path: root/board/sbc8240
2011-10-01sbc82xx: delete support for obsolete SBC8240/SBC8260Paul Gortmaker
The EST SBC8260 is over 10 years old, and the SBC8240 older than that. With the tiny amount of RAM (by today's standards), there really isn't anyone interested in running the latest U-boot on these EOL products anymore. Signed-off-by: Paul Gortmaker <paul.gortmaker@windriver.com> CC: jon.diekema@smiths-aerospace.com
2008-09-02Moved initialization of TULIP Ethernet controller to board_eth_init()Ben Warren
Affected boards: cu824 bab7xx adciop dasa_sim mousse mpc8540eval musenki mvblue pcippc2/pcippc6 sbc8240 stxssa Removed initialization of the driver from net/eth.c Signed-off-by: Ben Warren <biggerbadderben@gmail.com>
2007-07-04Remove obsolete mpc824x linker scriptsGrant Likely
2004-07-10* Patch by Prakash Kumar, 27 Jun 2004:wdenk
Add support for the PXA250 based Intrinsyc Cerf board. * Patch by Yasushi Shoji, 27 Jun 2004: fix comment in include/common.h
2004-07-10* Rename SBC8560 into sbc8560 for consistencywdenk
* Patch by Daniel Poirot, 24 Jun 2004: Add support for Wind River's sbc8240 board * Patches by Yasushi Shoji, 26 Jun 2004: - drivers/serial_xuartlite.c: fix "return 0" in void function - add microblaze support to mkimage tool
