path: root/board/samsung/origen
2016-02-24samsung: fix mkorigenspl for darwinAndreas Bießmann
Compiling the mkorigenspl tool on darwin complains about undefined ulong. Fix this by using the unified way. Signed-off-by: Andreas Bießmann <andreas.devel@googlemail.com>
2015-10-24Fix bad return value checks (detected with Coccinelle)Thomas Huth
In the "Getting Started with Coccinelle - KVM edition" presentation that has been held by Julia Lawall at the KVM forum 2015 (see the slides at http://events.linuxfoundation.org/sites/events/files/slides/tutorial_kvm_0.pdf), she pointed out some bad return value checks in U-Boot that can be detected with Coccinelle by using the following config file: @@ identifier x,y; identifier f; statement S; @@ x = f(...); ( if (x < 0) S | if ( - y + x < 0) S ) This patch now fixes these issues. Signed-off-by: Thomas Huth <huth@tuxfamily.org>
2014-10-22dm: exynos: Tidy up GPIO headersSimon Glass
The wrong header is being included, thus requiring the code to re-declare the generic GPIO interface in each GPIO header. Fix this. Signed-off-by: Simon Glass <sjg@chromium.org>
2014-08-30exynos: kconfig: move board select menu and common settingsMasahiro Yamada
Becuase the board select menu in arch/arm/Kconfig is too big, move the Exynos board select menu to exynos/Kconfig. Consolidate also common settings (CONFIG_SYS_CPU="armv7" and CONFIG_SYS_SOC="exynos"). Signed-off-by: Masahiro Yamada <yamada.m@jp.panasonic.com> Acked-by: Minkyu Kang <mk7.kang@samsung.com>
2014-05-05usb: dfu: fix boards wo USB cable detectionMateusz Zalega
Former usb_cable_connected() patch broke compilation of boards which do not support this feature. I've renamed usb_cable_connected() to g_dnl_usb_cable_connected() and added its default implementation to gadget downloader driver code. There's only one driver of this kind and it's unlikely there'll be another, so there's no point in keeping it in /common. Previously this function was declared in usb.h. I've moved it, since it's more appropriate to keep it in g_dnl.h - usb.h seems to be intended for USB host implementation. Existing code, confronted with default -EOPNOTSUPP return value, continues as if the cable was connected. CONFIG_USB_CABLE_CHECK was removed. Change-Id: Ib9198621adee2811b391c64512f14646cefd0369 Signed-off-by: Mateusz Zalega <m.zalega@samsung.com> Acked-by: Marek Vasut <marex@denx.de> Acked-by: Lukasz Majewski <l.majewski@samsung.com>
2014-03-12board:origen: Enable device tree on OrigenPiotr Wilczek
This patch enables to run Origen board on device tree. Uart, DRAM and MMC init functions are removed as their generic replacements form the common board file are used. The config file is modified to contain only board specific options. Signed-off-by: Piotr Wilczek <p.wilczek@samsung.com> Signed-off-by: Kyungmin Park <kyungmin.park@samsung.com> Cc: Chander Kashyap <k.chander@samsung.com> Signed-off-by: Minkyu Kang <mk7.kang@samsung.com>
2014-02-19kbuild: add dummy obj-y to create built-in.oMasahiro Yamada
We are going to switch over to Kbuild in upcoming commits. Each makefile must have non-empty obj- or obj-y to generate built-in.o on Kbuild. Signed-off-by: Masahiro Yamada <yamada.m@jp.panasonic.com>
2014-02-19kbuild: change out-of-tree buildMasahiro Yamada
This commit changes the working directory where the build process occurs. Before this commit, build process occurred under the source tree for both in-tree and out-of-tree build. That's why we needed to add $(obj) prefix to all generated files in makefiles like follows: $(obj)u-boot.bin: $(obj)u-boot Here, $(obj) is empty for in-tree build, whereas it points to the output directory for out-of-tree build. And our old build system changes the current working directory with "make -C <sub-dir>" syntax when descending into the sub-directories. On the other hand, Kbuild uses a different idea to handle out-of-tree build and directory descending. The build process of Kbuild always occurs under the output tree. When "O=dir/to/store/output/files" is given, the build system changes the current working directory to that directory and restarts the make. Kbuild uses "make -f $(srctree)/scripts/Makefile.build obj=<sub-dir>" syntax for descending into sub-directories. (We can write it like "make $(obj)=<sub-dir>" with a shorthand.) This means the current working directory is always the top of the output directory. Signed-off-by: Masahiro Yamada <yamada.m@jp.panasonic.com> Tested-by: Gerhard Sittig <gsi@denx.de>
