path: root/board/shmin
2014-11-13sh: consolidate CONFIG_SYS_CPU definesMasahiro Yamada
Now each board selects one of CONFIG_CPU_SH2, CONFIG_CPU_SH3, CONFIG_CPU_SH4, so let's move CONFIG_SYS_CPU definition to arch/sh/Kconfig. Signed-off-by: Masahiro Yamada <yamada.m@jp.panasonic.com> Cc: Nobuhiro Iwamatsu <nobuhiro.iwamatsu.yj@renesas.com> Signed-off-by: Nobuhiro Iwamatsu <iwamatsu@nigauri.org>
2013-10-31sh: convert makefiles to Kbuild styleMasahiro Yamada
2011-12-08ne2000: Convert to new net-multi model, fixes build of three boardsBernhard Kaindl
This fixes the build of the two sh boards shmin and r7780mp and qemu-mips which currently fail to build due to dropped pre-CONFIG_NET_MULTI code. This v2 patch minimizes the number of lines in the diff for easy review and to eliminate any possible accidential changes resulting from moving lines of code in the file. This also makes the register function very easy. Any cleanups and improvements are intentionally deferred to follow-up patches to keep this patch as simple and as easy to review as possible. A new driver register function, ne2k_register() calls the existing one-time setup part of the old init function and calls eth_register(). Changes to shmin, r7780mp and qemu-mips: - Call the new ne2k_register() from board_eth_init() of the boards. - Tested using qemu-mips board, - Tested the two renesas / sh boards r7780mp and shmin to compile again, and should work. checkpatch-clean when "--ignore VOLATILE" is added to .checkpatch.conf, and no warnings introduced in none of the three boards using this driver. Signed-off-by: Bernhard Kaindl <bernhard.kaindl@gmx.net>
2011-10-22build: add missing $(AR)->$(cmd_link_o_target) updateMike Frysinger
Seems people fixed their files to use libfoo.o, but didn't actually update the creation targets to use $(cmd_link_o_target). Update the rest of the Makefile's found with grep. Signed-off-by: Mike Frysinger <vapier@gentoo.org> Tested-by: Simon Glass <sjg@chromium.org>
2011-02-02sh: Remove config.mk for shmin boardNobuhiro Iwamatsu
Move CONFIG_SYS_TEXT_BASE to the board's config file, and remove the unnecessary config.mk file. Signed-off-by: Nobuhiro Iwamatsu <iwamatsu@nigauri.org>
2011-01-06sh: Add support T-SH7706LSR boardNobuhiro Iwamatsu
This patch supports T-SH7706LSR board. This is constitution almost same as shmin (T-SH7706LAN). Therefore, most functions work by a change of the setting of config. http://web.kyoto-inet.or.jp/people/takagaki/T-SH7706/T-SH7706LSR.htm Signed-off-by: Nobuhiro Iwamatsu <iwamatsu@nigauri.org>
2011-01-11sh: Fix build of shmin boardNobuhiro Iwamatsu
Change lib$(BOARD).a to lib$(BOARD).o Signed-off-by: Nobuhiro Iwamatsu <iwamatsu@nigauri.org>
2011-01-11sh: Add support shmin boardNobuhiro Iwamatsu
This adds support for the SHMIN SH7706 board(T-SH7706LAN). The CPU of this board is SH7706. There are SDRAM of 32M byte, Flash memory of 512K byte, Serial, 10Base Ether and MMC. http://web.kyoto-inet.or.jp/people/takagaki/T-SH7706/T-SH7706.htm Signed-off-by: Nobuhiro Iwamatsu <iwamatsu@nigauri.org>
