The change is currently needed to be able to remove the board
configuration scripting from the top level Makefile and replace it by
a simple, table driven script.
Moving this configuration setting into the "CONFIG_*" name space is
also desirable because it is needed if we ever should move forward to
a Kconfig driven configuration system.
This cleanup is done by creating header files for all SoC versions and
moving the SoC specific defines into these special headers. This way the
common header ppc405.h and ppc440.h can be cleaned up finally.
As a part from this cleanup, the GPIO definitions for PPC405EP are
corrected. The high and low parts of the registers (for example
CONFIG_SYS_GPIO0_OSRL vs. CONFIG_SYS_GPIO0_OSRH) have been defined in
the wrong order. This patch now fixes this issue by switching these
xxxH and xxxL values. This brings the GPIO 405EP port in sync with all
other PPC4xx ports.
This patch moves some ppc4xx related headers from the common include
directory (include/) to the powerpc specific one
(arch/powerpc/include/asm/). This way to common include directory is not
so cluttered with files.
Update image size after addition of new environment handling.
As discussed on the list, move "arch/ppc" to "arch/powerpc" to
better match the Linux directory structure.
Please note that this patch also changes the "ppc" target in
MAKEALL to "powerpc" to match this new infrastructure. But "ppc"
is kept as an alias for now, to not break compatibility with
scripts using this name.
Acked-by: Wolfgang Denk <wd@denx.de>
Acked-by: Detlev Zundel <dzu@denx.de>
Acked-by: Kim Phillips <kim.phillips@freescale.com>
Cc: Peter Tyser <ptyser@xes-inc.com>
Now that the other architecture-specific lib directories have been
moved out of the top-level directory there's not much reason to have the
'_generic' suffix on the common lib directory.
Also move lib_$ARCH/config.mk to arch/$ARCH/config.mk
This change is intended to clean up the top-level directory structure
and more closely mimic Linux's directory organization.
The following changes allow U-Boot to fully relocate from flash to
RAM:
- Remove linker scripts' .fixup sections from the .text section
- Add -mrelocatable to PLATFORM_RELFLAGS for all boards
- Define CONFIG_RELOC_FIXUP_WORKS for all boards
Previously, U-Boot would partially relocate, but statically initialized
pointers needed to be manually relocated.
The latest PPC4xx register cleanup patch missed some SDRAM defines.
This patch now changes lower case UIC defines to upper case. Also
some names are changed to match the naming in the IBM/AMCC users
manuals (e.g. mem_mcopt1 -> SDRAM0_CFG).
The latest PPC4xx register cleanup patch missed the UIC defines.
This patch cleans up multiple issues of the 4xx register (mostly
DCR, SDR, CPR, etc) definitions:
- Change lower case defines to upper case (plb4_acr -> PLB4_ACR)
- Change the defines to better match the names from the
user's manuals (e.g. cprpllc -> CPR0_PLLC)
- Removal of some unused defines
Please test this patch intensive on your PPC4xx platform. Even though
I tried not to break anything and tested successfully on multiple
4xx AMCC platforms, testing on custom platforms is recommended.
It was brought to our attention that U-Boot contains code derived from the
IBM OpenBIOS source code originally provided with some of the older PowerPC
4xx development boards. As a result, the original license of this code has
been carried in the various files for a number of years in the U-Boot project.
IBM is dual-licensing the IBM code contributions already present in U-Boot
under either the terms of the GNU General Public License version 2, or the
original code license already present.
Signed-off-by: Josh Boyer <jwboyer@linux.vnet.ibm.com>
A recent gcc added a new unaligned rodata section called '.rodata.str1.1',
which needs to be added the the linker script. Instead of just adding this
one section, we use a wildcard ".rodata*" to get all rodata linker section
gcc has now and might add in the future.
However, '*(.rodata*)' by itself will result in sub-optimal section
ordering. The sections will be sorted by object file, which causes extra
padding between the unaligned rodata.str.1.1 of one object file and the
aligned rodata of the next object file. This is easy to fix by using the
SORT_BY_ALIGNMENT command.
This patch has not be tested one most of the boards modified. Some boards
have a linker script that looks something like this:
*(.text)
. = ALIGN(16);
*(.rodata)
*(.rodata.str1.4)
*(.eh_frame)
I change this to:
*(.text)
. = ALIGN(16);
*(.eh_frame)
*(SORT_BY_ALIGNMENT(SORT_BY_NAME(.rodata*)))
This means the start of rodata will no longer be 16 bytes aligned.
However, the boundary between text and rodata/eh_frame is still aligned to
16 bytes, which is what I think the real purpose of the ALIGN call is.