2014-02-19board: samsung: refactor host programsMasahiro Yamada
Some Samsung boards have their own tools under board/samsung/<board>/tools/. This commit refactor more makefiles with "hostprogs-y". Signed-off-by: Masahiro Yamada <yamada.m@jp.panasonic.com>
2013-07-05EXYNOS: Move files from board/samsung to arch/armRajeshwari Shinde
This patch performs the following: 1) Convert the assembly code for memory and clock initialization to C code. 2) Move the memory and clock init codes from board/samsung to arch/arm 3) Creat a common lowlevel_init file across Exynos4 and Exynos5. Converted the common lowlevel_init from assembly to C-code 4) Made spl_boot.c and tzpc_init.c common for both exynos4 and exynos5. 5) Enable CONFIG_SKIP_LOWLEVEL_INIT as stack pointer initialisation is already done in _main. 6) exynos-uboot-spl.lds made common across SMDKV310, Origen and SMDK5250. TEST: Tested SD-MMC boot on SMDK5250 and Origen. Tested USB and SPI boot on SMDK5250 Compile tested for SMDKV310. Signed-off-by: Rajeshwari Shinde <rajeshwari.s@samsung.com> Signed-off-by: Minkyu Kang <mk7.kang@samsung.com>
2013-07-05EXYNOS4210: Configure GPIO for uartRajeshwari Shinde
This patch configures the gpio values for UART on Origen and SMDKV310 using pinmux Signed-off-by: Rajeshwari Shinde <rajeshwari.s@samsung.com> Acked-by: Simon Glass <sjg@chromium.org> Signed-off-by: Minkyu Kang <mk7.kang@samsung.com>
2013-06-04exynos: Update origen and smdkv310 to use common tzpc_initInderpal Singh
Signed-off-by: Inderpal Singh <inderpal.singh@linaro.org> Acked-by: Chander Kashyap <chander.kashyap@linaro.org> Signed-off-by: Minkyu Kang <mk7.kang@samsung.com>
2012-10-26Origen: Add default clock settings for multimedia IPsAnnamalai Lakshmanan
Added clock settings for MFC, FIMC, FB and G3D. They are clocked to maximum respective frequencies as per datasheet. Signed-off-by: Annamalai Lakshmanan <annamalai.lakshmanan@linaro.org> Signed-off-by: Giridhar Maruthy <giridhar.maruthy@linaro.org> Signed-off-by: Inderpal Singh <inderpal.singh@linaro.org> Signed-off-by: Tushar Behera <tushar.behera@linaro.org>
2012-02-12Origen: Select SCLKMPLL as FIMD0 parent clockChander Kashyap
Signed-off-by: Chander Kashyap <chander.kashyap@linaro.org> Signed-off-by: Minkyu Kang <mk7.kang@samsung.com>
2011-12-09S5PC2XX: Rename S5pc2XX to exynosChander Kashyap
As per new naming convention for Samsung SoC's, all Cortex-A9 and Cortex-A15 based SoC's will be classified under the name Exynos. Cortex-A9 and Cortex-A15 based SoC's will be sub-classified as Exynos4 and Exynos5 respectively. In order to better adapt and reuse code across various upcoming Samsung Exynos based boards, all uses of s5pc210 prefix/suffix/directory-names are renamed in this patch. s5pc210 is renamed as exynos4210 and S5PC210/s5pc210 suffix/prefix are renamed as exynos4/EXYNOS4. Signed-off-by: Chander Kashyap <chander.kashyap@linaro.org> Signed-off-by: Minkyu Kang <mk7.kang@samsung.com>
2011-11-03ORIGEN : use absolute paths and fix tool namingAngus Ainslie
On some hosts using relative paths will cause the build to fail. This patch sets absolute paths for the tools directory Get rid of MSDOS style excecutable extension Signed-off-by: Angus Ainslie <angus.ainslie@linaro.org> Signed-off-by: Minkyu Kang <mk7.kang@samsung.com>
2011-10-22build: add missing $(AR)->$(cmd_link_o_target) updateMike Frysinger
Seems people fixed their files to use libfoo.o, but didn't actually update the creation targets to use $(cmd_link_o_target). Update the rest of the Makefile's found with grep. Signed-off-by: Mike Frysinger <vapier@gentoo.org> Tested-by: Simon Glass <sjg@chromium.org>
2011-09-04ORIGEN: Add MMC SPL supportChander Kashyap
Adds mmc boot support. Signed-off-by: Chander Kashyap <chander.kashyap@linaro.org> Signed-off-by: Minkyu Kang <mk7.kang@samsung.com>
2011-09-04ARMV7: Add support for Samsung ORIGEN boardChander Kashyap
Origen board is based upon S5PV310 SoC which is similiar to S5PC210 SoC. Signed-off-by: Chander Kashyap <chander.kashyap@linaro.org> Signed-off-by: Minkyu Kang <mk7.kang@samsung.com>
