path: root/board/sbc8349/sbc8349.c
2008-01-08mpc83xx: remove FLAT_TREE codeKim Phillips
need to rm it from pci code, too! Signed-off-by: Kim Phillips <kim.phillips@freescale.com>
2008-01-08sbc8349: migrate board to libfdtPaul Gortmaker
This adds libfdt support code for the Wind River sbc8349 board. Parallel of commit 3fde9e8b22cfbd7af489214758f9839a206576cb for the other Freescale 83xx boards. Signed-off-by: Paul Gortmaker <paul.gortmaker@windriver.com>
2008-01-08sbc8349: Remove board specific ECC codePaul Gortmaker
ECC code is now shared for all 83xx boards, so remove board specific one. See commit daab8c67d2defef73dc26ab07f0c3afd1b05d019 for reference. Signed-off-by: Paul Gortmaker <paul.gortmaker@windriver.com>
2007-08-16mpc83xx: implement board_add_ram_infoKim Phillips
add board_add_ram_info, to make memory diagnostic output more consistent. u-boot banner output now looks like: DRAM: 256 MB (DDR1, 64-bit, ECC on) and for boards with SDRAM on the local bus, a line such as this is added: SDRAM: 64 MB (local bus) also replaced some magic numbers with their equivalent define names. Signed-off-by: Kim Phillips <kim.phillips@freescale.com>
2007-03-02mpc83xx: U-Boot support for Wind River SBC8349Paul Gortmaker
I've redone the SBC8349 support to match git-current, which incorporates all the MPC834x updates from Freescale since the 1.1.6 release, including the DDR changes. I've kept all the SBC8349 files as parallel as possible to the MPC8349EMDS ones for ease of maintenance and to allow for easy inspection of what was changed to support this board. Hence the SBC8349 U-Boot has FDT support and everything else that the MPC8349EMDS has. Fortunately the Freescale updates added support for boards using CS0, but I had to change spd_sdram.c to allow for board specific settings for the sdram_clk_cntl (it is/was hard coded to zero, and that remains the default if the board doesn't specify a value.) Hopefully this should be mergeable as-is and require no whitespace cleanups or similar, but if something doesn't measure up then let me know and I'll fix it. Thanks, Paul.
