path: root/board/samsung/smdk5250
2015-08-05exynos: Add support for springSimon Glass
Spring is the first ARM-based HP Chromebook 11. It is similar to snow and it uses the same Samsung Exynos5250 chip. But has some unusual features. Mainline support for it has lagged snow (both in kernel and U-Boot). Now that the exynos5 code is common we can support spring just by adding a device tree and a few lines of configuration. Signed-off-by: Simon Glass <sjg@chromium.org>
2015-08-05exynos: Drop old exynos5250-specific board codeSimon Glass
Now that most exynos5250 boards can use the generic exynos5 code, switch over to it and remove the old code. Signed-off-by: Simon Glass <sjg@chromium.org>
2014-10-22dm: exynos: Make sure that GPIOs are requestedSimon Glass
With driver model GPIOs must be requested before use. Make sure this is done correctly. (Note that the soft SPI part of universal is omitted, since this driver is about to be replaced with a driver-model-aware version) Signed-off-by: Simon Glass <sjg@chromium.org>
2014-10-08exynos: update maintainer of Snow and SMDK5420 boardMasahiro Yamada
The email address of Rajeshwari Shinde <rajeshwari.s@samsung.com> is not working. This commit gives Akshay the maintainership of Snow and SMDK5420 boards. Signed-off-by: Masahiro Yamada <yamada.m@jp.panasonic.com> Cc: Akshay Saraswat <akshay.s@samsung.com> Cc: Minkyu Kang <mk7.kang@samsung.com> Signed-off-by: Minkyu Kang <mk7.kang@samsung.com>
2014-08-30exynos: kconfig: move board select menu and common settingsMasahiro Yamada
Becuase the board select menu in arch/arm/Kconfig is too big, move the Exynos board select menu to exynos/Kconfig. Consolidate also common settings (CONFIG_SYS_CPU="armv7" and CONFIG_SYS_SOC="exynos"). Signed-off-by: Masahiro Yamada <yamada.m@jp.panasonic.com> Acked-by: Minkyu Kang <mk7.kang@samsung.com>
2014-05-28exynos: Enable the LCD backlight for snowSimon Glass
The backlight uses FETs on the TPS65090. Enable this so that the display is visible. Signed-off-by: Simon Glass <sjg@chromium.org> Reviewed-by: Lukasz Majewski <l.majewski@samsung.com> Signed-off-by: Minkyu Kang <mk7.kang@samsung.com>
2014-05-28exynos5: support tps65090 pmicAaron Durbin
The TSP65090 is a PMIC on some exynos5 boards. The init function is called for the TPS65090 pmic. If that device is not a part of the device tree (returns -ENODEV) then continue. Otherwise return a failure. Signed-off-by: Aaron Durbin <adurbin@chromium.org> Signed-off-by: Simon Glass <sjg@chromium.org> Reviewed-by: Simon Glass <sjg@chromium.org> Signed-off-by: Minkyu Kang <mk7.kang@samsung.com>
2014-05-28exynos: Drop old smdk5250.c fileSimon Glass
This is not used by any boards now. Drop it to avoid confusion. Signed-off-by: Simon Glass <sjg@chromium.org> Signed-off-by: Minkyu Kang <mk7.kang@samsung.com>
2014-05-13S5P: Exynos: Add GPIO pin numbering and rename definitionsAkshay Saraswat
This patch includes following changes : * Adds gpio pin numbering support for EXYNOS SOCs. To have consistent 0..n-1 GPIO numbering the banks are divided into different parts where ever they have holes in them. * Rename GPIO definitions from GPIO_... to S5P_GPIO_... These changes were done to enable cmd_gpio for EXYNOS and cmd_gpio has GPIO_INPUT same as s5p_gpio driver and hence getting a error during compilation. * Adds support for name to gpio conversion in s5p_gpio to enable gpio command EXYNOS SoCs. Function has been added to asm/gpio.h to decode the input gpio name to gpio number. Example: SMDK5420 # gpio set gpa00 Signed-off-by: Leela Krishna Amudala <l.krishna@samsung.com> Signed-off-by: Rajeshwari Shinde <rajeshwari.s@samsung.com> Signed-off-by: Akshay Saraswat <akshay.s@samsung.com> Acked-by: Przemyslaw Marczak <p.marczak@samsung.com> Signed-off-by: Minkyu Kang <mk7.kang@samsung.com>
