path: root/board/samsung
2013-09-11Merge branch 'u-boot-samsung/master' into 'u-boot-arm/master'Albert ARIBAUD
Conflicts: tools/Makefile
2013-09-11arm:goni:mmc: Add sd card detection and initialization.Przemyslaw Marczak
This change allow to use sd card on Goni the same like mmc 0. SD card is mmc dev 1, so it can be used like this: "fatls mmc 1:2". SD card is inited even if eMMC initialization fails. Signed-off-by: Przemyslaw Marczak <p.marczak@samsung.com> Signed-off-by: Kyungmin Park <kyungmin.park@samsung.com> CC: Minkyu Kang <mk7.kang@samsung.com> Acked-by: Jaehoon Chung <jh80.chung@samsung.com> Signed-off-by: Minkyu Kang <mk7.kang@samsung.com>
2013-09-11dts: samsung: arndale: Fix include pathChander Kashyap
As per new convention ARCH_CPU_DTS is not defined in "dtc/Makefile". Hence Arndale comilation is failing. Fix this by adding proper include file in "board/samsung/dts/exynos5250-arndale.dts". Signed-off-by: Chander Kashyap <chander.kashyap@linaro.org> Signed-off-by: Minkyu Kang <mk7.kang@samsung.com>
2013-08-30exynos5250: arndale: Add mmc supportInderpal Singh
This patch adds mmc support to the arndale board. Signed-off-by: Inderpal Singh <inderpal.singh@linaro.org> Signed-off-by: Minkyu Kang <mk7.kang@samsung.com>
2013-08-30exynos5250: Add arndale board supportChander Kashyap
Arndale board is based on samsung's exynos5250 soc. Signed-off-by: Inderpal Singh <inderpal.singh@linaro.org> Signed-off-by: Chander Kashyap <chander.kashyap@linaro.org> Signed-off-by: Minkyu Kang <mk7.kang@samsung.com>
2013-08-28arm: goni: remove config.mk fileMinkyu Kang
Since config.mk is deprecated, remove this file, and move CONFIG_SYS_TEXT_BASE define to config file. Signed-off-by: Minkyu Kang <mk7.kang@samsung.com>
2013-08-28arm: smdkc100: remove config.mk fileMinkyu Kang
Since config.mk is deprecated, remove this file, and move CONFIG_SYS_TEXT_BASE define to config file. Signed-off-by: Minkyu Kang <mk7.kang@samsung.com> Cc: Wolfgang Denk <wd@denx.de>
2013-08-20i2c:samsung: Adjust Trats, GONI and Universal_c210 boards to work with new ↵Łukasz Majewski
I2C framework New I2C framework, introduced after v2013.07 final release, imposed I2C code adjustment for some Samsung boards - namely Trats, GONI and Universal_c210. Those boards were using schematic based I2C enumeration (I2C_5, I2C_9). However, new I2C framework imposes usage of logical I2C adapters numbering (e.g. I2C_0, I2C_1, etc). Additionally, I2C_GET_* macros were replaced with i2c_*_bus_num() functions. Trats board gained definition of second soft I2C adapter. Signed-off-by: Lukasz Majewski <l.majewski@samsung.com> Cc: Minkyu Kang <mk7.kang@samsung.com> Cc: Heiko Schocher <hs@denx.de>
2013-08-02dt: don't use ARCH_CPU_DTSStephen Warren
Now that we assume dtc supports the -i option, we don't need to use ARCH_CPU_DTS in *.dts{,i}; we simply specify the include filename directly, and dtc will find it. Signed-off-by: Stephen Warren <swarren@nvidia.com> Acked-by: Simon Glass <sjg@chromium.org>
2013-07-16arm:samsung:trats:fix: Restore proper orientation of TRATS's LCD panelŁukasz Majewski
