path: root/board/siemens/SMN42
2010-04-13arm: Move cpu/$CPU to arch/arm/cpu/$CPUPeter Tyser
2009-06-12arm: unify linker scriptJean-Christophe PLAGNIOL-VILLARD
all arm boards except a few use the same cpu linker script so move it to cpu/$(CPU) that could be overwrite in following order SOC BOARD via the corresponding config.mk Signed-off-by: Jean-Christophe PLAGNIOL-VILLARD <plagnioj@jcrosoft.com>
2008-07-02Cleanup: replace hard-wired $(AR) 'crv' settings by $(ARFLAGS)Wolfgang Denk
2007-09-15Fix cases where DECLARE_GLOBAL_DATA_PTR was not declared as globalWolfgang Denk
2007-07-04Fix a few file permission problems.Wolfgang Denk
2007-06-06Coding Style cleanup; generate new CHANGELOG file.Wolfgang Denk
2007-05-18Reduce line lengths to 80 characters max.Peter Pearse
2007-05-09Add the board directory for SMN42Peter Pearse
