path: root/board/sbc8641d
2017-04-13board_f: Rename initdram() to dram_init()Simon Glass
This allows us to use the same DRAM init function on all archs. Add a dummy function for arc, which does not use DRAM init here. Signed-off-by: Simon Glass <sjg@chromium.org> [trini: Dummy function on nios2] Signed-off-by: Tom Rini <trini@konsulko.com>
2017-04-05board_f: Drop return value from initdram()Simon Glass
At present we cannot use this function as an init sequence call without a wrapper, since it returns the RAM size. Adjust it to set the RAM size in global_data instead, and return 0 on success. Signed-off-by: Simon Glass <sjg@chromium.org> Reviewed-by: Stefan Roese <sr@denx.de>
2017-04-05board_f: Drop board_type parameter from initdram()Simon Glass
It looks like only cm5200 and tqm8xx use this feature, so we don't really need it in generic code. Drop it and have the users access gd->board_type directly. Signed-off-by: Simon Glass <sjg@chromium.org> Reviewed-by: Stefan Roese <sr@denx.de>
2016-02-06Use correct spelling of "U-Boot"Bin Meng
Correct spelling of "U-Boot" shall be used in all written text (documentation, comments in source files etc.). Signed-off-by: Bin Meng <bmeng.cn@gmail.com> Reviewed-by: Heiko Schocher <hs@denx.de> Reviewed-by: Simon Glass <sjg@chromium.org> Reviewed-by: Minkyu Kang <mk7.kang@samsung.com>
2016-01-19Add more SPDX-License-Identifier tagsTom Rini
In a number of places we had wordings of the GPL (or LGPL in a few cases) license text that were split in such a way that it wasn't caught previously. Convert all of these to the correct SPDX-License-Identifier tag. Signed-off-by: Tom Rini <trini@konsulko.com>
2015-10-19sbc8641d: increase monitor size from 256k to 384kPaul Gortmaker
Between v2015.07-rc1 and v2015.07-rc2 this board started silent boot failure. A bisect led to commit 6eed3786c68c8a49d ("net: Move the CMD_NET config to defconfigs"). This commit looks harmless in itself, but it did implicitly add a feature to the image which led to this: u-boot$git describe 6eed3786c68c8a49d v2015.07-rc1-412-g6eed3786c68c ^^^ u-boot$ls -l ../41*/u-boot.bin -rwxrwxr-x 1 paul paul 261476 Oct 16 16:47 ../411/u-boot.bin -rwxrwxr-x 1 paul paul 266392 Oct 16 16:43 ../412/u-boot.bin u-boot$bc bc 1.06.95 Copyright 1991-1994, 1997, 1998, 2000, 2004, 2006 Free Software Foundation, Inc. This is free software with ABSOLUTELY NO WARRANTY. For details type `warranty'. 256*1024 262144 i.e. we finally broke through the 256k monitor size. Jump it up to 384k and fix the hard coded value used in the env offset at the same time. We were probably flirting with the 256k size issue without knowing it when testing on different baselines in earlier commits, but since this is all board specific, a rebase or reorder to put this commit 1st is of little value. Signed-off-by: Paul Gortmaker <paul.gortmaker@windriver.com>
2015-10-19sbc8641d: add basic flash setup instructions to README filePaul Gortmaker
...so that I don't have to go work them out from scratch again by peering at the manual. Signed-off-by: Paul Gortmaker <paul.gortmaker@windriver.com>
2014-11-21fdt: Allow ft_board_setup() to report failureSimon Glass
This function can fail if the device tree runs out of space. Rather than silently booting with an incomplete device tree, allow the failure to be detected. Unfortunately this involves changing a lot of places in the code. I have not changed behvaiour to return an error where one is not currently returned, to avoid unexpected breakage. Eventually it would be nice to allow boards to register functions to be called to update the device tree. This would avoid all the many functions to do this. However it's not clear yet if this should be done using driver model or with a linker list. This work is left for later. Signed-off-by: Simon Glass <sjg@chromium.org> Acked-by: Anatolij Gustschin <agust@denx.de>
