These boards have been orphaned for more than 6 months.
The sandburst-specific i2c drivers have been deleted, conflict was just
over the SPDX conversion.
board/sandburst/common/ppc440gx_i2c.c
board/sandburst/common/ppc440gx_i2c.h
[trini: Fixup common/cmd_io.c]
Signed-off-by: Dirk Eibach <dirk.eibach@gdsys.cc>
Cc: Stefan Roese <sr@denx.de>
Tested-by: Stefan Roese <sr@denx.de>
This patch removes the duplicted implementations of the pci_pre_init()
function by introducing a weak default function for it. This weak default
has a different implementation for some PPC variants. It can be
overridden by a board specific version.
This patch removes the duplicted implementations of the pci_target_init()
has a different implementation for 440EP(x)/GR(x) PPC's. It can be
overridden by a board specific version (e.g. PMC440, korat).
Acked-by: Matthias Fuchs <matthias.fuchs@esd.eu>
This patch introduces a weak default function for is_pci_host(),
returning 1. This is the default behaviour, since most boards only
implement PCI host functionality. This weak default can be overridden
by a board specific version if needed.
Modify all existing *.c files to use the new register names
as seen in the AMCC manuals.
Signed-off-by: Niklaus Giger <niklaus.giger@member.fsf.org>
The latest PPC4xx register cleanup patch missed some SDRAM defines.
This patch now changes lower case UIC defines to upper case. Also
some names are changed to match the naming in the IBM/AMCC users
manuals (e.g. mem_mcopt1 -> SDRAM0_CFG).
This patch cleans up multiple issues of the 4xx register (mostly
DCR, SDR, CPR, etc) definitions:
- Change lower case defines to upper case (plb4_acr -> PLB4_ACR)
- Change the defines to better match the names from the
user's manuals (e.g. cprpllc -> CPR0_PLLC)
- Removal of some unused defines
Please test this patch intensive on your PPC4xx platform. Even though
I tried not to break anything and tested successfully on multiple
4xx AMCC platforms, testing on custom platforms is recommended.
The environment is the canonical storage location of the mac address, so
we're killing off the global data location and moving everything to
querying the env directly.
Rather than have the common ppc code have board-specific hooks, move the
board_get_enetaddr() function into the board-specific init functions.
CC: Ben Warren <biggerbadderben@gmail.com>
This patch changes the return type of initdram() from long int to phys_size_t.
This is required for a couple of reasons: long int limits the amount of dram
to 2GB, and u-boot in general is moving over to phys_size_t to represent the
size of physical memory. phys_size_t is defined as an unsigned long on almost
all current platforms.
This patch *only* changes the return type of the initdram function (in
include/common.h, as well as in each board's implementation of initdram). It
does not actually modify the code inside the function on any of the platforms;
platforms which wish to support more than 2GB of DRAM will need to modify
their initdram() function code.
Build tested with MAKEALL for ppc, arm, mips, mips-el. Booted on powerpc
MPC8641HPCN.
Signed-off-by: Becky Bruce <becky.bruce@freescale.com>
This patch removes the CFG_PCI_PRE_INIT option completely, since
it's not needed anymore with the patch from Matthias Fuchs with
the "weak" pci_pre_init() implementation.
Second serial port on 440GX now defined as a system device.
Add 'Short Etch' code for Cicada PHY within 440gx_enet.c
Patch by Travis B. Sawyer, 12 Jul 2005
Check return value of malloc in 440gx_enet.c
Patch by Travis B. Sawyer, 18 Jul 2005
