2008-09-10 | rename environment.c in env_embedded.c to reflect is functionality | Jean-Christophe PLAGNIOL-VILLARD | |
Signed-off-by: Jean-Christophe PLAGNIOL-VILLARD <plagnioj@jcrosoft.com> | |||
2008-09-09 | add board_eth_init() for sh7785lcr board | Yoshihiro Shimoda | |
Fix the problem that cannot work RTL8169 on sh7785lcr board. Signed-off-by: Yoshihiro Shimoda <shimoda.yoshihiro@renesas.com> | |||
2008-08-31 | sh: Remove CC line from board's Makefile | Nobuhiro Iwamatsu | |
Signed-off-by: Nobuhiro Iwamatsu <iwamatsu@nigauri.org> | |||
2008-08-31 | sh: Renesas R0P7785LC0011RL board support | Nobuhiro Iwamatsu | |
This board has SH7785, 512MB DDR2-SDRAM, NOR Flash, Graphic, Ethernet, USB, SD, RTC, and I2C controller. This patch supports the following functions: - 128MB DDR2-SDRAM (29-bit address mode only) - NOR Flash - USB host - Ethernet Signed-off-by: Yoshihiro Shimoda <shimoda.yoshihiro@renesas.com> Signed-off-by: Nobuhiro Iwamatsu <iwamatsu@nigauri.org> |