2013-11-25Driver/DDR: combine ccsr_ddr for 83xx, 85xx and 86xxYork Sun
Fix ccsr_ddr structure to avoid using typedef. Combine DDR2 and DDR3 structure for 83xx, 85xx and 86xx. Signed-off-by: York Sun <yorksun@freescale.com>
2013-11-25Driver/DDR: Moving Freescale DDR driver to a common driverYork Sun
Freescale DDR driver has been used for mpc83xx, mpc85xx, mpc86xx SoCs. The similar DDR controllers will be used for ARM-based SoCs. Signed-off-by: York Sun <yorksun@freescale.com>
2012-07-29doc: cleanup - move board READMEs into respective board directoriesWolfgang Denk
Also drop a few files referring to no longer / not yet supported boards. Signed-off-by: Wolfgang Denk <wd@denx.de> Cc: Prafulla Wadaskar <prafulla@marvell.com> Cc: Stefan Roese <sr@denx.de> Cc: Kim Phillips <kim.phillips@freescale.com> Cc: Andy Fleming <afleming@gmail.com> Cc: Jason Jin <jason.jin@freescale.com> Cc: Stefano Babic <sbabic@denx.de> Cc: Daniel Schwierzeck <daniel.schwierzeck@googlemail.com> Acked-by: Stefano Babic <sbabic@denx.de> Acked-by: Daniel Schwierzeck <daniel.schwierzeck@googlemail.com>
2011-07-29MPC8xxx: drop redundant boot messagesWolfgang Denk
Current code would print RAM size information like this: DRAM: DDR: 256 MiB (DDR1, 64-bit, CL=2, ECC off) Turn a number of printf()s into debug() to get rid of the redundant "DDR: " string like this: DRAM: 256 MiB (DDR1, 64-bit, CL=2, ECC off) Signed-off-by: Wolfgang Denk <wd@denx.de> Acked-by: York Sun <yorksun@freescale.com> Signed-off-by: Kumar Gala <galak@kernel.crashing.org>
2011-04-04powerpc/8xxx: Refactor fsl_ddr_get_spd into common code from boardKumar Gala
Move fsl_ddr_get_spd into common mpc8xxx/ddr/main.c as most boards pretty much do the same thing. The only variations are in how many controllers or DIMMs per controller exist. To make this work we standardize on the names of the SPD_EEPROM_ADDRESS defines based on the use case of the board. We allow boards to override get_spd to either do board specific fixups to the SPD data or deal with any unique behavior of how the SPD eeproms are wired up. Signed-off-by: Kumar Gala <galak@kernel.crashing.org>
2011-04-04powerpc/8xxx: Replace fsl_ddr_get_mem_data_rate with get_ddr_freq()Kumar Gala
Every 85xx board implements fsl_ddr_get_mem_data_rate via get_ddr_freq() and every 86xx board uses get_bus_freq(). If implement get_ddr_freq() as a static inline to call get_bus_freq() we can remove fsl_ddr_get_mem_data_rate altogether and just call get_ddr_freq() directly. Signed-off-by: Kumar Gala <galak@kernel.crashing.org>
2011-04-04powerpc: Move cpu specific lmb reserve to arch_lmb_reserveKumar Gala
We've been utilizing board_lmb_reserve to reserve the boot page for MP systems. We can just move this into arch_lmb_reserve for 85xx & 86xx systems rather than duplicating in each board port. Signed-off-by: Kumar Gala <galak@kernel.crashing.org>
2011-01-14powerpc/86xx: Convert SBC8641 to use common SRIO init codeKumar Gala
Signed-off-by: Kumar Gala <galak@kernel.crashing.org> Tested-by: Paul Gortmaker <paul.gortmaker@windriver.com>
2011-01-14powerpc/86xx: Rework SBC8641 pci_init_board to use common FSL PCIe codeKumar Gala
Remove duplicated code in SBC8641 board and utilize the common fsl_pcie_init_board(). We also now dynamically setup the LAWs for PCI controllers based on which PCIe controllers are enabled. Signed-off-by: Kumar Gala <galak@kernel.crashing.org> CC: Paul Gortmaker <paul.gortmaker@windriver.com>
