path: root/board/siemens/SCM
2008-09-10cleanup use of CFG_ENV_IS_IN_FLASHJean-Christophe PLAGNIOL-VILLARD
- #if CFG_ENV_IS_IN_FLASH - #if (CFG_ENV_IS_IN_FLASH == 1) - #define CFG_ENV_IS_IN_FLASH 0 Signed-off-by: Jean-Christophe PLAGNIOL-VILLARD <plagnioj@jcrosoft.com>
2008-07-04CCM/SCM boards: fix out of tree buildingWolfgang Denk
2008-07-03SCM board: fix build errors.Wolfgang Denk
2008-03-09SCM: fix 'packed' attribute ignored for field of type 'can_msg_t' warningsJean-Christophe PLAGNIOL-VILLARD
Signed-off-by: Jean-Christophe PLAGNIOL-VILLARD <plagnioj@jcrosoft.com> Signed-off-by: Wolfgang Denk <wd@denx.de>
2007-07-04Remove obsolete mpc824x linker scriptsGrant Likely
2004-02-12* Some code cleanupwdenk
* Patch by Josef Baumgartner, 10 Feb 2004: Fixes for Coldfire port * Patch by Brad Kemp, 11 Feb 2004: Fix CFI flash driver problems
2002-08-26Initial revisionwdenk
2002-07-29Initial revisionwdenk
2002-06-10Initial revisionwdenk
