This patch performs the following:
1) Convert the assembly code for memory and clock initialization to C code.
2) Move the memory and clock init codes from board/samsung to arch/arm
3) Creat a common lowlevel_init file across Exynos4 and Exynos5. Converted
the common lowlevel_init from assembly to C-code
4) Made spl_boot.c and tzpc_init.c common for both exynos4 and exynos5.
5) Enable CONFIG_SKIP_LOWLEVEL_INIT as stack pointer initialisation is already
done in _main.
6) exynos-uboot-spl.lds made common across SMDKV310, Origen and SMDK5250.
TEST: Tested SD-MMC boot on SMDK5250 and Origen.
Tested USB and SPI boot on SMDK5250
Compile tested for SMDKV310.
Signed-off-by: Rajeshwari Shinde <rajeshwari.s@samsung.com>
tzpc_init is common for all exynos5 boards, hence move it to
armv7/exynos so that all other boards can use it.
Also update the smdk5250 Makefile and config file.
Signed-off-by: Inderpal Singh <inderpal.singh@linaro.org>
Acked-by: Chander Kashyap <chander.kashyap@linaro.org>
MPLL is selected as the source clk of pwm by default
Test with command "sf probe 1:0; time sf read 40008000 0 1000".
Try with different numbers of bytes and see that sane values are obtained
Build and boot U-boot with this patch, backlight works properly.
Signed-off-by: Padmavathi Venna <padma.v@samsung.com>
Signed-off-by: Akshay Saraswat <akshay.s@samsung.com>
The patch adds the memory initialization sequence of DDR3.
Signed-off-by: Hatim Ali <hatim.rv@samsung.com>
Add new clock values for Exynos5250 Rev 1.0
SMDK5250 board is based on Samsungs EXYNOS5250 SoC.
Signed-off-by: Chander Kashyap <chander.kashyap@linaro.org>
