path: root/board/sbc8548
2008-04-2985xx/86xx: Rename ext_refrec to timing_cfg_3 to match docsKumar Gala
All the 85xx and 86xx UM describe the register as timing_cfg_3 not as ext_refrec. Signed-off-by: Kumar Gala <galak@kernel.crashing.org>
2008-03-2685xx: Add the concept of CFG_CCSRBAR_PHYSKumar Gala
When we go to 36-bit physical addresses we need to keep the concept of the physical CCSRBAR address seperate from the virtual one. For the majority of boards CFG_CCSBAR_PHYS == CFG_CCSRBAR Signed-off-by: Kumar Gala <galak@kernel.crashing.org>
2008-03-05Remove erroneous or extra spd.h #includers.Jon Loeliger
Many of the spd.h #includers don't need it, and wanted to have spd_sdram() declared instead. Since they didn't get that, some also had open coded extern declarations of it instead or as well. Fix it all up by using spd_sdram.h where needed. Signed-off-by: Jon Loeliger <jdl@freescale.com>
2008-02-27sbc8548: Fix Revision reading and unused variable 'path'Jean-Christophe PLAGNIOL-VILLARD
2008-01-1785xx: Convert SBC8540/SBC8560/SBC8548 to new TLB setupKumar Gala
2008-01-1685xx: Use proper defines for PCI addressesKumar Gala
We should be using the _MEM_PHYS for LAW and TLB setup and not _MEM_BASE. While _MEM_BASE & _MEM_PHYS are normally the same, _MEM_BASE should only be used for configuring the PCI ATMU. Signed-off-by: Kumar Gala <galak@kernel.crashing.org>
2008-01-1685xx: convert SBC8540/SBC8560/SBC8548 over to use new LAW init codeKumar Gala
2008-01-10Coding Style cleanup; update CHANGELOGWolfgang Denk
2008-01-09mpc85xx: Add support for SBC8548 (updated)Joe Hamman
Add support for Wind River's SBC8548 reference board. Signed-off by: Joe Hamman <joe.hamman@embeddedspecialties.com>
Add support for Wind River's SBC8548 reference board. Signed-off by: Joe Hamman <joe.hamman@embeddedspecialties.com> Signed-off by: Andy Fleming <afleming@freescale.com>