Before setting: mipi_lcd_device.reverse_panel = 1, the Trats's LCD panel was flipped by 180 degrees. The flip was caused by following change: Exynos: Change get_timer() to work correctly SHA1: 3d00c0cb96ff93a929700b80d89cb905e5ab5315 This commit fixed udelay(), which is necessary (due to HW LCD controller oddity) for mipi-dsi correct operation. As a result the display orientation has been switched. As a follow up, the hwrevision() function has been removed, since it was used only in this particular place. Test HW: Trats Exynos4210 rev 0. Signed-off-by: Lukasz Majewski <l.majewski@samsung.com> Signed-off-by: Kyungmin Park <kyungmin.park@samsung.com> Cc: Minkyu Kang <mk7.kang@samsung.com> Acked-by: Minkyu Kang <mk7.kang@samsung.com>
2013-07-12Merge branch 'master' of git://git.denx.de/u-boot-armTom Rini
Fix a trivial conflict in arch/arm/dts/exynos5250.dtsi about gpio and serial. Conflicts: arch/arm/dts/exynos5250.dtsi Signed-off-by: Tom Rini <trini@ti.com>
2013-07-10EXYNOS: Resolve the i2c compilation errorAmar
This patch resolves the below mentioned compilation error of i2c driver for non-FDT case Compilation error: s3c24x0_i2c.c: In function 'board_i2c_init': s3c24x0_i2c.c:544:18: error: 'CONFIG_MAX_I2C_NUM' undeclared (first use in this function) s3c24x0_i2c.c:544:18: note: each undeclared identifier is reported only once for each function it appears in s3c24x0_i2c.c:545:3: warning: implicit declaration of function Signed-off-by: Rajeshwari Shinde <rajeshwari.s@samsung.com> Signed-off-by: Amar <amarendra.xt@samsung.com> Signed-off-by: Minkyu Kang <mk7.kang@samsung.com>
2013-07-05EXYNOS: Move files from board/samsung to arch/armRajeshwari Shinde
This patch performs the following: 1) Convert the assembly code for memory and clock initialization to C code. 2) Move the memory and clock init codes from board/samsung to arch/arm 3) Creat a common lowlevel_init file across Exynos4 and Exynos5. Converted the common lowlevel_init from assembly to C-code 4) Made spl_boot.c and tzpc_init.c common for both exynos4 and exynos5. 5) Enable CONFIG_SKIP_LOWLEVEL_INIT as stack pointer initialisation is already done in _main. 6) exynos-uboot-spl.lds made common across SMDKV310, Origen and SMDK5250. TEST: Tested SD-MMC boot on SMDK5250 and Origen. Tested USB and SPI boot on SMDK5250 Compile tested for SMDKV310. Signed-off-by: Rajeshwari Shinde <rajeshwari.s@samsung.com> Signed-off-by: Minkyu Kang <mk7.kang@samsung.com>
2013-07-05EXYNOS4210: Configure GPIO for uartRajeshwari Shinde
This patch configures the gpio values for UART on Origen and SMDKV310 using pinmux Signed-off-by: Rajeshwari Shinde <rajeshwari.s@samsung.com> Acked-by: Simon Glass <sjg@chromium.org> Signed-off-by: Minkyu Kang <mk7.kang@samsung.com>
2013-07-05EXYNOS: LDS file move to commonRajeshwari Shinde
smdk5250-uboot-spl.lds is moved to common folder, so that it can be reused. It is renamed to exynos-uboot-spl.lds Signed-off-by: Rajeshwari Shinde <rajeshwari.s@samsung.com> Acked-by: Simon Glass <sjg@chromium.org> Tested-by: Simon Glass <sjg@chromium.org> Signed-off-by: Minkyu Kang <mk7.kang@samsung.com>
2013-06-28SMDK5250: Remove reduntant codeRajeshwari Shinde
enum boot_mode is defined twice once in spl.h and also in spl_boot.c, hence removing the same from spl_boot.c and including the header file. Signed-off-by: Rajeshwari Shinde <rajeshwari.s@samsung.com> Acked-by: Simon Glass <sjg@chromium.org> Signed-off-by: Minkyu Kang <mk7.kang@samsung.com>
2013-06-26cros: exynos: enable cros-ec for smdk5250Hung-ying Tyan
