path: root/board/sandpoint
2007-07-04Remove obsolete mpc824x linker scriptsGrant Likely
2003-02-14Add "pcidelay" environment variable (in ms, enabled via CONFIG_PCI_BOOTDELAY).stroese
2002-08-14Initial revisionwdenk
2002-04-01Initial revisionwdenk
2002-01-09Initial revisionwdenk
2001-11-28Initial revisionwdenk
2001-10-15Initial revisionwdenk
2001-04-28Initial revisionwdenk
