path: root/board/sbc8641d
2010-04-13ppc: Move cpu/$CPU to arch/ppc/cpu/$CPUPeter Tyser
2010-04-13Rename lib_generic/ to lib/Peter Tyser
Now that the other architecture-specific lib directories have been moved out of the top-level directory there's not much reason to have the '_generic' suffix on the common lib directory. Signed-off-by: Peter Tyser <ptyser@xes-inc.com>
2010-04-13Move lib_$ARCH directories to arch/$ARCH/libPeter Tyser
Also move lib_$ARCH/config.mk to arch/$ARCH/config.mk This change is intended to clean up the top-level directory structure and more closely mimic Linux's directory organization. Signed-off-by: Peter Tyser <ptyser@xes-inc.com>
2009-11-0486xx: Remove redundant code in initdramBecky Bruce
The same code exists both inside an #ifdef and outside of it. Remove the extra code for all the 86xx boards. Signed-off-by: Becky Bruce <beckyb@kernel.crashing.org> Signed-off-by: Kumar Gala <galak@kernel.crashing.org>
2009-10-16sbc8641d: fix LAW so board doesn't hang on DDR initPaul Gortmaker
All versions between now and since this commit: commit bd76729bcbfd64b5d016a9b936f058931fc06eaf MPC86xx: set CONFIG_MAX_MEM_MAPPED to 2G by default will fail to allow the SBC8641D to get past DDR init, because the LAW config was overlapping. Eventually this board will do SPD EEPROM config, but for now this gets the board working again. Signed-off-by: Paul Gortmaker <paul.gortmaker@windriver.com> Signed-off-by: Kumar Gala <galak@kernel.crashing.org>
2009-10-03ppc: Enable full relocation to RAMPeter Tyser
The following changes allow U-Boot to fully relocate from flash to RAM: - Remove linker scripts' .fixup sections from the .text section - Add -mrelocatable to PLATFORM_RELFLAGS for all boards - Define CONFIG_RELOC_FIXUP_WORKS for all boards Previously, U-Boot would partially relocate, but statically initialized pointers needed to be manually relocated. Signed-off-by: Peter Tyser <ptyser@xes-inc.com>
2009-08-2886xx: Remove redudant PLATFORM_CPPFLAGSKumar Gala
For historic reasons we had defined some additional PLATFORM_CPPFLAGS like: PLATFORM_CPPFLAGS += -DCONFIG_MPC86xx=1 PLATFORM_CPPFLAGS += -DCONFIG_MPC8641=1 However these are all captured in the config.h and thus redudant. Also moved common 86xx flags into cpu/mpc86xx/config.mk. Signed-off-by: Kumar Gala <galak@kernel.crashing.org>
2009-08-28pci/fsl_pci_init: Fold fsl_pci_setup_inbound_windows into fsl_pci_initKumar Gala
Every platform that calls fsl_pci_init calls fsl_pci_setup_inbound_windows before it calls fsl_pci_init. There isn't any reason to just call it from fsl_pci_init and simplify things a bit. Signed-off-by: Kumar Gala <galak@kernel.crashing.org>
2009-08-28pci/fsl_pci_init: Fold pci_setup_indirect into fsl_pci_initKumar Gala
Every platform that calls fsl_pci_init calls pci_setup_indirect before it calls fsl_pci_init. There isn't any reason to just call it from fsl_pci_init and simplify things a bit. Signed-off-by: Kumar Gala <galak@kernel.crashing.org>
2009-07-2286xx: Rename ccsr_ddr's sdram_mode_1, sdram_cfg_1 fieldsPeter Tyser
Rename sdram_mode_1 to sdram_mode and sdram_cfg_1 to sdram_cfg to match the 86xx user's manual and other Freescale architectures Signed-off-by: Peter Tyser <ptyser@xes-inc.com> Signed-off-by: Kumar Gala <galak@kernel.crashing.org>
2009-04-04fsl_pci: Move prototypes into fsl_pci.h and remove explicit externsKumar Gala
2009-04-04fsl_pci: Renamed immap_fsl_pci.h to fsl_pci.hKumar Gala
Rename the pci header for FSL HW so we can move some prototypes in there and stop doing explicit externs Signed-off-by: Kumar Gala <galak@kernel.crashing.org>
2009-04-0186xx: Cleanup MP supportKumar Gala
* Use CONFIG_MP instead of CONFIG_NUM_CPUS to match 85xx * Introduce determine_mp_bootpg() helper. We'll need this to address a bug introduced in v2009.03 with 86xx MP booting. We have to make sure to reserve the region of memory used for the MP bootpg() so other u-boot code doesn't use it. * Added dummy versions of cpu_reset(), cpu_status() & cpu_release() to allow cmd_mp.c to build and work. In the future we should look at implementing all these functions. This could be common w/85xx if we use spin tables on 86xx. Signed-off-by: Kumar Gala <galak@kernel.crashing.org>
2009-03-31mpc8641hpcn/sbc8641d: Add missing board_lmb_reservesBecky Bruce
We're missing the board_lmb_reserve definitions that allow cpu_mp_lmb_reserve to be called; this means that Linux is free to reallocate reserved pages. Linux currently boots because we're getting lucky - the page we've reserved is high enough in memory that it isn't allocated by Linux while we still need it to be in existence. Signed-off-by: Becky Bruce <beckyb@kernel.crashing.org> Signed-off-by: Kumar Gala <galak@kernel.crashing.org>
2009-02-1686xx: Reset updatePeter Tyser
