path: root/board/sc3
2007-07-04board/[k-z]*: Augment CONFIG_COMMANDS tests with defined(CONFIG_CMD_*).Jon Loeliger
2007-03-13Make SC3 board build with 'make O='; use 'addcons' consistentlyWolfgang Denk
(SC3 and Jupiter used to use 'addcon' instead). Signed-off-by: Wolfgang Denk wd@denx.de
2007-01-18[PATCH] Fix: Compilerwarnings for SC3 board.Heiko Schocher
The EBC Configuration Register is now by CFG_EBC_CFG definable Added JFFS2 support for the SC3 board. Signed-off-by: Heiko Schocher <hs@denx.de>
2007-01-16Raname solidcard3 into sc3; add redundant env for sc3Wolfgang Denk
