path: root/board/siemens/pxm2/mux.c
2013-08-28arm, am335x: add support for 3 siemens boardsHeiko Schocher
add support for the am335x based boards from siemens: dxr2: - DDR3 128MiB - NAND 256MiB - Ethernet with external Switch SMSC LAN9303 - no PMIC - internal Watchdog - DFU support pxm2: - DDR2 512 MiB - NAND 1024 MiB - PMIC - PHY atheros ar803x - USB Host - internal Watchdog - DFU support rut: - DDR3 256 MiB - NAND 256 MiB - PMIC - PHY natsemi dp83630 - external Watchdog - DFU support Signed-off-by: Heiko Schocher <hs@denx.de> Signed-off-by: Roger Meier <r.meier@siemens.com> Signed-off-by: Samuel Egli <samuel.egli@siemens.com> Cc: Pascal Bach <pascal.bach@siemens.com> Cc: Tom Rini <trini@ti.com>
