path: root/board/sc3/sc3.c
2010-09-23ppc4xx: Big header cleanup part 2, mostly PPC405 relatedStefan Roese
This cleanup is done by creating header files for all SoC versions and moving the SoC specific defines into these special headers. This way the common header ppc405.h and ppc440.h can be cleaned up finally. As a part from this cleanup, the GPIO definitions for PPC405EP are corrected. The high and low parts of the registers (for example CONFIG_SYS_GPIO0_OSRL vs. CONFIG_SYS_GPIO0_OSRH) have been defined in the wrong order. This patch now fixes this issue by switching these xxxH and xxxL values. This brings the GPIO 405EP port in sync with all other PPC4xx ports. Signed-off-by: Stefan Roese <sr@denx.de>
2009-09-28ppc4xx: Convert PPC4xx SDRAM defines from lower case to upper caseStefan Roese
The latest PPC4xx register cleanup patch missed some SDRAM defines. This patch now changes lower case UIC defines to upper case. Also some names are changed to match the naming in the IBM/AMCC users manuals (e.g. mem_mcopt1 -> SDRAM0_CFG). Signed-off-by: Stefan Roese <sr@denx.de>
2009-09-28ppc4xx: Convert PPC4xx UIC defines from lower case to upper caseStefan Roese
The latest PPC4xx register cleanup patch missed the UIC defines. This patch now changes lower case UIC defines to upper case. Signed-off-by: Stefan Roese <sr@denx.de>
2009-09-11ppc4xx: Big cleanup of PPC4xx definesStefan Roese
This patch cleans up multiple issues of the 4xx register (mostly DCR, SDR, CPR, etc) definitions: - Change lower case defines to upper case (plb4_acr -> PLB4_ACR) - Change the defines to better match the names from the user's manuals (e.g. cprpllc -> CPR0_PLLC) - Removal of some unused defines Please test this patch intensive on your PPC4xx platform. Even though I tried not to break anything and tested successfully on multiple 4xx AMCC platforms, testing on custom platforms is recommended. Signed-off-by: Stefan Roese <sr@denx.de>
2008-09-02Moved initialization of EEPRO100 Ethernet controller to board_eth_init()Ben Warren
Affected boards: db64360 db64460 katmai taihu taishan yucca cpc45 cpu87 eXalion elppc debris kvme080 mpc8315erdb integratorap ixdp425 oxc pm826 pm828 pm854 pm856 ppmc7xx sc3 sc520_spunk sorcery tqm8272 tqm85xx utx8245 Removed initialization of the driver from net/eth.c Also, wrapped contents of pci_eth_init() by CONFIG_PCI. Signed-off-by: Ben Warren <biggerbadderben@gmail.com>
2008-01-09fix comments with new drivers organizationMarcel Ziswiler
Signed-off-by: Marcel Ziswiler <marcel@ziswiler.com>
2007-01-18[PATCH] Fix: Compilerwarnings for SC3 board.Heiko Schocher
The EBC Configuration Register is now by CFG_EBC_CFG definable Added JFFS2 support for the SC3 board. Signed-off-by: Heiko Schocher <hs@denx.de>
2007-01-16Raname solidcard3 into sc3; add redundant env for sc3Wolfgang Denk
