path: root/board/samsung/smdk5420/MAINTAINERS
2015-07-10arm: adds the status info for odroid-xu3Minkyu Kang
Adds the 'F:' entry for the board's defconfig Signed-off-by: Minkyu Kang <mk7.kang@samsung.com>
2015-04-09odroid-XU3: update board maintainerPrzemyslaw Marczak
At present Hyungwon can't take care of this board in U-Boot, so I will keep it working. Signed-off-by: Przemyslaw Marczak <p.marczak@samsung.com> Cc: Hyungwon Hwang <human.hwang@samsung.com>
2014-11-17Config: Exynos5800: Enable build for Peach-PiAkshay Saraswat
This adds following things : - New config and defconfig for Peach-Pi board. - Alterations in Kconfig and MAINTAINERS. - Addition of CONFIG_EXYNOS5800. - ADdition of exynos5800-peach-pi in dts list. Signed-off-by: Akshay Saraswat <akshay.s@samsung.com> Acked-by: Simon Glass <sjg@chromium.org> Tested-by: Simon Glass <sjg@chromium.org> Signed-off-by: Minkyu Kang <mk7.kang@samsung.com>
2014-10-08exynos: update maintainer of Snow and SMDK5420 boardMasahiro Yamada
The email address of Rajeshwari Shinde <rajeshwari.s@samsung.com> is not working. This commit gives Akshay the maintainership of Snow and SMDK5420 boards. Signed-off-by: Masahiro Yamada <yamada.m@jp.panasonic.com> Cc: Akshay Saraswat <akshay.s@samsung.com> Cc: Minkyu Kang <mk7.kang@samsung.com> Signed-off-by: Minkyu Kang <mk7.kang@samsung.com>
