path: root/board/samsung/trats
2012-09-17i2c:soft:multi: Enable soft I2C multibus at Trats development boardŁukasz Majewski
This commit enables multibus handling at Samsung's Trats development board. Signed-off-by: Lukasz Majewski <l.majewski@samsung.com> Signed-off-by: Kyungmin Park <kyungmin.park@samsung.com> Cc: Minkyu Kang <mk7.kang@samsung.com> Acked-by: Heiko Schocher <hs@denx.de>
2012-09-01arm:trats: Support for USB UDC driver at TRATS board.Lukasz Majewski
Support for USB UDC driver at trats board. Signed-off-by: Lukasz Majewski <l.majewski@samsung.com> Signed-off-by: Kyungmin Park <kyungmin.park@samsung.com> Cc: Marek Vasut <marex@denx.de> Cc: Minkyu Kang <mk7.kang@samsung.com>
2012-07-07misc:pmic:trats: Correct procedure of enabling/disabling USB regulatorsŁukasz Majewski
In the MAX8997, LDO regulators needs to preserve previously set voltage values. Signed-off-by: Lukasz Majewski <l.majewski@samsung.com> Signed-off-by: Kyungmin Park <kyungmin.park@samsung.com> Signed-off-by: Minkyu Kang <mk7.kang@samsung.com>
2012-07-07TRATS: initialize panel_info data structure in board fileDonghwa Lee
panel_info data structure is gloable variable, so, I have initialized it in board file. If it is initialized in init_panel_info() like existing, it can't be used in drv_lcd_init() in common/lcd.c because init_panel_info() is called after drv_lcd_init(). Signed-off-by: Donghwa Lee <dh09.lee@samsung.com> Signed-off-by: Kyungmin Park <kyungmin.park@samsung.com> Acked-by: Anatolij Gustschin <agust@denx.de> Signed-off-by: Minkyu Kang <mk7.kang@samsung.com>
2012-05-25EXYNOS: display 32bpp bitmap TIZEN logoDonghwa Lee
This patch supports drawing 32bpp bitmap TIZEN logo in exynos fb. "tizen_hd_logo.h" data is compressed from trats_logo.bmp to trats_logo.bmp.gz by gzip and converted to tizen_hd_logo.h header file format by some application. The logo data is decompressed in the exynos fb driver by bmp_display(). Signed-off-by: Donghwa Lee <dh09.lee@samsung.com> Signed-off-by: Kyungmin Park <kyungmin.park@samsung.com> Acked-by: Minkyu Kang <mk7.kang@samsung.com> Signed-off-by: Anatolij Gustschin <agust@denx.de>
2012-05-25LCD: support another s6e8ax0 panel typeDonghwa Lee
s6e8ax0 panel has many panel of types. This patch support another panel on TIZEN lunchbox board(HWREVISION 2). This panel has reversed panel display type. So, I had added necessary command. Signed-off-by: Donghwa Lee <dh09.lee@samsung.com> Signed-off-by: Kyungmin Park <kyungmin.park@samsung.com> Acked-by: Minkyu Kang <mk7.kang@samsung.com> Signed-off-by: Anatolij Gustschin <agust@denx.de>
2012-05-15EXYNOS: Change bits per pixel value proper for u-boot.Donghwa Lee
vl_bpix of vidinfo_t was changed proper value for u-boot. It is used to multiple of 2 by using NBITS() macro. Signed-off-by: Donghwa Lee <dh09.lee@samsung.com> Signed-off-by: Kyungmin Park <kyungmin.park@samsung.com> Acked-by: Anatolij Gustschin <agust@denx.de> Signed-off-by: Minkyu Kang <mk7.kang@samsung.com>
2012-05-15EXYNOS: support TRATS board display functionDonghwa Lee
This patch support TRATS board configuration and display function. Signed-off-by: Donghwa Lee <dh09.lee@samsung.com> Signed-off-by: Kyungmin Park <kyungmin.park@samsung.com> Signed-off-by: Inki Dae <inki.dae@samsung.com> Signed-off-by: Minkyu Kang <mk7.kang@samsung.com>
2012-05-15misc:pmic:samsung Convert TRATS target to use MAX8997 instead of MAX8998Łukasz Majewski
TRATS target uses MAX8997 PMIC device instead of MAX8998. Signed-off-by: Lukasz Majewski <l.majewski@samsung.com> Signed-off-by: Kyungmin Park <kyungmin.park@samsung.com> Acked-by: Minkyu Kang <mk7.kang@samsung.com>
2012-02-12TRATS: set gpio of UART correctlyMinkyu Kang
Signed-off-by: Minkyu Kang <mk7.kang@samsung.com> Signed-off-by: HeungJun, Kim <riverful.kim@samsung.com> Cc: Chander Kashyap <chander.kashyap@linaro.org>
2012-02-12TRATS: use the generic watchdog timerMinkyu Kang
Signed-off-by: Minkyu Kang <mk7.kang@samsung.com> Signed-off-by: Kyungmin Park <kyungmin.park@samsung.com> Cc: HeungJun, Kim <riverful.kim@samsung.com>
2012-02-12ARMV7: Exynos4: Add support for TRATS boardHeungJun, Kim
This patch adds support for Samsung TRATS board Signed-off-by: HeungJun, Kim <riverful.kim@samsung.com> Signed-off-by: Kyungmin Park <kyungmin.park@samsung.com> Signed-off-by: Minkyu Kang <mk7.kang@samsung.com>
