path: root/board/samsung/smdk5250
2013-03-08EXYNOS5: GPIO to enable MAX98095Rajeshwari Shinde
This patch sets high a GPIO to enable the codec MAX98095 Signed-off-by: Rajeshwari Shinde <rajeshwari.s@samsung.com> Acked-by: Simon Glass <sjg@chromium.org> Signed-off-by: Minkyu Kang <mk7.kang@samsung.com>
2013-02-20SMDK5250: Add PMIC voltage settingsRajeshwari Shinde
This patch adds required pmic voltage settings for SMDK5250. Acked-by: Simon Glass <sjg@chromium.org> Signed-off-by: Rajeshwari Shinde <rajeshwari.s@samsung.com> Signed-off-by: Minkyu Kang <mk7.kang@samsung.com>
2013-01-11EXYNOS5: Make all display related code dependent on CONFIG_LCDAjay Kumar
u-boot compilation fails for smdk5250 when we deselect CONFIG_LCD from the main config file. Following error was observed: drivers/video/libvideo.o: In function `exynos_lcd_init': /home/ajay/u-boot-samsung/drivers/video/exynos_fb.c:68: undefined reference to `lcd_set_flush_dcache' This is because exynos video drivers have dependency on CONFIG_LCD. Signed-off-by: Ajay Kumar <ajaykumar.rs@samsung.com> Acked-by: Simon Glass <sjg@chromium.org> Signed-off-by: Minkyu Kang <mk7.kang@samsung.com>
2013-01-10EXYNOS5: Add support for FIMD and DPAjay Kumar
Add panel_info structure required by LCD driver and DP panel platdata for SMDK5250. Add GPIO configuration for LCD. Enable FIMD and DP support on SMDK5250. DP Panel size: 2560x1600. We use 16BPP resolution to get LCD console. Signed-off-by: Ajay Kumar <ajaykumar.rs@samsung.com> Acked-by: Simon Glass <sjg@chomium.org> Signed-off-by: Minkyu Kang <mk7.kang@samsung.com>
2013-01-08SMDK5250: Enable VBus for USB 2.0 controllerVivek Gautam
This patch enables Vbus required for USB 2.0 controller. Signed-off-by: Vivek Gautam <gautam.vivek@samsung.com> Signed-off-by: Rajeshwari Shinde <rajeshwari.s@samsung.com> Signed-off-by: Minkyu Kang <mk7.kang@samsung.com>
2013-01-08SMDK5250: Initialise I2C using FDTRajeshwari Shinde
This patch initialises I2C using FDT. Signed-off-by: Rajeshwari Shinde <rajeshwari.s@samsung.com> Acked-by: Simon Glass <sjg@chromium.org> Acked-by: Heiko Schocher <hs@denx.de> Signed-off-by: Minkyu Kang <mk7.kang@samsung.com>
2012-12-26exynos5: Add DT based driver for SMC911X ethernetHatim RV
Add device tree based ethernet driver for SMC911X controller on SMDK5250 boards. Signed-off-by: Hatim Ali <hatim.rv@samsung.com> Acked-by: Simon Glass <sjg@chromium.org> Signed-off-by: Minkyu Kang <mk7.kang@samsung.com>
2012-12-11SMDK5250: Enable pmic MAX77686Rajeshwari Shinde
Enabled pmic MAX77686 for SMDK5250. Signed-off-by: Rajeshwari Shinde <rajeshwari.s@samsung.com> Reviewed-by: Lukasz Majewski <l.majewski@samsung.com> Acked-by: Lukasz Majewski <l.majewski@samsung.com> Signed-off-by: Minkyu Kang <mk7.kang@samsung.com>
2012-11-15EXYNOS5: Enable SPI booting.Rajeshwari Shinde
This patch enables SPI Booting for EXYNOS5 Signed-off-by: Rajeshwari Shinde <rajeshwari.s@samsung.com> Signed-off-by: Minkyu Kang <mk7.kang@samsung.com>
2012-11-15EXYNOS5: Enable SPIHatim RV
This patch enables SPI driver for EXYNOS5. Signed-off-by: Rajeshwari Shinde <rajeshwari.s@samsung.com> Signed-off-by: Hatim Ali <hatim.rv@samsung.com> Acked-by: Simon Glass <sjg@chromium.org> Signed-off-by: Minkyu Kang <mk7.kang@samsung.com>
2012-11-15SMDK5250: Config: Enable MAX77686 pmic chipRajeshwari Shinde
This patch enables MAX77686 pmic chip for SMDK5250. Signed-off-by: Rajeshwari Shinde <rajeshwari.s@samsung.com> Signed-off-by: Minkyu Kang <mk7.kang@samsung.com>
2012-10-22common: Add .u_boot_list into all linker filesMarek Vasut
Add section for the linker-generated lists into all possible linker files, so that everyone can easily use these lists. This is mostly a mechanical adjustment. Signed-off-by: Marek Vasut <marex@denx.de> Cc: Joe Hershberger <joe.hershberger@gmail.com> Cc: Mike Frysinger <vapier@gentoo.org>
2012-09-01SMDK5250: Enable UART and MMC for Exynos5250 Rev 1.0Rajeshwari Shinde
This patch sets UART3 and MMC channle 0 for Exynos5250 Rev 1.0 Signed-off-by: Rajeshwari Shinde <rajeshwari.s@samsung.com> Signed-off-by: Minkyu Kang <mk7.kang@samsung.com>
2012-09-01Exynos5: DDR3: Add DDR3 memory setup for Exynos5250 Rev 1.0Rajeshwari Shinde
