path: root/board/sheldon
2010-09-2383xx: Remove warmboot parameter from PCI init functionsPeter Tyser
This change lays the groundwork for the BOOTFLAG_* flags being removed. This change has the small affect of delaying 100ms on PCI initialization after a warm boot as opposed to the optimal 1ms on some boards. Signed-off-by: Peter Tyser <ptyser@xes-inc.com> included the mpc8308_p1m board. Signed-off-by: Kim Phillips <kim.phillips@freescale.com>
2010-07-1683xx/85xx/86xx: LBC register cleanupBecky Bruce
Currently, 83xx, 86xx, and 85xx have a lot of duplicated code dedicated to defining and manipulating the LBC registers. Merge this into a single spot. To do this, we have to decide on a common name for the data structure that holds the lbc registers - it will now be known as fsl_lbc_t, and we adopt a common name for the immap layouts that include the lbc - this was previously known as either im_lbc or lbus; use the former. In addition, create accessors for the BR/OR regs that use in/out_be32 and use those instead of the mismash of access methods currently in play. I have done a successful ppc build all and tested a board or two from each processor family. Signed-off-by: Becky Bruce <beckyb@kernel.crashing.org> Acked-by: Kim Phillips <kim.phillips@freescale.com> Signed-off-by: Kumar Gala <galak@kernel.crashing.org>
2010-05-17Removal of checkboard from spl bootstrap build for SIMPC8313Ron Madrid
This patch removes the checkboard function from the build of the 4k bootstrap section for the SIMPC8313 as it is not needed in the spl build. This will allow > 100 bytes of extra room for other uses. Signed-off-by: Ron Madrid <ron_madrid@sbcglobal.net> Signed-off-by: Kim Phillips <kim.phillips@freescale.com>
2010-05-07mpc83xx: Add UPMA configuration to SIMPC8313Ron Madrid
Added UPM array table, upmconfig, and Local Bus configuration support for SIMPC8313 Signed-off-by: Ron Madrid <ron_madrid@sbcglobal.net> Signed-off-by: Kim Phillips <kim.phillips@freescale.com>
2009-09-15NAND boot: change NAND loader's relocate SP to CONFIG paramMingkai Hu
So that we can set the NAND loader's relocate stack pointer to the value other than the relocate address + 0x10000. Signed-off-by: Mingkai Hu <Mingkai.hu@freescale.com> Acked-by: Kim Phillips <kim.phillips@freescale.com> Acked-by: Scott Wood <scottwood@freescale.com> Signed-off-by: Kumar Gala <galak@kernel.crashing.org>
2009-01-23mpc83xx: New board support for SIMPC8313Ron Madrid
This patch will create a new board, SIMPC8313, from Sheldon Instruments. This board boots from NAND devices and is configureable for either large or small page devices. The board supports non-soldered DDR2, one ethernet port, a Marvell 88E1118 PHY, and PCI host support. The board also has a FPGA connected to the eLBC providing glue logic to a TMS320C67xx DSP. Signed-off-by: Ron Madrid <ron_madrid@sbcglobal.net> Signed-off-by: Kim Phillips <kim.phillips@freescale.com>