2011-01-14powerpc/8xxx: Replace is_fsl_pci_cfg with is_serdes_configuredKumar Gala
Now that we have serdes support for all 85xx/86xx/Pxxx chips we can replace the is_fsl_pci_cfg() code with the is_serdes_configured(). Signed-off-by: Kumar Gala <galak@kernel.crashing.org>
2010-11-14fsl: Clean up printing of PCI boot infoPeter Tyser
Previously boards used a variety of indentations, newline styles, and colon styles for the PCI information that is printed on bootup. This patch unifies the style to look like: ... NAND: 1024 MiB PCIE1: connected as Root Complex Scanning PCI bus 01 04 01 8086 1010 0200 00 04 01 8086 1010 0200 00 03 00 10b5 8112 0604 00 02 01 10b5 8518 0604 00 02 02 10b5 8518 0604 00 08 00 1957 0040 0b20 00 07 00 10b5 8518 0604 00 09 00 10b5 8112 0604 00 07 01 10b5 8518 0604 00 07 02 10b5 8518 0604 00 06 00 10b5 8518 0604 00 02 03 10b5 8518 0604 00 01 00 10b5 8518 0604 00 PCIE1: Bus 00 - 0b PCIE2: connected as Root Complex Scanning PCI bus 0d 0d 00 1957 0040 0b20 00 PCIE2: Bus 0c - 0d In: serial ... Signed-off-by: Peter Tyser <ptyser@xes-inc.com> CC: wd@denx.de CC: sr@denx.de CC: galak@kernel.crashing.org
2010-10-2086xx: Create common linker scriptKumar Gala
Signed-off-by: Peter Tyser <ptyser@xes-inc.com> Signed-off-by: Kumar Gala <galak@kernel.crashing.org>
2010-10-20sbc8641d: Update PCI codePeter Tyser
Update to use the recent, common FSL PCI initialization code. Signed-off-by: Peter Tyser <ptyser@xes-inc.com> CC: joe.hamman@embeddedspecialties.com Signed-off-by: Kumar Gala <galak@kernel.crashing.org>
2010-07-20powerpc/85xx & 86xx: Rework ft_fsl_pci_setup to not require aliasesKumar Gala
Previously we used an alias the pci node to determine which node to fixup or delete. Now we use the new fdt_node_offset_by_compat_reg to find the node to update. Additionally, we replace the code in each board with a single macro call that makes assumes uniform naming and reduces duplication in this area. Signed-off-by: Kumar Gala <galak@kernel.crashing.org>
2010-07-20powerpc/86xx: Rename PCI1/2 to PCIE1/2 on MPC8641HPCN & SBC8641Kumar Gala
The MPC8641 boards actually only have PCIE not PCI. Rename so we are uniform with regards to names so we can replace this code with templated code. Signed-off-by: Kumar Gala <galak@kernel.crashing.org>
2010-07-20powerpc/86xx: Move PCI/PCIe address defines into common immap_86xx.hKumar Gala
Remove dupliacted setting of PCI/PCIe address and offsets in board config.h. Renamed CONFIG_SYS_PCI1/2_ADDR to CONFIG_SYS_PCI1/2ADDR on MPC8641 boards since its really PCIE controllers and not PCI. Signed-off-by: Kumar Gala <galak@kernel.crashing.org>
2010-04-13ppc: Move cpu/$CPU to arch/ppc/cpu/$CPUPeter Tyser
2010-04-13Rename lib_generic/ to lib/Peter Tyser
Now that the other architecture-specific lib directories have been moved out of the top-level directory there's not much reason to have the '_generic' suffix on the common lib directory. Signed-off-by: Peter Tyser <ptyser@xes-inc.com>
2010-04-13Move lib_$ARCH directories to arch/$ARCH/libPeter Tyser
Also move lib_$ARCH/config.mk to arch/$ARCH/config.mk This change is intended to clean up the top-level directory structure and more closely mimic Linux's directory organization. Signed-off-by: Peter Tyser <ptyser@xes-inc.com>
2009-11-0486xx: Remove redundant code in initdramBecky Bruce
The same code exists both inside an #ifdef and outside of it. Remove the extra code for all the 86xx boards. Signed-off-by: Becky Bruce <beckyb@kernel.crashing.org> Signed-off-by: Kumar Gala <galak@kernel.crashing.org>
2009-10-16sbc8641d: fix LAW so board doesn't hang on DDR initPaul Gortmaker
