path: root/board/sbc8641d
2008-08-27FSL DDR: Convert SBC8641D to new DDR code.Kumar Gala
2008-06-1185xx/86xx: Move to dynamic mgmt of LAWsKumar Gala
With the new LAW interface (set_next_law) we can move to letting the system allocate which LAWs are used for what purpose. This makes life a bit easier going forward with the new DDR code. Signed-off-by: Kumar Gala <galak@kernel.crashing.org> Signed-off-by: Andy Fleming <afleming@freescale.com> Acked-by: Jon Loeliger <jdl@freescale.com> Acked-by: Becky Bruce <becky.bruce@freescale.com>
2008-04-2985xx/86xx: Rename ext_refrec to timing_cfg_3 to match docsKumar Gala
All the 85xx and 86xx UM describe the register as timing_cfg_3 not as ext_refrec. Signed-off-by: Kumar Gala <galak@kernel.crashing.org>
2008-03-05Remove erroneous or extra spd.h #includers.Jon Loeliger
Many of the spd.h #includers don't need it, and wanted to have spd_sdram() declared instead. Since they didn't get that, some also had open coded extern declarations of it instead or as well. Fix it all up by using spd_sdram.h where needed. Signed-off-by: Jon Loeliger <jdl@freescale.com>
2008-02-2586xx: Fix renamed GUR symbols in sbc8641d board.Jon Loeliger
Back in commit a551cee99ad1d1da20fd23ad265de47448852f56 (86xx: Fix GUR PCI config registers properly), we should have changed the MPC86xx_PORBMSR_HA and MPC86xx_PORDEVSR_IO_SEL symbols in the sbc8641d board as well. Fix this oversight. Signed-off-by: Jon Loeliger <jdl@freescale.com>
2008-02-1886xx: Convert sbc8641d to use libfdt.Jon Loeliger
This is the proper fix for a missing closing brace in the function ft_cpu_setup() noticed by joe.hamman <at> embeddedspecialties.com. The ft_cpu_setup() function in mpc8641hpcn.c should have been removed earlier as it was under the obsolete CONFIG_OF_FLAT_TREE, but was missed. Only, the sbc8641d was nominally still using it. It all got ripped out, and the funcality that was in ft_board_setup() was refactored to remove the CPU portions into the new file cpu/mpc86xx/fdt.c instead. Make sbc8641d use this now. Based loosely on an original patch from joe.hamman@embeddedspecialties.com Signed-off-by: Jon Loeliger <jdl@freescale.com>
2008-01-2486xx: Remove old-style law setup codeBecky Bruce
This includes mpc8610hpcd, mpc8641hpcn, and sbc8641d. Signed-off-by: Becky Bruce <becky.bruce@freescale.com>
2008-01-2486xx: Convert sbc8641d to use new law setup code.Becky Bruce
2007-08-13Modify SBC8641D to use new Freescale PCI routinesJoe Hamman
PCI-Express sockets 1 and 2 verified working with Intel Pro/1000 PT adapter. Signed-off-by: Joe Hamman <joe.hamman@embeddedspecialties.com> Signde-off-by: Jon Loeliger <jdl@freescale.com>
2007-08-10Add support for SBC8641D. Board files.Joe Hamman
Add support for Wind River's SBC8641D reference board. Signed-off by: Joe Hamman <joe.hamman@embeddedspecialties.com> Acked-by: Wolfgang Denk <wd@denx.de> Acked-by: Jon Loeliger <jdl@freescale.com>