2014-03-25Merge branch 'u-boot/master' into 'u-boot-arm/master'Albert ARIBAUD
Trivial merge conflict, needed to manually remove local_info as per commit 41364f0f. Conflicts: board/samsung/common/board.c
2014-03-17cros_ec: Move EC interface into common libraryVadim Bendebury
Add a common library for obtaining access to the Chrome OS EC. This is used by boards which need to talk to the EC. Reviewed-by: Vadim Bendebury <vbendeb@google.com> Tested-by: Vadim Bendebury <vbendeb@google.com> Signed-off-by: Vadim Bendebury <vbendeb@chromium.org> Signed-off-by: Simon Glass <sjg@chromium.org>
2014-03-12board:samsung:common: move max77686 init functionPiotr Wilczek
This patch moves board specific max77686 init function from common board to smdk5250 board file. Signed-off-by: Piotr Wilczek <p.wilczek@samsung.com> Signed-off-by: Kyungmin Park <kyungmin.park@samsung.com> Cc: Rajeshwari S Shinde <rajeshwari.s@samsung.com> Cc: Rajeshwari Birje <rajeshwari.birje@gmail.com> Signed-off-by: Minkyu Kang <mk7.kang@samsung.com>
2014-03-12board:samsung: move checkboard to common filePiotr Wilczek
The checkboard function's implementation is common for all DT supporting boards and should be placed in the board common file. Signed-off-by: Piotr Wilczek <p.wilczek@samsung.com> Signed-off-by: Kyungmin Park <kyungmin.park@samsung.com> Cc: Chander Kashyap <k.chander@samsung.com> Cc: Rajeshwari S Shinde <rajeshwari.s@samsung.com> Cc: Amar <amarendra.xt@samsung.com> Acked-by: Rajeshwari Shinde <rajeshwari.s@samsung.com> Signed-off-by: Minkyu Kang <mk7.kang@samsung.com>
2014-02-19Exynos5250: Remove lowlevelinitRajeshwari S Shinde
Since we use CONFIG_SKIP_LOWLEVEL_INIT for Exynos baords, we dont need to a lowlevel_init.S file. Signed-off-by: Rajeshwari S Shinde <rajeshwari.s@samsung.com> Acked-by: Simon Glass <sjg@chromium.org>
2014-02-03smdk5250: Remove 'board_usb_vbus_init()' functionVivek Gautam
Previously as a part of moving the VBUS gpio support to device tree following patch removed this and added relevant support in driver: 4a271cb exynos: usb: Switch USB VBUS GPIOs to be device tree configured Recent changes for common board file migration for exynos platform added it again. So removing it now. Signed-off-by: Vivek Gautam <gautam.vivek@samsung.com> Cc: Julius Werner <jwerner@chromium.org> Cc: Minkyu Kang <mk7.kang@samsung.com> Cc: Marek Vasut <marex@denx.de> Signed-off-by: Minkyu Kang <mk7.kang@samsung.com>
2013-12-30EXYNOS5: Create a common board fileRajeshwari Birje
Create a common board.c file for all functions which are common across all EXYNOS5 platforms. exynos_init function is provided for platform specific code. Signed-off-by: Rajeshwari S Shinde <rajeshwari.s@samsung.com> Acked-by: Simon Glass <sjg@chromium.org> Signed-off-by: Minkyu Kang <mk7.kang@samsung.com>
2013-12-05driver:i2c:s3c24x0: adapt driver to new i2cPiotr Wilczek