Signed-off-by: Trent Piepho <xyzzy@speakeasy.org>
Most of the bss initialization loop increments 4 bytes
at a time. And the loop end is checked for an 'equal'
condition. Make the bss end address aligned by 4, so
that the loop will end as expected.
Signed-off-by: Selvamuthukumar <selva.muthukumar@e-coninfotech.com>
Affected boards:
db64360
db64460
katmai
taihu
taishan
yucca
cpc45
cpu87
eXalion
elppc
debris
kvme080
mpc8315erdb
integratorap
ixdp425
oxc
pm826
pm828
pm854
pm856
ppmc7xx
sc3
sc520_spunk
sorcery
tqm8272
tqm85xx
utx8245
Removed initialization of the driver from net/eth.c
Also, wrapped contents of pci_eth_init() by CONFIG_PCI.
- Fixing leading white spaces
- Fixing indentation where 4 spaces are used instead of tab
- Removing C++ comments (//), wherever I introduced them
Signed-off-by: William Juul <william.juul@tandberg.com>
A lot changed in the Linux MTD code, since it was last ported from
Linux to U-Boot. This patch takes U-Boot NAND support to the level
of Linux 2.6.22.1 and will enable support for very large NAND devices
(4KB pages) and ease the compatibility between U-Boot and Linux
filesystems.
This patch is tested on two custom boards with PPC and ARM
processors running YAFFS in U-Boot and Linux using gcc-4.1.2
cross compilers.
MAKEALL ppc/arm has some issues:
* DOC/OneNand/nand_spl is not building (I have not tried porting
these parts, and since I do not have any HW and I am not familiar
with this code/HW I think its best left to someone else.)
Except for the issues mentioned above, I have ported all drivers
necessary to run MAKEALL ppc/arm without errors and warnings. Many
drivers were trivial to port, but some were not so trivial. The
following drivers must be examined carefully and maybe rewritten to
some degree:
cpu/ppc4xx/ndfc.c
cpu/arm926ejs/davinci/nand.c
board/delta/nand.c
board/zylonite/nand.c
Signed-off-by: Stig Olsen <stig.olsen@tandberg.com>
This patch changes the return type of initdram() from long int to phys_size_t.
This is required for a couple of reasons: long int limits the amount of dram
to 2GB, and u-boot in general is moving over to phys_size_t to represent the
size of physical memory. phys_size_t is defined as an unsigned long on almost
all current platforms.
This patch *only* changes the return type of the initdram function (in
include/common.h, as well as in each board's implementation of initdram). It
does not actually modify the code inside the function on any of the platforms;
platforms which wish to support more than 2GB of DRAM will need to modify
their initdram() function code.
Build tested with MAKEALL for ppc, arm, mips, mips-el. Booted on powerpc
MPC8641HPCN.
Signed-off-by: Becky Bruce <becky.bruce@freescale.com>
This commit gets rid of a huge amount of silly white-space issues.
Especially, all sequences of SPACEs followed by TAB characters get
removed (unless they appear in print statements).
Also remove all embedded "vim:" and "vi:" statements which hide
indentation problems.
The cross compiler is responsible for providing the correct libraries
and the logic to find the linking libraries.
Signed-off-by: Jason Wessel <jason.wessel@windriver.com>
With recent toolchain versions, some boards would not build because
or errors like this one (here for ocotea board when building with
ELDK 4.2 beta):
ppc_4xx-ld: section .bootpg [fffff000 -> fffff23b] overlaps section .bss [fffee900 -> fffff8ab]
For many boards, the .bss section is big enough that it wraps around
at the end of the address space (0xFFFFFFFF), so the problem will not
be visible unless you use a 64 bit tool chain for development. On
some boards however, changes to the code size (due to different
optimizations) we bail out with section overlaps like above.
The fix is to add the NOLOAD attribute to the .bss and .sbss
sections, telling the linker that .bss does not consume any space in
the image.
Signed-off-by: Marcel Ziswiler <marcel@ziswiler.com>
Change all linker scripts to reference the changed driver name 4xx_uart.o.
Note: In most cased all these explicit referencing of these object files
in the linker scripts is not neccessary. Only for manually embedded
environment into the U-Boot image, which is not done is most cases.
This is a compatibility step that allows both the older form
and the new form to co-exist for a while until the older can
be removed entirely.
All transformations are of the form:
Before:
#if (CONFIG_COMMANDS & CFG_CMD_AUTOSCRIPT)
After:
#if (CONFIG_COMMANDS & CFG_CMD_AUTOSCRIPT) || defined(CONFIG_CMD_AUTOSCRIPT)
(SC3 and Jupiter used to use 'addcon' instead).
Signed-off-by: Wolfgang Denk wd@denx.de
The EBC Configuration Register is now by CFG_EBC_CFG definable
Added JFFS2 support for the SC3 board.
