.org> Cc: Heiko Schocher <hs@denx.de> Cc: Lars Poeschel <poeschel@lemonage.de> Signed-off-by: Tom Rini <trini@ti.com> Tested-by: Matt Porter <matt.porter@linaro.org>
2013-11-12arm, am335x: update for the siemens boardsSamuel Egli
- dxr2: define unused pins as input - do not enable RTC32K OSC on dxr2 board - update default environment - add splashpos=m,m to default environment, so splash screen is always centered. - adapt environment for bootcount feature - add altbootcmd to default environment - rut: SPL add early reset pulse for eth-phy, maXTouch and display - rut: display timing aenderungen - siemens boards: adapt for background color = white - add boutcount feature for the siemens boards store the bootcount in the environment, as we have no softreset save registers on this hardware. Use therefore the CONFIG_BOOTCOUNT_ENV bootcount driver. - change spi mode from 3 to 0 for the lcd init - add gpio pin for lcd reset with state 0 and add mdelay - siemens boards: use own USB id's - add dfu serial and device number for siemens boards Add for the siemens boards the possibility to define in dfu mode, the iSerialNumber and the bcdDevice fields in the USB Device descriptor. - fix upgrade mechanism based on bootcount Correct location of saveenv and remove not active variable. Add CONFIG_BOOT_RETRY_TIME and CONFIG_RESET_TO_RETRY to reboot board in case of empty kernel partition. Without these defines an empty kernel partition leads to an abort of boot process and one remains in u-boot prompt. - general cleanup of dxr2, pxm2 and rut boards all: * Remove net boot from bootcmd Ping can cause a crash on boards without ethernet phy. net_nfs command is used only for development * Add reset at the end of bootcmd In order to have an immediate reset of the boot when bootcmd fails, add reset at the end of bootcmd. rut: * add nand_img_size dxr2: * update nand_img_size * ddr3 timings updated with iocontrol property that can be modified via eeprom. New default parameters from software leveling with draco ES2. Signed-off-by: Samuel Egli <samuel.egli@siemens.com> Signed-off-by: Pascal Bach <pascal.bach@siemens.com> Signed-off-by: Roger Meier <r.meier@siemens.com> Signed-off-by: Heiko Schocher <hs@denx.de> Cc: Matthias Michel <matthias.michel@siemens.com> Cc: Tom Rini <trini@ti.com>
2013-10-14Coding Style cleanup: drop some excessive empty linesWolfgang Denk
2013-08-28arm, am335x: add support for 3 siemens boardsHeiko Schocher
add support for the am335x based boards from siemens: dxr2: - DDR3 128MiB - NAND 256MiB - Ethernet with external Switch SMSC LAN9303 - no PMIC - internal Watchdog - DFU support pxm2: - DDR2 512 MiB - NAND 1024 MiB - PMIC - PHY atheros ar803x - USB Host - internal Watchdog - DFU support rut: - DDR3 256 MiB - NAND 256 MiB - PMIC - PHY natsemi dp83630 - external Watchdog - DFU support Signed-off-by: Heiko Schocher <hs@denx.de> Signed-off-by: Roger Meier <r.meier@siemens.com> Signed-off-by: Samuel Egli <samuel.egli@siemens.com> Cc: Pascal Bach <pascal.bach@siemens.com> Cc: Tom Rini <trini@ti.com>