This patch adapts the s3c24x0 driver to the new i2c framework. Config file is modified for all the boards that use the driver. Signed-off-by: Piotr Wilczek <p.wilczek@samsung.com> Signed-off-by: Kyungmin Park <kyungmin.park@samsung.com> CC: Minkyu Kang <mk7.kang@samsung.com> CC: Heiko Schocher <hs@denx.de> CC: Inderpal Singh <inderpal.singh@linaro.org> CC: David Müller <d.mueller@elsoft.ch> CC: Chander Kashyap <k.chander@samsung.com> CC: Lukasz Majewski <l.majewski@samsung.com> Tested-by: Naveen Krishna Chatradhi <ch.naveen@samsung.com> Reviewed-by: Naveen Krishna Chatradhi <ch.naveen@samsung.com>
2013-10-20exynos: usb: Switch USB VBUS GPIOs to be device tree configuredJulius Werner
Some Exynos boards, such as the SMDK5250, control USB port power through a GPIO pin. For now this had been hardcoded in the exynos5-dt board file, but not all boards use the same pin, requiring local changes to support different boards. This patch moves the GPIO initialization into the USB host controller drivers which they belong to, and uses the samsung,vbus-gpio parameter in the device tree to configure it. Signed-off-by: Julius Werner <jwerner@chromium.org> Signed-off-by: Vivek Gautam <gautam.vivek@samsung.com> Cc: Simon Glass <sjg@chromium.org> Cc: Minkyu Kang <mk7.kang@samsung.com> Cc: Marek Vasut <marex@denx.de>
2013-07-12Merge branch 'master' of git://git.denx.de/u-boot-armTom Rini
Fix a trivial conflict in arch/arm/dts/exynos5250.dtsi about gpio and serial. Conflicts: arch/arm/dts/exynos5250.dtsi Signed-off-by: Tom Rini <trini@ti.com>
2013-07-10EXYNOS: Resolve the i2c compilation errorAmar
This patch resolves the below mentioned compilation error of i2c driver for non-FDT case Compilation error: s3c24x0_i2c.c: In function 'board_i2c_init': s3c24x0_i2c.c:544:18: error: 'CONFIG_MAX_I2C_NUM' undeclared (first use in this function) s3c24x0_i2c.c:544:18: note: each undeclared identifier is reported only once for each function it appears in s3c24x0_i2c.c:545:3: warning: implicit declaration of function Signed-off-by: Rajeshwari Shinde <rajeshwari.s@samsung.com> Signed-off-by: Amar <amarendra.xt@samsung.com> Signed-off-by: Minkyu Kang <mk7.kang@samsung.com>
2013-07-05EXYNOS: Move files from board/samsung to arch/armRajeshwari Shinde
This patch performs the following: 1) Convert the assembly code for memory and clock initialization to C code. 2) Move the memory and clock init codes from board/samsung to arch/arm 3) Creat a common lowlevel_init file across Exynos4 and Exynos5. Converted the common lowlevel_init from assembly to C-code 4) Made spl_boot.c and tzpc_init.c common for both exynos4 and exynos5. 5) Enable CONFIG_SKIP_LOWLEVEL_INIT as stack pointer initialisation is already done in _main. 6) exynos-uboot-spl.lds made common across SMDKV310, Origen and SMDK5250. TEST: Tested SD-MMC boot on SMDK5250 and Origen. Tested USB and SPI boot on SMDK5250 Compile tested for SMDKV310. Signed-off-by: Rajeshwari Shinde <rajeshwari.s@samsung.com> Signed-off-by: Minkyu Kang <mk7.kang@samsung.com>
2013-07-05EXYNOS: LDS file move to commonRajeshwari Shinde
smdk5250-uboot-spl.lds is moved to common folder, so that it can be reused. It is renamed to exynos-uboot-spl.lds Signed-off-by: Rajeshwari Shinde <rajeshwari.s@samsung.com> Acked-by: Simon Glass <sjg@chromium.org> Tested-by: Simon Glass <sjg@chromium.org> Signed-off-by: Minkyu Kang <mk7.kang@samsung.com>
2013-06-28SMDK5250: Remove reduntant codeRajeshwari Shinde
