path: root/board/sc520_spunk
2009-09-04i386: Moved PCI from #ifdef to conditional compile for sc520 boardsGraeme Russ
Signed-off-by: Graeme Russ <graeme.russ@gmail.com>
2009-09-04i386: Replace [read, write]_mmcr_[byte, word, long] with memory mapped structureGraeme Russ
2009-09-04Fixup sc520_spunk boardGraeme Russ
Primary intent is to resolve build errors for this board which has been neglected for a very long time. I do not have one of these boards, so I cannot test functionality Signed-off-by: Graeme Russ <graeme.russ@gmail.com>
2009-01-24Renamed cpu/i386/reset.S to resetvec.SGraeme Russ
Brings i386 in line with other CPUs with a reset vector and frees up reset.c for CPU reset functions Signed-off-by: Graeme Russ <graeme.russ@gmail.com>
2008-10-28i386: Renamed show_boot_progress in assembler codeGraeme Russ
Renamed show_boot_progress in assembler init phase to show_boot_progress_asm to avoid link conflicts with C version Signed-off-by: Graeme Russ <graeme.russ@gmail.com>
2008-09-02Moved initialization of EEPRO100 Ethernet controller to board_eth_init()Ben Warren
Affected boards: db64360 db64460 katmai taihu taishan yucca cpc45 cpu87 eXalion elppc debris kvme080 mpc8315erdb integratorap ixdp425 oxc pm826 pm828 pm854 pm856 ppmc7xx sc3 sc520_spunk sorcery tqm8272 tqm85xx utx8245 Removed initialization of the driver from net/eth.c Also, wrapped contents of pci_eth_init() by CONFIG_PCI. Signed-off-by: Ben Warren <biggerbadderben@gmail.com>
2008-05-19i386: Fix multiple definitions of __show_boot_progressJean-Christophe PLAGNIOL-VILLARD
2008-05-19sc530_spunk: add missing SOBJS entryJean-Christophe PLAGNIOL-VILLARD
2008-05-19sc520_spunk: Fix flashJean-Christophe PLAGNIOL-VILLARD
flash.c:593: warning: dereferencing type-punned pointer will break strict-aliasing rules flash.c:398: error: label at end of compound statement Signed-off-by: Jean-Christophe PLAGNIOL-VILLARD <plagnioj@jcrosoft.com>
2007-06-22[PCS440EP] upgrade the PCS440EP board:Heiko Schocher
- Show on the Status LEDs, some States of the board. - Get the MAC addresses from the EEProm - use PREBOOT - use the CF on the board. - check the U-Boot image in the Flash with a SHA1 checksum. - use dynamic TLB entries generation for the SDRAM Signed-off-by: Heiko Schocher <hs@denx.de>
2006-10-09Coding style cleanupWolfgang Denk
2003-09-18* Patches by Anders Larsen, 17 Sep 2003:wdenk
- fix spelling errors - set GD_FLG_DEVINIT flag only after device function pointers are valid - Allow CFG_ALT_MEMTEST on systems where address zero isn't writeable - enable 3.rd UART (ST-UART) on PXA(XScale) CPUs - trigger watchdog while waiting in serial driver
2003-05-31* Patch by Marc Singer, 29 May 2003:LABEL_2003_05_31_2115wdenk
Fixed rarp boot method for IA32 and other little-endian CPUs. * Patch by Marc Singer, 28 May 2003: Added port I/O commands. * Patch by Matthew McClintock, 28 May 2003 - cpu/mpc824x/start.S: fix relocation code when booting from RAM - minor patches for utx8245 * Patch by Daniel Engström, 28 May 2003: x86 update * Patch by Dave Ellis, 9 May 2003 + 27 May 2003: add nand flash support to SXNI855T configuration fix/extend nand flash support: - fix 'nand erase' command so does not erase bad blocks - fix 'nand write' command so does not write to bad blocks - fix nand_probe() so handles no flash detected properly - add doc/README.nand - add .jffs2 and .oob options to nand read/write - add 'nand bad' command to list bad blocks - add 'clean' option to 'nand erase' to write JFFS2 clean markers - make NAND read/write faster * Patch by Rune Torgersen, 23 May 2003: Update for MPC8266ADS board