This patch initiates cros-ec in board_init() to enable it for smdk5250. This patch depends on the patch in the MMC series that brings in exynos5-dt.c. Refer to http://patchwork.ozlabs.org/patch/240084. Signed-off-by: Simon Glass <sjg@chromium.org> Signed-off-by: Vincent Palatin <vpalatin@chromium.org> Signed-off-by: Hung-ying Tyan <tyanh@chromium.org> Acked-by: Simon Glass <sjg@chromium.org>
2013-06-26cros: exynos: add cros-ec device nodes to exynos5250-snow.dtsHung-ying Tyan
This patch adds cros-ec related device nodes to exynos5250-snow.dts. It also adds a gpio node to exynos5250.dtsi. Signed-off-by: Hung-ying Tyan <tyanh@chromium.org> Acked-by: Simon Glass <sjg@chromium.org>
2013-06-24EXYNOS5: FDT: Add serial device node valuesRajeshwari Shinde
This patch adds the device node required for serial driver Signed-off-by: Abhilash Kesavan <a.kesavan@samsung.com> Signed-off-by: Rajeshwari Shinde <rajeshwari.s@samsung.com> Signed-off-by: Minkyu Kang <mk7.kang@samsung.com>
2013-06-24exynos: Adjust the starting MIF voltage to 1.05vBernie Thompson
Some Exynos5250 silicon may require 1.05v on the MIF to be stable, so to be safe we can default to 1.05v instead of 1.00v. This can be set optimally later in the boot process by the kernel. The 0x6 value for 1.05v comes from the MAX77686 datasheet. Signed-off-by: Bernie Thompson <bhthompson@chromium.org> Acked-by: Simon Glass <sjg@chromium.org> Signed-off-by: Minkyu Kang <mk7.kang@samsung.com>
2013-06-21exynos: Enable mmc for snowSimon Glass
Snow has an internal eMMC and an external SD card. Enable these in the device tree. Signed-off-by: Simon Glass <sjg@chromium.org> Signed-off-by: Minkyu Kang <mk7.kang@samsung.com>
2013-06-13SMDK5250: Enable EMMC bootingAmar
This patch adds support for EMMC booting on SMDK5250. Signed-off-by: Amar <amarendra.xt@samsung.com> Signed-off-by: Minkyu Kang <mk7.kang@samsung.com>
2013-06-13SMDK5250: Initialise and Enable DWMMC, support FDT and non-FDTAmar
This patch enables and initialises DWMMC for SMDK5250. Supports both FDT and non-FDT. This patch creates a new file 'exynos5-dt.c' meant for FDT support. exynos5-dt.c: This file shall contain all code which supports FDT. Any addition of FDT support for any module needs to be added in this file. smdk5250.c: This file shall contain the code which supports non-FDT. version. Any addition of non-FDT support for any module needs to be added in this file. May be, the file smdk5250.c can be removed in near future when non-FDT is not required. The Makefile is updated to compile only one of the files exynos5-dt.c / smdk5250.c based on FDT configuration. NOTE: Please note that all additions corresponding to FDT need to be added into the file exynos5-dt.c. At same time if non-FDT support is required then add the corresponding updations into smdk5250.c. Signed-off-by: Amar <amarendra.xt@samsung.com> Signed-off-by: Minkyu Kang <mk7.kang@samsung.com>
2013-06-13EXYNOS5: FDT: Add DWMMC device node dataAmar
This patch adds DWMMC device node data for exynos5. This patch also adds binding file for DWMMC device node. Signed-off-by: Vivek Gautam <gautam.vivek@samsung.com> Signed-off-by: Amar <amarendra.xt@samsung.com> Acked-by: Jaehoon Chung <jh80.chung@samsung.com> Acked-by: Simon Glass <sjg@chromium.org> Signed-off-by: Minkyu Kang <mk7.kang@samsung.com>