enum boot_mode is defined twice once in spl.h and also in spl_boot.c, hence removing the same from spl_boot.c and including the header file. Signed-off-by: Rajeshwari Shinde <rajeshwari.s@samsung.com> Acked-by: Simon Glass <sjg@chromium.org> Signed-off-by: Minkyu Kang <mk7.kang@samsung.com>
2013-06-26cros: exynos: enable cros-ec for smdk5250Hung-ying Tyan
This patch initiates cros-ec in board_init() to enable it for smdk5250. This patch depends on the patch in the MMC series that brings in exynos5-dt.c. Refer to http://patchwork.ozlabs.org/patch/240084. Signed-off-by: Simon Glass <sjg@chromium.org> Signed-off-by: Vincent Palatin <vpalatin@chromium.org> Signed-off-by: Hung-ying Tyan <tyanh@chromium.org> Acked-by: Simon Glass <sjg@chromium.org>
2013-06-24exynos: Adjust the starting MIF voltage to 1.05vBernie Thompson
Some Exynos5250 silicon may require 1.05v on the MIF to be stable, so to be safe we can default to 1.05v instead of 1.00v. This can be set optimally later in the boot process by the kernel. The 0x6 value for 1.05v comes from the MAX77686 datasheet. Signed-off-by: Bernie Thompson <bhthompson@chromium.org> Acked-by: Simon Glass <sjg@chromium.org> Signed-off-by: Minkyu Kang <mk7.kang@samsung.com>
2013-06-13SMDK5250: Enable EMMC bootingAmar
This patch adds support for EMMC booting on SMDK5250. Signed-off-by: Amar <amarendra.xt@samsung.com> Signed-off-by: Minkyu Kang <mk7.kang@samsung.com>
2013-06-13SMDK5250: Initialise and Enable DWMMC, support FDT and non-FDTAmar
This patch enables and initialises DWMMC for SMDK5250. Supports both FDT and non-FDT. This patch creates a new file 'exynos5-dt.c' meant for FDT support. exynos5-dt.c: This file shall contain all code which supports FDT. Any addition of FDT support for any module needs to be added in this file. smdk5250.c: This file shall contain the code which supports non-FDT. version. Any addition of non-FDT support for any module needs to be added in this file. May be, the file smdk5250.c can be removed in near future when non-FDT is not required. The Makefile is updated to compile only one of the files exynos5-dt.c / smdk5250.c based on FDT configuration. NOTE: Please note that all additions corresponding to FDT need to be added into the file exynos5-dt.c. At same time if non-FDT support is required then add the corresponding updations into smdk5250.c. Signed-off-by: Amar <amarendra.xt@samsung.com> Signed-off-by: Minkyu Kang <mk7.kang@samsung.com>
2013-06-04exynos: update tzpc to make it common for exynos4 and exynos5Inderpal Singh
This requires that cpu_is_exynos4/5 should be made available before tzpc_init. Hence this patch also makes necessary changes to have cpu_info in spl and invokes arch_cpu_init before tzpc_init in low_level_init.S for smdk5250. Signed-off-by: Inderpal Singh <inderpal.singh@linaro.org> Acked-by: Chander Kashyap <chander.kashyap@linaro.org> Signed-off-by: Minkyu Kang <mk7.kang@samsung.com>
2013-06-04exynos: move tzpc_init to armv7/exynosInderpal Singh
tzpc_init is common for all exynos5 boards, hence move it to armv7/exynos so that all other boards can use it. Also update the smdk5250 Makefile and config file. Signed-off-by: Inderpal Singh <inderpal.singh@linaro.org> Acked-by: Chander Kashyap <chander.kashyap@linaro.org> Signed-off-by: Minkyu Kang <mk7.kang@samsung.com>
2013-04-17Exynos5: Add support for USB download boot modeVivek Gautam
