path: root/board/sandburst/common/ppc440gx_i2c.h
2013-07-23i2c, ppc4xx_i2c: switch to new multibus/multiadapter supportDirk Eibach
Signed-off-by: Dirk Eibach <dirk.eibach@gdsys.cc> Cc: Heiko Schocher <hs@denx.de> Cc: Stefan Roese <sr@denx.de> Tested-by: Stefan Roese <sr@denx.de>
2010-09-23ppc4xx: Move ppc4xx headers to powerpc include directoryStefan Roese
This patch moves some ppc4xx related headers from the common include directory (include/) to the powerpc specific one (arch/powerpc/include/asm/). This way to common include directory is not so cluttered with files. Signed-off-by: Stefan Roese <sr@denx.de>
2009-12-22i2c, ppc4xx: fix compiling KAREF and METROBOX boards.Heiko Schocher
commit eb5eb2b0f744f0cba405160c5d01335c40f09acf ppc4xx: Cleanup PPC4xx I2C infrastructure This patch cleans up the PPC4xx I2C intrastructure: - Use C struct to describe the I2C registers instead of defines - Coding style cleanup (braces, whitespace, comments, line length) - Extract common code from i2c_read() and i2c_write() - Remove unneeded IIC defines from ppc405.h & ppc440.h breaks comiling for the KAREF and METROBOX boards. This patch fixes this issue. Signed-off-by: Heiko Schocher <hs@denx.de> Signed-off-by: Stefan Roese <sr@denx.de>
2009-10-07ppc_4xx: Apply new HW register namesNiklaus Giger
Modify all existing *.c files to use the new register names as seen in the AMCC manuals. Signed-off-by: Niklaus Giger <niklaus.giger@member.fsf.org> Signed-off-by: Stefan Roese <sr@denx.de>
2007-02-20[PATCH] PPC4xx: Add support for multiple I2C bussesStefan Roese
This patch adds support for multiple I2C busses on the PPC4xx platforms. Define CONFIG_I2C_MULTI_BUS in the board config file to make use of this feature. It also merges the 405 and 440 i2c header files into one common file 4xx_i2c.h. Also the 4xx i2c reset procedure is reworked since I experienced some problems with the first access on the 440SPe Katmai board. Signed-off-by: Stefan Roese <sr@denx.de>
2005-08-15Coding style cleanupWolfgang Denk
2005-08-15Add Sandburst Metrobox and Sandburst Karef board support packages.Stefan Roese
Second serial port on 440GX now defined as a system device. Add 'Short Etch' code for Cicada PHY within 440gx_enet.c Patch by Travis B. Sawyer, 12 Jul 2005 Check return value of malloc in 440gx_enet.c Patch by Travis B. Sawyer, 18 Jul 2005
