path: root/board/samsung/smdk2400/smdk2400.c
2009-11-27Add a unified s3c24x0 header filekevin.morfitt@fearnside-systems.co.uk
This patch adds a unified s3c24x0 cpu header file that selects the header file for the specific s3c24x0 cpu from the SOC and CPU configs defined in board config file. This removes the current chain of s3c24-type #ifdef's from the s3c24x0 code. Signed-off-by: Kevin Morfitt <kevin.morfitt@fearnside-systems.co.uk> Signed-off-by: Minkyu Kang <mk7.kang@samsung.com>
2009-11-27Move s3c24x0 header files to asm-arm/arch-s3c24x0/kevin.morfitt@fearnside-systems.co.uk
This patch moves the s3c24x0 header files from include/ to include/asm-arm/arch-s3c24x0/. checkpatch.pl showed 2 errors and 3 warnings. The 2 errors were both due to a non-UTF8 character in David M?ller's name: ERROR: Invalid UTF-8, patch and commit message should be encoded in UTF-8 #489: FILE: include/asm-arm/arch-s3c24x0/s3c2410.h:3: + * David M?ller ELSOFT AG Switzerland. d.mueller@elsoft.ch As David's name correctly contains a non-UTF8 character I haven't fixed these errors. The 3 warnings were all because of the use of 'volatile' in s3c24x0.h: WARNING: Use of volatile is usually wrong: see Documentation/volatile-considered-harmful.txt #673: FILE: include/asm-arm/arch-s3c24x0/s3c24x0.h:35: +typedef volatile u8 S3C24X0_REG8; +typedef volatile u16 S3C24X0_REG16; +typedef volatile u32 S3C24X0_REG32; I'll fix these errors in another patch. Tested by running MAKEALL for ARM8 targets and ensuring there were no new errors or warnings. Signed-off-by: Kevin Morfitt <kevin.morfitt@fearnside-systems.co.uk> Signed-off-by: Minkyu Kang <mk7.kang@samsung.com>
2009-10-13Clean-up of s3c24x0 drivers excluding nand driverkevin.morfitt@fearnside-systems.co.uk
This patch re-formats the arm920t s3c24x0 driver files, excluding the nand driver, in preparation for changes to add support for the Embest SBC2440-II Board. The changes are as follows: - re-indent the code using Lindent - make sure register layouts are defined using a C struct - replace the upper-case typedef'ed C struct names with lower case non-typedef'ed ones - make sure registers are accessed using the proper accessor functions - run checkpatch.pl and fix any error reports It assumes the following patch has been applied first: - [U-Boot][PATCH-ARM] CONFIG_SYS_HZ fix for ARM902T S3C24X0 Boards, 05/09/2009 - patches 1/4 and 2/4 of this series Tested on an Embest SBC2440-II Board with local u-boot patches as I don't have any s3c2400 or s3c2410 boards but need this patch applying before I can submit patches for the SBC2440-II Board. Also, temporarily modified sbc2410x, smdk2400, smdk2410 and trab configs to use the mtd nand driver (which isn't used by any board at the moment), ran MAKEALL for all ARM9 targets and no new warnings or errors were found. Signed-off-by: Kevin Morfitt <kevin.morfitt@fearnside-systems.co.uk> Signed-off-by: Minkyu Kang <mk7.kang@samsung.com>
2009-08-25Convert CS8900 Ethernet driver to CONFIG_NET_MULTI APIBen Warren
All in-tree boards that use this controller have CONFIG_NET_MULTI added Also: - changed CONFIG_DRIVER_CS8900 to CONFIG_CS8900 - changed CS8900_BASE to CONFIG_CS8900_BASE - changed CS8900_BUS?? to CONFIG_CS8900_BUS?? - cleaned up line lengths - modified VCMA9 command function that accesses the device - removed MAC address initialization from lib_arm/board.c Signed-off-by: Ben Warren <biggerbadderben@gmail.com> Tested-by: Wolfgang Denk <wd@denx.de> Acked-by: Wolfgang Denk <wd@denx.de>
2009-05-15Fix e-mail address of Gary Jennejohn.Detlev Zundel
Signed-off-by: Detlev Zundel <dzu@denx.de>
2009-01-29move Samsung's board to board/samsungJean-Christophe PLAGNIOL-VILLARD
