The SC520 CDP boards originally implemented by Daniel Engström are now
very broken. Attempts to contact Daniel via the email address on the
copyright notice have failed. Remove these boards from mainline
Signed-off-by: Graeme Russ <graeme.russ@gmail.com>
Change PCI_REGION_MEMORY to PCI_REGION_SYS_MEMORY (Originally done in
commit ff4e66e93c1a, regressed by commit 6d7f610b09f8)
Cast PCI_ROM_ADDRESS_MASK to u32
Wrap probe_pci_video() call inside #ifdef CONFIG_VIDEO
Change call to pci_find_class() to pci_find_devices(). This is based on a
patch submitted on 1st March 2007 (Patch that fixes the compilation errors
for sc520_cdp board) by mushtaq_k
This patch requires that PCI_VIDEO_VENDOR_ID and PCI_VIDEO_DEVICE_ID be
specified in the board config file. Dummy values have been added for the
SC520 CDP board to enable compilation, but since I do not have one of these,
I do know what the values should be
Moved ali512x.h from include/asm-i386/ic/ to /include
Signed-off-by: Graeme Russ <graeme.russ at gmail.com>
Options are now all uniformly CONFIG_SYS_SC520_<option>
Attempt to bring i386 / sc520 inline with master
Affected boards:
PN62
sc520_cdp
Removed initialization of the driver from net/eth.c
This commit gets rid of a huge amount of silly white-space issues.
Especially, all sequences of SPACEs followed by TAB characters get
removed (unless they appear in print statements).
Also remove all embedded "vim:" and "vi:" statements which hide
indentation problems.
- Show on the Status LEDs, some States of the board.
- Get the MAC addresses from the EEProm
- use PREBOOT
- use the CF on the board.
- check the U-Boot image in the Flash with a SHA1
checksum.
- use dynamic TLB entries generation for the SDRAM
* Patch by Brad Parker, 02 Aug 2003:
fix sc520_cdp problems
* Implement Boot Cycle Detection (Req. 2.3 of OSDL CGL Reqirements)
* Allow erase command to cross flash bank boundaries
- remove trailing white space, trailing empty lines, C++ comments, etc.
- split cmd_boot.c (separate cmd_bdinfo.c and cmd_load.c)
* Patches by Kenneth Johansson, 25 Jun 2003:
- major rework of command structure
(work done mostly by Michal Cendrowski and Joakim Kristiansen)
Fixed rarp boot method for IA32 and other little-endian CPUs.
* Patch by Marc Singer, 28 May 2003:
Added port I/O commands.
* Patch by Matthew McClintock, 28 May 2003
- cpu/mpc824x/start.S: fix relocation code when booting from RAM
- minor patches for utx8245
* Patch by Daniel Engström, 28 May 2003:
x86 update
* Patch by Dave Ellis, 9 May 2003 + 27 May 2003:
add nand flash support to SXNI855T configuration
fix/extend nand flash support:
- fix 'nand erase' command so does not erase bad blocks
- fix 'nand write' command so does not write to bad blocks
- fix nand_probe() so handles no flash detected properly
- add doc/README.nand
- add .jffs2 and .oob options to nand read/write
- add 'nand bad' command to list bad blocks
- add 'clean' option to 'nand erase' to write JFFS2 clean markers
- make NAND read/write faster
* Patch by Rune Torgersen, 23 May 2003:
Update for MPC8266ADS board
* Patch by Erwin Rol, 27 Feb 2003:
Add support for RTEMS
* Add image information to README
* Fix dual PCMCIA slot support (when running with just one
slot populated)
* Add VFD type detection to trab board
* extend drivers/cs8900.c driver to synchronize ethaddr environment
variable with value in the EEPROM
* Start adding MIPS support files
* Patch by Rod Boyce, 21 Nov 2002:
fix PCMCIA on MBX8xx board
* Patch by Pierre Aubert , 21 Nov 2002
Add CFG_CPM_POST_WORD_ADDR to make the offset of the
bootmode word in DPRAM configurable
Add support for i386 architecture and AMD SC520 board
* Patch by Pierre Aubert, 12 Nov 2002:
Add support for DOS filesystem and booting from DOS floppy disk
