path: root/board/sbc8560
2008-07-14sbc8560: add in ft_board_setup()Paul Gortmaker
Add in for the sbc8560, the ft_board_setup() routine, based on what is in use for the Freescale MPC8560ADS board. Signed-off-by: Paul Gortmaker <paul.gortmaker@windriver.com>
2008-07-14sbc8560: properly set cs0_bnds for 512MBPaul Gortmaker
The sbc8560 board ships with 512MB of memory installed, but the current cs0_bnds is hard coded for 256MB. Set the value based on CFG_SDRAM_SIZE. Signed-off-by: Paul Gortmaker <paul.gortmaker@windriver.com>
2008-06-1185xx/86xx: Move to dynamic mgmt of LAWsKumar Gala
With the new LAW interface (set_next_law) we can move to letting the system allocate which LAWs are used for what purpose. This makes life a bit easier going forward with the new DDR code. Signed-off-by: Kumar Gala <galak@kernel.crashing.org> Signed-off-by: Andy Fleming <afleming@freescale.com> Acked-by: Jon Loeliger <jdl@freescale.com> Acked-by: Becky Bruce <becky.bruce@freescale.com>
2008-03-2685xx: Add the concept of CFG_CCSRBAR_PHYSKumar Gala
When we go to 36-bit physical addresses we need to keep the concept of the physical CCSRBAR address seperate from the virtual one. For the majority of boards CFG_CCSBAR_PHYS == CFG_CCSRBAR Signed-off-by: Kumar Gala <galak@kernel.crashing.org>
2008-03-05Remove erroneous or extra spd.h #includers.Jon Loeliger
Many of the spd.h #includers don't need it, and wanted to have spd_sdram() declared instead. Since they didn't get that, some also had open coded extern declarations of it instead or as well. Fix it all up by using spd_sdram.h where needed. Signed-off-by: Jon Loeliger <jdl@freescale.com>
2008-01-1785xx: Convert SBC8540/SBC8560/SBC8548 to new TLB setupKumar Gala
2008-01-1685xx: Use proper defines for PCI addressesKumar Gala
We should be using the _MEM_PHYS for LAW and TLB setup and not _MEM_BASE. While _MEM_BASE & _MEM_PHYS are normally the same, _MEM_BASE should only be used for configuring the PCI ATMU. Signed-off-by: Kumar Gala <galak@kernel.crashing.org>
2008-01-1685xx: convert SBC8540/SBC8560/SBC8548 over to use new LAW init codeKumar Gala
2008-01-09Reworked FSL Book-E TLB macros to be more readableKumar Gala
The old macros made it difficult to know what WIMGE and perm bits were set for a TLB entry. Actually use the bit masks for these items since they are only a single bit. Also moved the macros into mmu.h out of e500.h since they aren't specific to e500. Signed-off-by: Kumar Gala <galak@kernel.crashing.org>
2007-12-11Stop using immap_t on 85xxKumar Gala
In the future the offsets to various blocks may not be in same location. Move to using CFG_MPC85xx_*_ADDR as the base of the registers instead of getting it via &immap. Signed-off-by: Kumar Gala <galak@kernel.crashing.org>
2007-12-11Stop using immap_t for guts offset on 85xxKumar Gala
In the future the offsets to various blocks may not be in same location. Move to using CFG_MPC85xx_GUTS_ADDR as the base of the guts registers instead of getting it via &immap->im_gur. Signed-off-by: Kumar Gala <galak@kernel.crashing.org>
2006-10-20Converted all 85xx boards to use a common FSL I2C driver.Jon Loeliger
Introduced COFIG_FSL_I2C to select the common FSL I2C driver. And removed hard i2c path from a few u-boot.lds scipts too. Minor whitespace cleanups along the way. Signed-off-by: Jon Loeliger <jdl@freescale.com>
2005-10-28Add support for multiple PHYs.Marian Balakowicz
2005-07-23* Patch by Jon Loeliger, Kumar Gala 2005-02-08Jon Loeliger
- Convert the CPM2 based functionality to use new CONFIG_CPM2 option rather than a myriad of CONFIG_MPC8560-like variants. Applies to MPC85xx and MPC8260 boards, includes stxgp3 and sbc8560. Eliminates the CONFIG_MPC8560 option entirely. Distributes the new CONFIG_CPM2 option to each 8260 board.
2004-10-10* Patch by Michael Bendzick, 30 Aug 2004:wdenk
- Improve platform.S code for omap1510inn that detects whether code is running from SDRAM or not. Patch allows SDRAM to be configured if code is running out of SRAM at 0x20000000. * Patch by Frederick Klatt, 30 Aug 2004: Add support for the Wind River SBC8540/SBC8560 boards
2004-08-01* Code cleanupwdenk
* Patch by Sascha Hauer, 28 Jun: - add generic support for Motorola i.MX architecture - add support for mx1ads, mx1fs2 and scb9328 boards * Patches by Marc Leeman, 23 Jul 2004: - Add define for the PCI/Memory Buffer Configuration Register - corrected comments in cpu/mpc824x/cpu_init.c * Add support for multiple serial interfaces (for example to allow modem dial-in / dial-out)
2004-07-10* Patch by Fred Klatt, 25 Jun 2004:wdenk
Add support for WindRiver's SBC8560 board * Patch by Nicolas Lacressonniere, 24 Jun 2004 Small Bugs fixes for "at91rm9200dk" board: - Timing modifications for SPI DataFlash access - Fix NAND flash detection bug * Patch by Nicolas Lacressonniere, 24 Jun 2004: Add Support for Flash AT49BV6416 for AT91RM9200DK board
