path: root/board/sandburst
2010-04-24Merge branch 'master' of git://git.denx.de/u-boot-ppc4xxWolfgang Denk
2010-04-19ppc4xx: TLB init file cleanupStefan Roese
This patch adds new macros, with frequently used combinations of the 4xx TLB access control and storage attibutes. Additionally the 4xx init.S files are updated to make use of these new macros. Resulting in easier to read TLB definitions. Additionally some init.S files are updated to use the mmu header for the TLB defines, instead of defining their own macros. Signed-off-by: Stefan Roese <sr@denx.de>
2010-04-13ppc: Move cpu/$CPU to arch/ppc/cpu/$CPUPeter Tyser
2010-04-13Replace "#include <asm-$ARCH/$FILE>" with "#include <asm/$FILE>"Peter Tyser
The appropriate include/asm-$ARCH directory should already by symlinked to include/asm so using the whole "asm-$ARCH" path is unnecessary. This change should also allow us to move the include/asm-$ARCH directories into their appropriate lib/$ARCH/ directories. Signed-off-by: Peter Tyser <ptyser@xes-inc.com>
2010-04-13Rename lib_generic/ to lib/Peter Tyser
Now that the other architecture-specific lib directories have been moved out of the top-level directory there's not much reason to have the '_generic' suffix on the common lib directory. Signed-off-by: Peter Tyser <ptyser@xes-inc.com>
2010-04-13Move lib_$ARCH directories to arch/$ARCH/libPeter Tyser
Also move lib_$ARCH/config.mk to arch/$ARCH/config.mk This change is intended to clean up the top-level directory structure and more closely mimic Linux's directory organization. Signed-off-by: Peter Tyser <ptyser@xes-inc.com>
2009-12-22i2c, ppc4xx: fix compiling KAREF and METROBOX boards.Heiko Schocher
commit eb5eb2b0f744f0cba405160c5d01335c40f09acf ppc4xx: Cleanup PPC4xx I2C infrastructure This patch cleans up the PPC4xx I2C intrastructure: - Use C struct to describe the I2C registers instead of defines - Coding style cleanup (braces, whitespace, comments, line length) - Extract common code from i2c_read() and i2c_write() - Remove unneeded IIC defines from ppc405.h & ppc440.h breaks comiling for the KAREF and METROBOX boards. This patch fixes this issue. Signed-off-by: Heiko Schocher <hs@denx.de> Signed-off-by: Stefan Roese <sr@denx.de>
2009-11-19ppc4xx: Consolidate pci_pre_init() functionStefan Roese
This patch removes the duplicted implementations of the pci_pre_init() function by introducing a weak default function for it. This weak default has a different implementation for some PPC variants. It can be overridden by a board specific version. Signed-off-by: Stefan Roese <sr@denx.de>
2009-11-19ppc4xx: Consolidate pci_target_init() functionStefan Roese
This patch removes the duplicted implementations of the pci_target_init() function by introducing a weak default function for it. This weak default has a different implementation for 440EP(x)/GR(x) PPC's. It can be overridden by a board specific version (e.g. PMC440, korat). Signed-off-by: Stefan Roese <sr@denx.de> Acked-by: Matthias Fuchs <matthias.fuchs@esd.eu>
2009-11-09ppc4xx: Remove duplicated is_pci_host() functionsStefan Roese
This patch introduces a weak default function for is_pci_host(), returning 1. This is the default behaviour, since most boards only implement PCI host functionality. This weak default can be overridden by a board specific version if needed. Signed-off-by: Stefan Roese <sr@denx.de>
2009-11-02ppc4xx: Remove board specific linker scripts from most PPC4xx boardsStefan Roese
All these linker scripts can be removed since the new common ppc4xx linker script should be able to handle all of those boards. Please test and report problems. Thanks. Signed-off-by: Stefan Roese <sr@denx.de>
2009-10-09Merge branch 'reloc'Wolfgang Denk
2009-10-07ppc_4xx: Apply new HW register namesNiklaus Giger
Modify all existing *.c files to use the new register names as seen in the AMCC manuals. Signed-off-by: Niklaus Giger <niklaus.giger@member.fsf.org> Signed-off-by: Stefan Roese <sr@denx.de>
2009-10-03ppc: Enable full relocation to RAMPeter Tyser
The following changes allow U-Boot to fully relocate from flash to RAM: - Remove linker scripts' .fixup sections from the .text section - Add -mrelocatable to PLATFORM_RELFLAGS for all boards - Define CONFIG_RELOC_FIXUP_WORKS for all boards Previously, U-Boot would partially relocate, but statically initialized pointers needed to be manually relocated. Signed-off-by: Peter Tyser <ptyser@xes-inc.com>
2009-09-28ppc4xx: Convert PPC4xx SDRAM defines from lower case to upper caseStefan Roese
The latest PPC4xx register cleanup patch missed some SDRAM defines. This patch now changes lower case UIC defines to upper case. Also some names are changed to match the naming in the IBM/AMCC users manuals (e.g. mem_mcopt1 -> SDRAM0_CFG). Signed-off-by: Stefan Roese <sr@denx.de>
2009-09-28ppc4xx: Convert PPC4xx UIC defines from lower case to upper caseStefan Roese
The latest PPC4xx register cleanup patch missed the UIC defines. This patch now changes lower case UIC defines to upper case. Signed-off-by: Stefan Roese <sr@denx.de>
2009-09-11ppc4xx: Big cleanup of PPC4xx definesStefan Roese