Update the 86xx reset sequence to try executing a board-specific reset function. If the board-specific reset is not implemented or does not succeed, then assert #HRESET_REQ. Using #HRESET_REQ is a more standard reset procedure than the previous method and allows all board peripherals to be reset if needed. Signed-off-by: Peter Tyser <ptyser@xes-inc.com>
2009-01-13sbc8641d: Fix PCI mapping conceptsBecky Bruce
Rename _BASE to _BUS, as it's actually a PCI bus address, separate virtual and physical addresses into _VIRT and _PHYS, and use each appopriately. This makes the code easier to read and understand, and facilitates mapping changes going forward. Signed-off-by: Becky Bruce <beckyb@kernel.crashing.org>
2008-11-02Coding Style cleanup, update CHANGELOGWolfgang Denk
2008-10-3086xx: remove the unused ddr_enable_ecc in the board fileDave Liu
The DDR controller of 86xx processors have the ECC data init feature, and the new DDR code is using the feature, we don't need the way with DMA to init memory again. Signed-off-by: Dave Liu <daveliu@freescale.com> Acked-by: Kumar Gala <kumar.gala@freescale.com>
2008-10-2486xx: Convert all fsl_pci_init users to new APIsKumar Gala
Converted MPC8610HCPD, MPC8641HPCN, and SBC8641D to use fsl_pci_setup_inbound_windows() and ft_fsl_pci_setup(). With these changes the board code is a bit smaller and we get dma-ranges set in the device tree for these boards. Signed-off-by: Kumar Gala <galak@kernel.crashing.org> Signed-off-by: Andrew Fleming-AFLEMING <afleming@freescale.com> Acked-by: Jon Loeliger <jdl@freescale.com>
2008-10-18Pass dimm parameters to populate populate controller optionsHaiying Wang
Because some dimm parameters like n_ranks needs to be used with the board frequency to choose the board parameters like clk_adjust etc. in the board_specific_paramesters table of the board ddr file, we need to pass the dimm parameters to the board file. * move ddr dimm parameters header file from /cpu to /include directory. * add ddr dimm parameters to populate board specific options. * Fix fsl_ddr_board_options() for all the 8xxx boards which call this function. Signed-off-by: Haiying Wang <Haiying.Wang@freescale.com>
2008-08-27FSL DDR: Convert SBC8641D to new DDR code.Kumar Gala
2008-06-1185xx/86xx: Move to dynamic mgmt of LAWsKumar Gala
With the new LAW interface (set_next_law) we can move to letting the system allocate which LAWs are used for what purpose. This makes life a bit easier going forward with the new DDR code. Signed-off-by: Kumar Gala <galak@kernel.crashing.org> Signed-off-by: Andy Fleming <afleming@freescale.com> Acked-by: Jon Loeliger <jdl@freescale.com> Acked-by: Becky Bruce <becky.bruce@freescale.com>
2008-04-2985xx/86xx: Rename ext_refrec to timing_cfg_3 to match docsKumar Gala
All the 85xx and 86xx UM describe the register as timing_cfg_3 not as ext_refrec. Signed-off-by: Kumar Gala <galak@kernel.crashing.org>
2008-03-05Remove erroneous or extra spd.h #includers.Jon Loeliger
Many of the spd.h #includers don't need it, and wanted to have spd_sdram() declared instead. Since they didn't get that, some also had open coded extern declarations of it instead or as well. Fix it all up by using spd_sdram.h where needed. Signed-off-by: Jon Loeliger <jdl@freescale.com>
2008-02-2586xx: Fix renamed GUR symbols in sbc8641d board.Jon Loeliger
Back in commit a551cee99ad1d1da20fd23ad265de47448852f56 (86xx: Fix GUR PCI config registers properly), we should have changed the MPC86xx_PORBMSR_HA and MPC86xx_PORDEVSR_IO_SEL symbols in the sbc8641d board as well. Fix this oversight. Signed-off-by: Jon Loeliger <jdl@freescale.com>
2008-02-1886xx: Convert sbc8641d to use libfdt.Jon Loeliger
This is the proper fix for a missing closing brace in the function ft_cpu_setup() noticed by joe.hamman <at> embeddedspecialties.com. The ft_cpu_setup() function in mpc8641hpcn.c should have been removed earlier as it was under the obsolete CONFIG_OF_FLAT_TREE, but was missed. Only, the sbc8641d was nominally still using it. It all got ripped out, and the funcality that was in ft_board_setup() was refactored to remove the CPU portions into the new file cpu/mpc86xx/fdt.c instead. Make sbc8641d use this now. Based loosely on an original patch from joe.hamman@embeddedspecialties.com Signed-off-by: Jon Loeliger <jdl@freescale.com>
2008-01-2486xx: Remove old-style law setup codeBecky Bruce
This includes mpc8610hpcd, mpc8641hpcn, and sbc8641d. Signed-off-by: Becky Bruce <becky.bruce@freescale.com>
2008-01-2486xx: Convert sbc8641d to use new law setup code.Becky Bruce
2007-08-13Modify SBC8641D to use new Freescale PCI routinesJoe Hamman
PCI-Express sockets 1 and 2 verified working with Intel Pro/1000 PT adapter. Signed-off-by: Joe Hamman <joe.hamman@embeddedspecialties.com> Signde-off-by: Jon Loeliger <jdl@freescale.com>
2007-08-10Add support for SBC8641D. Board files.Joe Hamman
Add support for Wind River's SBC8641D reference board. Signed-off by: Joe Hamman <joe.hamman@embeddedspecialties.com> Acked-by: Wolfgang Denk <wd@denx.de> Acked-by: Jon Loeliger <jdl@freescale.com>