The patch adds the memory initialization sequence of DDR3. Signed-off-by: Hatim Ali <hatim.rv@samsung.com> Signed-off-by: Rajeshwari Shinde <rajeshwari.s@samsung.com> Signed-off-by: Minkyu Kang <mk7.kang@samsung.com>
2012-09-01EXYNOS5: CLOCK: Add clock support for Exynos5250 Rev 1.0Rajeshwari Shinde
Add new clock values for Exynos5250 Rev 1.0 Signed-off-by: Hatim Ali <hatim.rv@samsung.com> Signed-off-by: Rajeshwari Shinde <rajeshwari.s@samsung.com> Signed-off-by: Minkyu Kang <mk7.kang@samsung.com>
2012-09-01SMDK5250: Add smdk5250-uboot-spl.ldsRajeshwari Shinde
Default spl/u-boot-spl.lds created by spl/Makefile resolves the spl text load addr to 0x0. As 0x0 belongs to iROM addr so Global variables can not be used. Adding specific smdk5250-uboot-spl.lds makes possible to use Global Variables in spl. Signed-off-by: Alim Akhtar <alim.akhtar@samsung.com> Signed-off-by: Rajeshwari Shinde <rajeshwari.s@samsung.com> Signed-off-by: Minkyu Kang <mk7.kang@samsung.com>
2012-09-01SMDK5250: SPL: Define parametric board initializerRajeshwari Shinde
Define table-driven configuration mechanism for SMDK5250 rather than hard-coding board initialization parameters. Signed-off-by: Che-Liang Chiou <clchiou@chromium.org> Signed-off-by: Abhilash Kesavan <a.kesavan@samsung.com> Signed-off-by: Tom Wai-Hong Tam <waihong@chromium.org> Signed-off-by: Simon Glass <sjg@chromium.org> Signed-off-by: Rajeshwari Shinde <rajeshwari.s@samsung.com> Signed-off-by: Minkyu Kang <mk7.kang@samsung.com>
2012-07-31CONFIG: SMDK5250: I2C: Enable I2CRajeshwari Shinde
This enables I2C support on smdk5250. Pinmux setting moved to board file to avoid repeated setting of gpio lines. Signed-off-by: Alim Akhtar <alim.akhtar@samsung.com> Signed-off-by: Doug Anderson <dianders@chromium.org> Signed-off-by: Rajeshwari Shinde <rajeshwari.s@samsung.com> Acked-by: Simon Glass <sjg@chromium.org>
2012-07-07EXYNOS: SMDK5250: Enable the pinmux setupRajeshwari Shinde
Use the pinmux configuration function for SMDK5250. Signed-off-by: Abhilash Kesavan <a.kesavan@samsung.com> Signed-off-by: Rajeshwari Shinde <rajeshwari.s@samsung.com> Acked-by: Chander Kashyap <chander.kashyap@linaro.org> Acked-by: Simon Glass <sjg@chromium.org> Signed-off-by: Minkyu Kang <mk7.kang@samsung.com>
2012-05-15SMDK5250: fix compiler warningMinkyu Kang
this patch fixed following warning. tzpc_init.c: In function 'tzpc_init': tzpc_init.c:35: warning: assignment from incompatible pointer type Signed-off-by: Minkyu Kang <mk7.kang@samsung.com> Cc: Chander Kashyap <chander.kashyap@linaro.org>
2012-05-15EXYNOS: Rename exynos5_tzpc structure to exynos_tzpcChander Kashyap
TZPC IP is common across Exynos based SoC'c. Renaming exynos5_tzpc in arch/arm/include/asm/arch-exynos/tzpc.h to exynos_tzpc will allow generic usase of tzpc. Also modify board/samsung/smdk5250/tzpc_init.c to use exynos_tzpc. Signed-off-by: Chander Kashyap <chander.kashyap@linaro.org> Signed-off-by: Minkyu Kang <mk7.kang@samsung.com>
2012-03-27EXYNOS: SMDK5250: Support all 4 UARTsDoug Anderson
This properly configures the mux to enable all UARTs. This also fixes things so that we don't configure balls XUCTSN_1 and XURTSN_1 as UART1 configuration (RTS/CTS), since they aren't connected. Signed-off-by: Doug Anderson <dianders@chromium.org> Acked-by: Chander kashyap <chander.kashyap@linaro.org> Signed-off-by: Minkyu Kang <mk7.kang@samsung.com>
2012-02-12SMDK5250: Add ethernet supportChander Kashyap
This patch enable support for SMC911X based ethernet device. Signed-off-by: Chander Kashyap <chander.kashyap@linaro.org> Acked-by: Mike Frysinger <vapier@gentoo.org> Acked-by: Simon Glass <sjg@chromium.org> Signed-off-by: Minkyu Kang <mk7.kang@samsung.com>
2012-02-12EXYNOS: SMDK5250: Add MMC SPL supportChander Kashyap
This patch adds support for MMC SPL booting. Signed-off-by: Chander Kashyap <chander.kashyap@linaro.org> Signed-off-by: Minkyu Kang <mk7.kang@samsung.com>
2012-02-12EXYNOS: Add SMDK5250 board supportChander Kashyap
SMDK5250 board is based on Samsungs EXYNOS5250 SoC. Signed-off-by: Chander Kashyap <chander.kashyap@linaro.org> Signed-off-by: Minkyu Kang <mk7.kang@samsung.com>