2013-06-04exynos: Update origen and smdkv310 to use common tzpc_initInderpal Singh
Signed-off-by: Inderpal Singh <inderpal.singh@linaro.org> Acked-by: Chander Kashyap <chander.kashyap@linaro.org> Signed-off-by: Minkyu Kang <mk7.kang@samsung.com>
2013-06-04exynos: update tzpc to make it common for exynos4 and exynos5Inderpal Singh
This requires that cpu_is_exynos4/5 should be made available before tzpc_init. Hence this patch also makes necessary changes to have cpu_info in spl and invokes arch_cpu_init before tzpc_init in low_level_init.S for smdk5250. Signed-off-by: Inderpal Singh <inderpal.singh@linaro.org> Acked-by: Chander Kashyap <chander.kashyap@linaro.org> Signed-off-by: Minkyu Kang <mk7.kang@samsung.com>
2013-06-04exynos: move tzpc_init to armv7/exynosInderpal Singh
tzpc_init is common for all exynos5 boards, hence move it to armv7/exynos so that all other boards can use it. Also update the smdk5250 Makefile and config file. Signed-off-by: Inderpal Singh <inderpal.singh@linaro.org> Acked-by: Chander Kashyap <chander.kashyap@linaro.org> Signed-off-by: Minkyu Kang <mk7.kang@samsung.com>
2013-04-17exynos: fdt: Add TMU node for snowSimon Glass
Snow is missing a TMU node, and with TMU support this is not allowed, so it fails to boot. Add it. Signed-off-by: Simon Glass <sjg@chromium.org> Signed-off-by: Minkyu Kang <mk7.kang@samsung.com>
2013-04-17Exynos5: Add support for USB download boot modeVivek Gautam
Exynos5250 supports secondary USB device boot mode. If the iROM fails to download u-boot from the primary boot device (such as SD or eMMC), it will try to retrieve from the secondary boot device (such as USB). Signed-off-by: Naveen Krishna Ch <ch.naveen@samsung.com> Signed-off-by: Simon Glass <sjg@chromium.org> Signed-off-by: Vivek Gautam <gautam.vivek@samsung.com> Acked-by: Simon Glass <sjg@chromium.org> Signed-off-by: Minkyu Kang <mk7.kang@samsung.com>
2013-04-14smdk5250, snow: convert to CONFIG_SPL_MAX_FOOTPRINTAlbert ARIBAUD
This target wants to check full SPL size, BSS included. Remove CONFIG_SPL_MAX_SIZE definition and instead define CONFIG_SPL_MAX_FOOTPRINT. Signed-off-by: Albert ARIBAUD <albert.u.boot@aribaud.net>
2013-04-12arm: Make all linker scripts compatible with per-symbol sectionsBenoît Thébaudeau
Let all ARM linker scripts handle properly -ffunction-sections and -fdata-sections. This will be useful for future changes in order to create symbol-specific sections in common .S files. Signed-off-by: Benoît Thébaudeau <benoit.thebaudeau@advansee.com>
2013-04-12arm: Remove support for smdk6400Benoît Thébaudeau
The migration of boards from Makefile to boards.cfg was due for v2012.03, but smdk6400 did not follow, and it does not build, so move it to scrapyard. It will still be possible to restore it from the Git history before fixing it. Signed-off-by: Benoît Thébaudeau <benoit.thebaudeau@advansee.com>
2013-04-12arm: Remove unused relocate_code() parametersBenoît Thébaudeau
Commit e05e5de7fae5bec79617e113916dac6631251156 made the 2 1st parameters of ARM's relocate_code() useless since it moved the code handling them to crt0.S. So, drop these parameters. Signed-off-by: Benoît Thébaudeau <benoit.thebaudeau@advansee.com>
2013-04-12arm: relocate_code(): Use __image_copy_end for end of relocationBenoît Thébaudeau
