path: root/board/sbc8240/Makefile
2011-10-01sbc82xx: delete support for obsolete SBC8240/SBC8260Paul Gortmaker
The EST SBC8260 is over 10 years old, and the SBC8240 older than that. With the tiny amount of RAM (by today's standards), there really isn't anyone interested in running the latest U-boot on these EOL products anymore. Signed-off-by: Paul Gortmaker <paul.gortmaker@windriver.com> CC: jon.diekema@smiths-aerospace.com
2004-07-10* Rename SBC8560 into sbc8560 for consistencywdenk
* Patch by Daniel Poirot, 24 Jun 2004: Add support for Wind River's sbc8240 board * Patches by Yasushi Shoji, 26 Jun 2004: - drivers/serial_xuartlite.c: fix "return 0" in void function - add microblaze support to mkimage tool
