path: root/board/shannon
2011-09-07ARM: remove broken "shannon" board.Wolfgang Denk
Signed-off-by: Wolfgang Denk <wd@denx.de> Cc: Albert ARIBAUD <albert.u.boot@aribaud.net> Cc: Rolf Offermanns <rof@sysgo.de>
2011-07-16Timer: Fix misuse of ARM *timer_masked() functions outside arch/armGraeme Russ
Signed-off-by: Graeme Russ <graeme.russ@gmail.com>
2009-06-12arm: unify linker scriptJean-Christophe PLAGNIOL-VILLARD
all arm boards except a few use the same cpu linker script so move it to cpu/$(CPU) that could be overwrite in following order SOC BOARD via the corresponding config.mk Signed-off-by: Jean-Christophe PLAGNIOL-VILLARD <plagnioj@jcrosoft.com>
2006-03-11Some code cleanup for GCC 4.xWolfgang Denk
2005-04-02Prepare for SoC rework of ARM code:wdenk
- rename CONFIG_BOOTBINFUNC into CONFIG_INIT_CRITICAL - rename memsetup into lowlevel_init (function name and source files)
2004-10-17Code cleanup for GCC-3.3.x compilerswdenk
2004-10-10Patch by George G. Davis, 24 Aug 2004:wdenk
- update ARM boards to use constants from mach-types.h
2004-02-08Patch by Anders Larsen, 09 Jan 2004:wdenk
ARM memory layout fixes: the abort-stack is now set up in the correct RAM area, and the BSS is zeroed out as it should be. Furthermore, the magic variables 'armboot_end' and 'armboot_end_data' of the linker scripts are replaced by '__bss_start' and '_end', resp., which is a further step to eliminate unnecessary differences between the implementation of the CPU architectures.
2003-12-06* Patch by Gleb Natapov, 19 Sep 2003:wdenk
Move most of the timer interrupt related PPC code to ppc_lib/interrupts.c * Patch by Anders Larsen, 17 Sep 2003: Bring ARM memory layout in sync with the documentation: stack and malloc-heap are now located _below_ the U-Boot code
2003-09-18* Patches by Anders Larsen, 17 Sep 2003:wdenk
- fix spelling errors - set GD_FLG_DEVINIT flag only after device function pointers are valid - Allow CFG_ALT_MEMTEST on systems where address zero isn't writeable - enable 3.rd UART (ST-UART) on PXA(XScale) CPUs - trigger watchdog while waiting in serial driver
2002-10-26Initial revisionwdenk
2002-09-10Initial revisionwdenk
2002-09-09Initial revisionwdenk
2002-03-14Initial revisionwdenk