Use __image_copy_end instead of __bss_start for the end of the image to relocate. This is the same as commit 033ca72, but applied to all ARM start.S. This is a more appropriate symbol naming for an image copy & relocate feature, and this also saves a useless copy of data put between __image_copy_end and __bss_start in linker scripts (e.g. relocation information, or MMU initialization tables used only before jumping to the relocated image). Signed-off-by: Benoît Thébaudeau <benoit.thebaudeau@advansee.com>
2013-04-01Exynos: clock: Correct pwm source clk selectionPadmavathi Venna
MPLL is selected as the source clk of pwm by default Test with command "sf probe 1:0; time sf read 40008000 0 1000". Try with different numbers of bytes and see that sane values are obtained Build and boot U-boot with this patch, backlight works properly. Signed-off-by: Padmavathi Venna <padma.v@samsung.com> Signed-off-by: Akshay Saraswat <akshay.s@samsung.com> Acked-by: Simon Glass <sjg@chromium.org> Signed-off-by: Minkyu Kang <mk7.kang@samsung.com>
2013-03-29Exynos5: clock: Fix a typo bug in exynos clock initAkshay Saraswat
We intended to clear the bits of CLK_SRC_TOP2 register, instead we were writing on the reserved bits of src_core1 register. Since the default value of clk_src_top2 register were itself zero, this typo was not creating any big issue. But it is better to fix this error for better readability of the code. Signed-off-by: Hatim Ali <hatim.rv@samsung.com> Signed-off-by: Akshay Saraswat <akshay.s@samsung.com> Acked-by: Simon Glass <sjg@chromium.org> Signed-off-by: Minkyu Kang <mk7.kang@samsung.com>
2013-03-29Exynos: clock: Fix a bug in PLL lock check conditionAkshay Saraswat
The condition for testing of PLL getting locked was incorrect. Rectify this error in this patch. Reported-by: Alexei Fedorov <alexie.fedorov@arm.com> Signed-off-by: Hatim Ali <hatim.rv@samsung.com> Signed-off-by: Akshay Saraswat <akshay.s@samsung.com> Acked-by: Simon Glass <sjg@chromium.org> Signed-off-by: Minkyu Kang <mk7.kang@samsung.com>
2013-03-29SMDK5250: Fix compiler warning for non-dt systemsVivek Gautam
Compiling for non-dt systems gives folowing warning: smdk5250.c: In function 'board_eth_init': smdk5250.c:152:6: warning: unused variable 'node' [-Wunused-variable] Declare variable 'node' only for dt enabled systems to remove this warning. Signed-off-by: Vivek Gautam <gautam.vivek@samsung.com> Acked-by: Simon Glass <sjg@chromium.org> Signed-off-by: Minkyu Kang <mk7.kang@samsung.com>
2013-03-27SMDK5250: Use statically defined structures only in non DT caseAjay Kumar
Since we have DT support in exynos_fb and exynos_dp drivers now, we need not define any static structure or platform data related to display in the board file smdk5250.c. So, we place the already existing structures inside #ifndef CONFIG_OF_CONTROL block. Signed-off-by: Ajay Kumar <ajaykumar.rs@samsung.com> Signed-off-by: Minkyu Kang <mk7.kang@samsung.com>
2013-03-27SMDK5250: Add device node for DPAjay Kumar
Add DT bindings for DP supporting an eDP panel of size 2560x1600. Signed-off-by: Ajay Kumar <ajaykumar.rs@samsung.com> Signed-off-by: Minkyu Kang <mk7.kang@samsung.com>
2013-03-27SMDK5250: Add device node for FIMDAjay Kumar
Add DT bindings for FIMD supporting an eDP panel of size 2560x1600. Signed-off-by: Ajay Kumar <ajaykumar.rs@samsung.com> Signed-off-by: Minkyu Kang <mk7.kang@samsung.com>