All versions between now and since this commit: commit bd76729bcbfd64b5d016a9b936f058931fc06eaf MPC86xx: set CONFIG_MAX_MEM_MAPPED to 2G by default will fail to allow the SBC8641D to get past DDR init, because the LAW config was overlapping. Eventually this board will do SPD EEPROM config, but for now this gets the board working again. Signed-off-by: Paul Gortmaker <paul.gortmaker@windriver.com> Signed-off-by: Kumar Gala <galak@kernel.crashing.org>
2009-10-03ppc: Enable full relocation to RAMPeter Tyser
The following changes allow U-Boot to fully relocate from flash to RAM: - Remove linker scripts' .fixup sections from the .text section - Add -mrelocatable to PLATFORM_RELFLAGS for all boards - Define CONFIG_RELOC_FIXUP_WORKS for all boards Previously, U-Boot would partially relocate, but statically initialized pointers needed to be manually relocated. Signed-off-by: Peter Tyser <ptyser@xes-inc.com>
2009-08-2886xx: Remove redudant PLATFORM_CPPFLAGSKumar Gala
For historic reasons we had defined some additional PLATFORM_CPPFLAGS like: PLATFORM_CPPFLAGS += -DCONFIG_MPC86xx=1 PLATFORM_CPPFLAGS += -DCONFIG_MPC8641=1 However these are all captured in the config.h and thus redudant. Also moved common 86xx flags into cpu/mpc86xx/config.mk. Signed-off-by: Kumar Gala <galak@kernel.crashing.org>
2009-08-28pci/fsl_pci_init: Fold fsl_pci_setup_inbound_windows into fsl_pci_initKumar Gala
Every platform that calls fsl_pci_init calls fsl_pci_setup_inbound_windows before it calls fsl_pci_init. There isn't any reason to just call it from fsl_pci_init and simplify things a bit. Signed-off-by: Kumar Gala <galak@kernel.crashing.org>
2009-08-28pci/fsl_pci_init: Fold pci_setup_indirect into fsl_pci_initKumar Gala
Every platform that calls fsl_pci_init calls pci_setup_indirect before it calls fsl_pci_init. There isn't any reason to just call it from fsl_pci_init and simplify things a bit. Signed-off-by: Kumar Gala <galak@kernel.crashing.org>
2009-07-2286xx: Rename ccsr_ddr's sdram_mode_1, sdram_cfg_1 fieldsPeter Tyser
Rename sdram_mode_1 to sdram_mode and sdram_cfg_1 to sdram_cfg to match the 86xx user's manual and other Freescale architectures Signed-off-by: Peter Tyser <ptyser@xes-inc.com> Signed-off-by: Kumar Gala <galak@kernel.crashing.org>
2009-04-04fsl_pci: Move prototypes into fsl_pci.h and remove explicit externsKumar Gala
2009-04-04fsl_pci: Renamed immap_fsl_pci.h to fsl_pci.hKumar Gala
Rename the pci header for FSL HW so we can move some prototypes in there and stop doing explicit externs Signed-off-by: Kumar Gala <galak@kernel.crashing.org>
2009-04-0186xx: Cleanup MP supportKumar Gala
* Use CONFIG_MP instead of CONFIG_NUM_CPUS to match 85xx * Introduce determine_mp_bootpg() helper. We'll need this to address a bug introduced in v2009.03 with 86xx MP booting. We have to make sure to reserve the region of memory used for the MP bootpg() so other u-boot code doesn't use it. * Added dummy versions of cpu_reset(), cpu_status() & cpu_release() to allow cmd_mp.c to build and work. In the future we should look at implementing all these functions. This could be common w/85xx if we use spin tables on 86xx. Signed-off-by: Kumar Gala <galak@kernel.crashing.org>
2009-03-31mpc8641hpcn/sbc8641d: Add missing board_lmb_reservesBecky Bruce
We're missing the board_lmb_reserve definitions that allow cpu_mp_lmb_reserve to be called; this means that Linux is free to reallocate reserved pages. Linux currently boots because we're getting lucky - the page we've reserved is high enough in memory that it isn't allocated by Linux while we still need it to be in existence. Signed-off-by: Becky Bruce <beckyb@kernel.crashing.org> Signed-off-by: Kumar Gala <galak@kernel.crashing.org>