This patch cleans up multiple issues of the 4xx register (mostly DCR, SDR, CPR, etc) definitions: - Change lower case defines to upper case (plb4_acr -> PLB4_ACR) - Change the defines to better match the names from the user's manuals (e.g. cprpllc -> CPR0_PLLC) - Removal of some unused defines Please test this patch intensive on your PPC4xx platform. Even though I tried not to break anything and tested successfully on multiple 4xx AMCC platforms, testing on custom platforms is recommended. Signed-off-by: Stefan Roese <sr@denx.de>
2009-06-12General help message cleanupWolfgang Denk
Many of the help messages were not really helpful; for example, many commands that take no arguments would not print a correct synopsis line, but "No additional help available." which is not exactly wrong, but not helpful either. Commit ``Make "usage" messages more helpful.'' changed this partially. But it also became clear that lots of "Usage" and "Help" messages (fields "usage" and "help" in struct cmd_tbl_s respective) were actually redundant. This patch cleans this up - for example: Before: => help dtt dtt - Digital Thermometer and Thermostat Usage: dtt - Read temperature from digital thermometer and thermostat. After: => help dtt dtt - Read temperature from Digital Thermometer and Thermostat Usage: dtt Signed-off-by: Wolfgang Denk <wd@denx.de>
2009-03-28Fix implicit declaration of function 'eth_[gs]etenv_enetaddr'Wolfgang Denk
...and some other compile warnings. Signed-off-by: Wolfgang Denk <wd@denx.de>
2009-03-27karef/metrobox/xpedite1k: fix eth_setenv_enetaddr typosMike Frysinger
The function is called "eth_setenv_enetaddr", not "eth_putenv_enetaddr". Signed-off-by: Mike Frysinger <vapier@gentoo.org> CC: Ben Warren <biggerbadderben@gmail.com>
2009-03-20boards: move board_get_enetaddr() into board-specific initMike Frysinger
The environment is the canonical storage location of the mac address, so we're killing off the global data location and moving everything to querying the env directly. Rather than have the common ppc code have board-specific hooks, move the board_get_enetaddr() function into the board-specific init functions. Signed-off-by: Mike Frysinger <vapier@gentoo.org> CC: Ben Warren <biggerbadderben@gmail.com>
2009-01-28Command usage cleanupPeter Tyser
Remove command name from all command "usage" fields and update common/command.c to display "name - usage" instead of just "usage". Also remove newlines from command usage fields. Signed-off-by: Peter Tyser <ptyser@xes-inc.com>
2008-12-06Update U-Boot's build timestamp on every compilePeter Tyser
Use the GNU 'date' command to auto-generate a new U-Boot timestamp on every compile. Signed-off-by: Peter Tyser <ptyser@xes-inc.com>
2008-11-09Moved PPC4xx EMAC driver to drivers/netBen Warren
Also changed path in all linker scripts that reference this driver Signed-off-by: Ben Warren <biggerbadderben@gmail.com> Acked-by: Stefan Roese <sr@denx.de>
2008-07-14Merge branch 'master' of /home/stefan/git/u-boot/u-boot into nextStefan Roese
2008-07-11Fix some more printf() format issues.Wolfgang Denk
2008-07-11ppc4xx: Rework 440GX UIC handlingStefan Roese
This patch reworks the 440GX interrupt handling so that the common 4xx code can be used. The 440GX is an exception to all other 4xx variants by having the cascading interrupt vectors not on UIC0 but on a special UIC named UICB0 (UIC Base 0). With this patch now, U-Boot references the 440GX UICB0 when UIC0 is selected. And the common 4xx interrupt handling is simpler without any 440GX special cases. Also some additional cleanup to cpu/ppc4xx/interrupt.c is done. Signed-off-by: Stefan Roese <sr@denx.de>
2008-07-11Fix some more print() format errors.Wolfgang Denk
2008-07-02Cleanup: remove redundant deleting on *~ filesWolfgang Denk
2007-10-31ppc4xx: Rework of 4xx serial driver (2)Stefan Roese
Change all linker scripts to reference the changed driver name 4xx_uart.o. Note: In most cased all these explicit referencing of these object files in the linker scripts is not neccessary. Only for manually embedded environment into the U-Boot image, which is not done is most cases. Signed-off-by: Stefan Roese <sr@denx.de>
2007-06-25ppc4xx: Add pci_pre_init() for 405 boardsStefan Roese
This patch removes the CFG_PCI_PRE_INIT option completely, since it's not needed anymore with the patch from Matthias Fuchs with the "weak" pci_pre_init() implementation. Signed-off-by: Stefan Roese <sr@denx.de>
2007-02-20[PATCH] PPC4xx: Add support for multiple I2C bussesStefan Roese
This patch adds support for multiple I2C busses on the PPC4xx platforms. Define CONFIG_I2C_MULTI_BUS in the board config file to make use of this feature. It also merges the 405 and 440 i2c header files into one common file 4xx_i2c.h. Also the 4xx i2c reset procedure is reworked since I experienced some problems with the first access on the 440SPe Katmai board. Signed-off-by: Stefan Roese <sr@denx.de>
2005-11-27Changed PPC44x startup message (cpu info, speed...) to common style:Stefan Roese
On PPC44x platforms, the startup message generated in "cpu.c" only comprised the ppc type and revision but not additional informations like speed etc. Those speed infos where printed in the board specific code. This new implementation now prints all CPU infos in the common cpu specific code. No board specific code is needed anymore and therefore removed from all current 44x implementations. Patch by Stefan Roese, 27 Nov 2005
2005-09-24* Fix PHY address argument passing with mii info commandWolfgang Denk
Patch by Andrew Dyer, 28 Dec 2004 * Cleanup: fix broken builds