Exynos5250 supports secondary USB device boot mode. If the iROM fails to download u-boot from the primary boot device (such as SD or eMMC), it will try to retrieve from the secondary boot device (such as USB). Signed-off-by: Naveen Krishna Ch <ch.naveen@samsung.com> Signed-off-by: Simon Glass <sjg@chromium.org> Signed-off-by: Vivek Gautam <gautam.vivek@samsung.com> Acked-by: Simon Glass <sjg@chromium.org> Signed-off-by: Minkyu Kang <mk7.kang@samsung.com>
2013-04-14smdk5250, snow: convert to CONFIG_SPL_MAX_FOOTPRINTAlbert ARIBAUD
This target wants to check full SPL size, BSS included. Remove CONFIG_SPL_MAX_SIZE definition and instead define CONFIG_SPL_MAX_FOOTPRINT. Signed-off-by: Albert ARIBAUD <albert.u.boot@aribaud.net>
2013-04-12arm: Make all linker scripts compatible with per-symbol sectionsBenoît Thébaudeau
Let all ARM linker scripts handle properly -ffunction-sections and -fdata-sections. This will be useful for future changes in order to create symbol-specific sections in common .S files. Signed-off-by: Benoît Thébaudeau <benoit.thebaudeau@advansee.com>
2013-04-01Exynos: clock: Correct pwm source clk selectionPadmavathi Venna
MPLL is selected as the source clk of pwm by default Test with command "sf probe 1:0; time sf read 40008000 0 1000". Try with different numbers of bytes and see that sane values are obtained Build and boot U-boot with this patch, backlight works properly. Signed-off-by: Padmavathi Venna <padma.v@samsung.com> Signed-off-by: Akshay Saraswat <akshay.s@samsung.com> Acked-by: Simon Glass <sjg@chromium.org> Signed-off-by: Minkyu Kang <mk7.kang@samsung.com>
2013-03-29Exynos5: clock: Fix a typo bug in exynos clock initAkshay Saraswat
We intended to clear the bits of CLK_SRC_TOP2 register, instead we were writing on the reserved bits of src_core1 register. Since the default value of clk_src_top2 register were itself zero, this typo was not creating any big issue. But it is better to fix this error for better readability of the code. Signed-off-by: Hatim Ali <hatim.rv@samsung.com> Signed-off-by: Akshay Saraswat <akshay.s@samsung.com> Acked-by: Simon Glass <sjg@chromium.org> Signed-off-by: Minkyu Kang <mk7.kang@samsung.com>
2013-03-29Exynos: clock: Fix a bug in PLL lock check conditionAkshay Saraswat
The condition for testing of PLL getting locked was incorrect. Rectify this error in this patch. Reported-by: Alexei Fedorov <alexie.fedorov@arm.com> Signed-off-by: Hatim Ali <hatim.rv@samsung.com> Signed-off-by: Akshay Saraswat <akshay.s@samsung.com> Acked-by: Simon Glass <sjg@chromium.org> Signed-off-by: Minkyu Kang <mk7.kang@samsung.com>
2013-03-29SMDK5250: Fix compiler warning for non-dt systemsVivek Gautam
Compiling for non-dt systems gives folowing warning: smdk5250.c: In function 'board_eth_init': smdk5250.c:152:6: warning: unused variable 'node' [-Wunused-variable] Declare variable 'node' only for dt enabled systems to remove this warning. Signed-off-by: Vivek Gautam <gautam.vivek@samsung.com> Acked-by: Simon Glass <sjg@chromium.org> Signed-off-by: Minkyu Kang <mk7.kang@samsung.com>
2013-03-27SMDK5250: Use statically defined structures only in non DT caseAjay Kumar
Since we have DT support in exynos_fb and exynos_dp drivers now, we need not define any static structure or platform data related to display in the board file smdk5250.c. So, we place the already existing structures inside #ifndef CONFIG_OF_CONTROL block. Signed-off-by: Ajay Kumar <ajaykumar.rs@samsung.com> Signed-off-by: Minkyu Kang <mk7.kang@samsung.com>
2013-03-27video: exynos_dp: Remove callbacks from the driverAjay Kumar