2013-03-27video: exynos_dp: Remove callbacks from the driverAjay Kumar
Replaced the functionality of callbacks by using a standard set of functions. Instead of implementing and hooking up a callback, put the same code in one of the standard set of functions by overriding it. Signed-off-by: Ajay Kumar <ajaykumar.rs@samsung.com> Signed-off-by: Minkyu Kang <mk7.kang@samsung.com>
2013-03-27video: exynos_fb: Remove callbacks from the driverAjay Kumar
Replaced the functionality of callbacks by using a standard set of functions. Instead of implementing and hooking up a callback, put the same code in one of the standard set of functions by overriding it. This patch is tested only on SMDK5250. For Trats and universal_c210 board, it is only compile tested. Signed-off-by: Ajay Kumar <ajaykumar.rs@samsung.com> Signed-off-by: Minkyu Kang <mk7.kang@samsung.com>
2013-03-26Merge branch 'u-boot-samsung/master' into 'u-boot-arm/master'Albert ARIBAUD
2013-03-18Merge branch 'master' of git://git.denx.de/u-boot-usbTom Rini
2013-03-18Merge branch 'master' of git://git.denx.de/u-boot-armTom Rini
Albert's rework of the linker scripts conflicted with Simon's making everyone use __bss_end. We also had a minor conflict over README.scrapyard being added to in mainline and enhanced in u-boot-arm/master with proper formatting. Conflicts: arch/arm/cpu/ixp/u-boot.lds arch/arm/cpu/u-boot.lds arch/arm/lib/Makefile board/actux1/u-boot.lds board/actux2/u-boot.lds board/actux3/u-boot.lds board/dvlhost/u-boot.lds board/freescale/mx31ads/u-boot.lds doc/README.scrapyard include/configs/tegra-common.h Build tested for all of ARM and run-time tested on am335x_evm. Signed-off-by: Tom Rini <trini@ti.com>
2013-03-18arm:trats: Use new ums commandLukasz Majewski
This patch enables new "ums" command on Trats board Signed-off-by: Lukasz Majewski <l.majewski@samsung.com> Signed-off-by: Piotr Wilczek <p.wilczek@samsung.com> Signed-off-by: Kyungmin Park <kyungmin.park@samsung.com> CC: Minkyu Kang <mk7.kang@samsung.com>
2013-03-15Replace __bss_end__ with __bss_endSimon Glass
Note this is a tree-wide change affecting multiple architectures. At present we use __bss_start, but mostly __bss_end__. This seems inconsistent and in a number of places __bss_end is used instead. Change to use __bss_end for the BSS end symbol throughout U-Boot. This makes it possible to use the asm-generic/sections.h file on all archs. Signed-off-by: Simon Glass <sjg@chromium.org>
2013-03-12Refactor linker-generated arraysAlbert ARIBAUD
Refactor linker-generated array code so that symbols which were previously linker-generated are now compiler- generated. This causes relocation records of type R_ARM_ABS32 to become R_ARM_RELATIVE, which makes code which uses LGA able to run before relocation as well as after. Note: this affects more than ARM targets, as linker- lists span possibly all target architectures, notably PowerPC. Conflicts: arch/arm/cpu/arm926ejs/mxs/u-boot-spl.lds arch/arm/cpu/arm926ejs/spear/u-boot-spl.lds arch/arm/cpu/armv7/omap-common/u-boot-spl.lds board/ait/cam_enc_4xx/u-boot-spl.lds board/davinci/da8xxevm/u-boot-spl-da850evm.lds board/davinci/da8xxevm/u-boot-spl-hawk.lds board/vpac270/u-boot-spl.lds Signed-off-by: Albert ARIBAUD <albert.u.boot@aribaud.net>
