path: root/board/sandbox/MAINTAINERS
2016-07-14sandbox: Add a new sandbox_spl boardSimon Glass
It is useful to be able to build SPL for sandbox. It provides additional build coverage and allows SPL features to be tested in sandbox. However it does not need worthwhile to always create an SPL build. It nearly doubles the build time and the feature is (so far) seldom used. So for now, create a separate build target for sandbox SPL. This allows experimentation with this new feature without impacting existing workflows. Signed-off-by: Simon Glass <sjg@chromium.org>
2016-05-17dm: sandbox: Add a board for sandbox without CONFIG_BLKSimon Glass
While the driver-model block device support is in progress, it is useful to build sandbox both with and without CONFIG_BLK. Add a separate board for the latter. Signed-off-by: Simon Glass <sjg@chromium.org>