Replaced the functionality of callbacks by using a standard set of functions. Instead of implementing and hooking up a callback, put the same code in one of the standard set of functions by overriding it. Signed-off-by: Ajay Kumar <ajaykumar.rs@samsung.com> Signed-off-by: Minkyu Kang <mk7.kang@samsung.com>
2013-03-27video: exynos_fb: Remove callbacks from the driverAjay Kumar
Replaced the functionality of callbacks by using a standard set of functions. Instead of implementing and hooking up a callback, put the same code in one of the standard set of functions by overriding it. This patch is tested only on SMDK5250. For Trats and universal_c210 board, it is only compile tested. Signed-off-by: Ajay Kumar <ajaykumar.rs@samsung.com> Signed-off-by: Minkyu Kang <mk7.kang@samsung.com>
2013-03-26Merge branch 'u-boot-samsung/master' into 'u-boot-arm/master'Albert ARIBAUD
2013-03-18Merge branch 'master' of git://git.denx.de/u-boot-armTom Rini
Albert's rework of the linker scripts conflicted with Simon's making everyone use __bss_end. We also had a minor conflict over README.scrapyard being added to in mainline and enhanced in u-boot-arm/master with proper formatting. Conflicts: arch/arm/cpu/ixp/u-boot.lds arch/arm/cpu/u-boot.lds arch/arm/lib/Makefile board/actux1/u-boot.lds board/actux2/u-boot.lds board/actux3/u-boot.lds board/dvlhost/u-boot.lds board/freescale/mx31ads/u-boot.lds doc/README.scrapyard include/configs/tegra-common.h Build tested for all of ARM and run-time tested on am335x_evm. Signed-off-by: Tom Rini <trini@ti.com>
2013-03-15Replace __bss_end__ with __bss_endSimon Glass
Note this is a tree-wide change affecting multiple architectures. At present we use __bss_start, but mostly __bss_end__. This seems inconsistent and in a number of places __bss_end is used instead. Change to use __bss_end for the BSS end symbol throughout U-Boot. This makes it possible to use the asm-generic/sections.h file on all archs. Signed-off-by: Simon Glass <sjg@chromium.org>
2013-03-12Refactor linker-generated arraysAlbert ARIBAUD
Refactor linker-generated array code so that symbols which were previously linker-generated are now compiler- generated. This causes relocation records of type R_ARM_ABS32 to become R_ARM_RELATIVE, which makes code which uses LGA able to run before relocation as well as after. Note: this affects more than ARM targets, as linker- lists span possibly all target architectures, notably PowerPC. Conflicts: arch/arm/cpu/arm926ejs/mxs/u-boot-spl.lds arch/arm/cpu/arm926ejs/spear/u-boot-spl.lds arch/arm/cpu/armv7/omap-common/u-boot-spl.lds board/ait/cam_enc_4xx/u-boot-spl.lds board/davinci/da8xxevm/u-boot-spl-da850evm.lds board/davinci/da8xxevm/u-boot-spl-hawk.lds board/vpac270/u-boot-spl.lds Signed-off-by: Albert ARIBAUD <albert.u.boot@aribaud.net>
2013-03-12Exynos5: TMU: Add TMU init and status checkAkshay Saraswat
This adds call to tmu_init() and TMU boot time analysis for the SoC temperature threshold breach. Signed-off-by: Akshay Saraswat <akshay.s@samsung.com> Acked-by: Simon Glass <sjg@chromium.org> Signed-off-by: Minkyu Kang <mk7.kang@samsung.com>
2013-03-12SMDK5250: FDT: Retrieve board model via DTRajeshwari Shinde
Print out the board model by parsing the device tree file. Signed-off-by: Rajeshwari Shinde <rajeshwari.s@samsung.com> Acked-by: Simon Glass <sjg@chromium.org> Signed-off-by: Minkyu Kang <mk7.kang@samsung.com>
